[mpich-discuss] mpich2&open64 shared object compilation bug&fix
Evren Yurtesen IB eyurtese at abo.fi
Fri Sep 7 14:52:56 CDT 2012
for bash:
export CC=opencc
export CXX=openCC
export FC=openf95
export F77=openf95
export F95=openf95
(assuming they are on PATH)
mpich2 seems to pick these up nicely.
I am not sure if this specific problem is related to mpich2, I am in
contact with some open64 developers. I will send an update when I have
more information.
On Fri, 7 Sep 2012, Anthony Chan wrote:
> I am not familiar with Open64 compilers, what would you use
> to set CC, CXX, F77 and FC during mpich2 configure ?
>> I tried 1.5rc1 and there seems to be other problems... I have no idea
>> what
>> is this about... configured with: --enable-fast=O2 --enable-shared
>> --enable-mpe --with-pmi=slurm --with-pm=no
>> Just as a side note, same configure options work fine with GCC 4.7.1,
>> but
>> that doesnt say much about who to blame :)
>> Making all in .
>> make[2]: Entering directory `/home/eyurtese/temp/mpich2-1.5rc1'
>> CC src/binding/f90/create_f90_real.lo
>> src/binding/f90/create_f90_real.c: In function
>> 'PMPI_Type_create_f90_real':
>> src/binding/f90/create_f90_real.c:73: error: expected expression
>> before
>> ',' token
>> src/binding/f90/create_f90_real.c:74: warning: braces around scalar
>> initializer
>> src/binding/f90/create_f90_real.c:74: warning: (near initialization
>> for
>> 'f90_real_model[0].dtype')
>> src/binding/f90/create_f90_real.c:74: error: expected expression
>> before
>> ',' token
>> src/binding/f90/create_f90_real.c:74: warning: excess elements in
>> scalar
>> initializer
>> for
>> make[2]: *** [src/binding/f90/create_f90_real.lo] Error 1
>> make[2]: Leaving directory `/home/eyurtese/temp/mpich2-1.5rc1'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/home/eyurtese/temp/mpich2-1.5rc1'
>> make: *** [all] Error 2
>> On Fri, 7 Sep 2012, Evren Yurtesen IB wrote:
>>> On Thu, 6 Sep 2012, Pavan Balaji wrote:
>>>> Your patch below is to configure (not configure.in) which is
>>>> auto-generated. The first step I'd recommend is to try out
>>>> mpich2-1.5rc1.
>>>> That uses libtool for shared library support. That'll at least
>>>> confirm
>>>> whether libtool supports open64 or not. If it doesn't, then a patch
>>>> would
>>>> be required for libtool.
>>> Yes, I realized the configure.in later. My apologies, I am not very
>>> familiar
>>> with the configure system. Please see the attached diffs, what do
>>> you think
>>> about them?
>>> I will check 1.5 next.
>>> Thanks,
>>> Evren
>>>> -- Pavan
>>>> On 09/06/2012 05:47 PM, Evren Yurtesen IB wrote:
>>>>> Hmm, I am not quite sure? the configure.in file contains the
>>>>> information
>>>>> which should be changed?
>>>>> http://trac.mcs.anl.gov/projects/mpich2/browser/mpich2/branches/release/mpich2-1.4.x/configure.in
>>>>>> Hello,
>>>>>> It looks like this patch needs to go into libtool, rather than in
>>>>>> MPICH.
>>>>>> We
>>>>>> can maintain a patch to libtool within mpich (at least till
>>>>>> libtool
>>>>>> upstream
>>>>>> integrates it), if you can provide us with one.
>>>>>> -- Pavan
>>>>>> On 09/06/2012 05:24 PM, Evren Yurtesen IB wrote:
>>>>>>> I was trying to compile mpich2 1.4.1p1 using open64 and oddly it
>>>>>>> kept
>>>>>>> failing with the following configure options...
>>>>>>> --enable-fast=O2 --enable-shared --enable-mpe --with-pmi=slurm
>>>>>>> --with-pm=none
>>>>>>> I have googled this and found the following forum post:
>>>>>>> http://devgurus.amd.com/thread/146210
>>>>>>> Where the exact error message which I was getting was mentioned:
>>>>>>>     make[4]: Entering directory
>>>>>>> `/home2/ach/soft/wrfipkd/mpich2-1.3.1/src/binding/f90'
>>>>>>>      FC mpi.f90
>>>>>>> make[4]: *** [mpi.lo] Error 1
>>>>>>> I have modified the configure script and managed to finish
>>>>>>> installation.
>>>>>>> (diff below). Can this fix be part of mpich2?
>>>>>>> --- configure.orig 2012-09-07 00:45:10.571555205 +0300
>>>>>>> +++ configure 2012-09-07 00:59:28.956554973 +0300
>>>>>>> @@ -16739,6 +16739,10 @@
>>>>>>>         # Try to use the compiler name
>>>>>>>         if test "$FC" = "ifort" -o "$FC" = "ifc" ; then
>>>>>>>             pac_cv_fc_vendor=intel
>>>>>>> + elif test "$FC" = "openf90" ; then
>>>>>>> + pac_cv_fc_vendor=open64
>>>>>>> + elif test "$FC" = "openf95" ; then
>>>>>>>         elif test "$FC" = "pgf90" ; then
>>>>>>>             pac_cv_fc_vendor=pgi
>>>>>>>         elif test "$FC" = "xlf90" -o "$FC" = "xlf90_r" ; then
>>>>>>> @@ -16785,6 +16789,14 @@
>>>>>>>                    fi
>>>>>>> + open64)
>>>>>>> + # open64 implements the GNU options
>>>>>>> + FC_SHL="$FC -shared -fPIC"
>>>>>>> + if test "$enable_rpath" = yes ; then
>>>>>>> + FC_LINKPATH_SHL="-Wl,-rpath -Wl,"
>>>>>>> + fi
>>>>>>>                    pgi)
>>>>>>>                    # Portland Group implements the GNU options
>>>>>>> Thanks,
>>>>>>> Evren
>>>>>>> PS. I created a ticket as well:
>>>>>>> https://trac.mcs.anl.gov/projects/mpich2/ticket/1690
>>>>>>> _______________________________________________
>>>>>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>>>>> To manage subscription options or unsubscribe:
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>>> Pavan Balaji
>>>>>> http://www.mcs.anl.gov/~balaji
>>>> Pavan Balaji
