[mpich-discuss] Problem's whit Ubuntui / Installation???
    Joni-Pekka Kurronen
    joni.kurronen at gmail.com
    Fri Oct 12 03:57:02 CDT 2012
I tried to get mpich2 working whit binaryes but
could not get soved application depencies nor get it run
properly. My system inatallation description here:
http://sites.google.com/site/jpsdatareviewstheboy007/ubuntu-lts-12-4-companion-whit-ltsp-mpich2-elmer-openfoam
I ended to make sources,... compilation's are ok
but get both application errors and below error
from mpich make testing:
./perf
twovec
  No Errors
Timing failed - recorded times are too small relative to MPI_Wtick
nestvec
MPI_Pack time = 2.870560e-04, manual pack time = 1.883507e-05
MPI_Pack time should be less than 4 times the manual time
For most informative results, be sure to compile this test with optimization
  Found 1 errors
nestvec2
MPI_Pack time using struct with vector = 1.595974e-03, manual pack time
= 2.810955e-04
MPI_Pack using a vector = 3.039837e-04, using a struct with vector =
1.595974e-03
MPI_Pack time using vector should be about the same as the struct
containing the vector
  Found 2 errors
indexperf
MPI_Pack (block index) time = 3.480911e-05, manual pack time = 7.152557e-06
MPI_Pack time should be less than 2 times the manual time
MPI_Pack (struct of block index)) time = 3.480911e-05, manual pack time
= 7.152557e-06
  Found 2 errors
Joni-Pekka Kurronen
AMRINA, Insinööri AMK veneala
