[mpich-discuss] Problem's whit Ubuntui / Installation???
    Dave Goodell
    goodell at mcs.anl.gov
    Fri Oct 12 10:36:38 CDT 2012
Ignore these test failures.  They are only pointing out performance problems that are unlikely to substantially impact you at this time.
What is your application error?
-Dave
On Oct 12, 2012, at 3:57 AM CDT, Joni-Pekka Kurronen wrote:
> I tried to get mpich2 working whit binaryes but
> could not get soved application depencies nor get it run
> properly. My system inatallation description here:
> http://sites.google.com/site/jpsdatareviewstheboy007/ubuntu-lts-12-4-companion-whit-ltsp-mpich2-elmer-openfoam
> I ended to make sources,... compilation's are ok
> but get both application errors and below error
> from mpich make testing:
> ./perf
> twovec
> No Errors
> Timing failed - recorded times are too small relative to MPI_Wtick
> nestvec
> MPI_Pack time = 2.870560e-04, manual pack time = 1.883507e-05
> MPI_Pack time should be less than 4 times the manual time
> For most informative results, be sure to compile this test with optimization
> Found 1 errors
> nestvec2
> MPI_Pack time using struct with vector = 1.595974e-03, manual pack time = 2.810955e-04
> MPI_Pack using a vector = 3.039837e-04, using a struct with vector = 1.595974e-03
> MPI_Pack time using vector should be about the same as the struct containing the vector
> Found 2 errors
> indexperf
> MPI_Pack (block index) time = 3.480911e-05, manual pack time = 7.152557e-06
> MPI_Pack time should be less than 2 times the manual time
> MPI_Pack (struct of block index)) time = 3.480911e-05, manual pack time = 7.152557e-06
> Found 2 errors
> Joni-Pekka Kurronen
> AMRINA, Insinööri AMK veneala
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
