[mpich-discuss] MPE Logging on Windows
    Grischa Jacobs
    jacobs at gsc.tu-darmstadt.de
    Thu Oct 11 10:59:53 CDT 2012
Yes I did. c++ 2012 64bit resist..
Regards
Grischa
Am 11.10.12 17:56 schrieb "Jayesh Krishna" unter <jayesh at mcs.anl.gov>:
>Hi,
> Good to know MPICH worked for you. Did you install the Visual Studio
>runtime components to solve your problem?
>Regards,
>Jayesh
>----- Original Message -----
>From: "Grischa Jacobs" <jacobs at gsc.tu-darmstadt.de>
>To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
>Sent: Wednesday, October 10, 2012 12:40:35 PM
>Subject: Re: [mpich-discuss] MPE Logging on Windows
>Hi,
>Yes cpi worked. It's working now. Solution can be found here:
>http://www.rhyous.com/2011/11/01/avoiding-the-msvcr110-dll-or-msvcr110d-dl
>l
>-is-missing-error/
>Regards,
>Grischa
>Am 10.10.12 18:10 schrieb "Jayesh Krishna" unter <jayesh at mcs.anl.gov>:
>>Hi,
>> Are you able to run cpi.exe (C:\Program Files\MPICH2\examples\cpi.exe)
>>on the nodes? How are you launching your MPI job?
>>Regards,
>>Jayesh
>>Cc: mpich-discuss at mcs.anl.gov
>>Sent: Wednesday, October 10, 2012 11:04:38 AM
>>Hi,
>>yes, logging works on my dev machine but not on the nodes. As soon as I
>>run my application on a node I get a fatal crash. Running "hostname" app
>>works.
>>Windows Event Viewer is saying that:
>>Faulting module path: C:\\Windows\system32\mpe.dll
>>I looked with dependency walker for the applications dependencies. But
>>all
>>dll's are in place.
>>Any idea?
>>Regards,
>>Grischa
>>Am 10.10.12 17:56 schrieb "Jayesh Krishna" unter <jayesh at mcs.anl.gov>:
>>>Hi,
>>> Is MPE logging working for you now?
>>>Regards,
>>>Jayesh
>>>To: mpich-discuss at mcs.anl.gov
>>>Sent: Tuesday, October 9, 2012 10:13:05 AM
>>>Forgot to put -log to the options.
>>>Am 09.10.12 15:32 schrieb "Grischa Jacobs" unter
>>><jacobs at gsc.tu-darmstadt.de>:
>>>>Hi,
>>>>I would like to configure MPE automatic logging on Windows 7 x64. In
>>>>VS2012 C++ I linked to mpe.lib and mpi.lib in this order. Unfortunately
>>>>there is no logging file in my working directory after executing.
>>>>Any ideas what the problem might be? Do I need compiler options? I
>>>>tried
>>>>/mpe=mpilog at the linking command line.
>>>>Thanks, Grischa
>>>>_______________________________________________
>>>>mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>>To manage subscription options or unsubscribe:
>>>>https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
