[mpich-discuss] exit without calling finalize(windows xp pro 64bit)
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Sep 18 11:33:10 CDT 2012
 The error message says that one of the MPI processes exited before calling MPI_Finalize. This usually occurs when one of the MPI processes exits prematurely (segfault etc). I would recommend debugging your code further to find the source of the problem.
(PS: The error message can also occur if there is a bug in MPICH that causes the application to abort - however I would recommend debugging the application first to find the exact source of the problem.)
Jayesh
----- Original Message -----
Sent: Friday, September 14, 2012 7:58:22 PM
Subject: [mpich-discuss] exit without calling finalize(windows xp pro 64bit)
Dear all ,
I recently have written a program which calls MSC.Patran and MSC.Nastran over and over again until find an optimal solution, in the visual studio 2010 C++ environment on Windows XP professional 64bit. And the version of mpich2 is 1.4.1p1( 32bit).
Build, run the program and then wait. Sometimes, I can get an optimum solution when the parallel is done. But mostly, the optimization terminates unexpectedly, and error message follows:
job aborted:
rank: node: exit code[: error message]
0: yang: 123
1: yang: -1073741819: process 1 exited without calling finalize
2: yang: 123
Any advice?
Thanks for your help!
Yang Junbo
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
