[mpich-discuss] MPE Logging on Windows
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Oct 11 10:56:48 CDT 2012
 Good to know MPICH worked for you. Did you install the Visual Studio runtime components to solve your problem?
Jayesh
----- Original Message -----
From: "Grischa Jacobs" <jacobs at gsc.tu-darmstadt.de>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Wednesday, October 10, 2012 12:40:35 PM
Subject: Re: [mpich-discuss] MPE Logging on Windows
Yes cpi worked. It's working now. Solution can be found here:
http://www.rhyous.com/2011/11/01/avoiding-the-msvcr110-dll-or-msvcr110d-dll
-is-missing-error/
Grischa
Am 10.10.12 18:10 schrieb "Jayesh Krishna" unter <jayesh at mcs.anl.gov>:
>Hi,
> Are you able to run cpi.exe (C:\Program Files\MPICH2\examples\cpi.exe)
>on the nodes? How are you launching your MPI job?
>Regards,
>Jayesh
>Cc: mpich-discuss at mcs.anl.gov
>Sent: Wednesday, October 10, 2012 11:04:38 AM
>Hi,
>yes, logging works on my dev machine but not on the nodes. As soon as I
>run my application on a node I get a fatal crash. Running "hostname" app
>works.
>Windows Event Viewer is saying that:
>Faulting module path: C:\\Windows\system32\mpe.dll
>I looked with dependency walker for the applications dependencies. But all
>dll's are in place.
>Any idea?
>Regards,
>Grischa
>Am 10.10.12 17:56 schrieb "Jayesh Krishna" unter <jayesh at mcs.anl.gov>:
>>Hi,
>> Is MPE logging working for you now?
>>Regards,
>>Jayesh
>>To: mpich-discuss at mcs.anl.gov
>>Sent: Tuesday, October 9, 2012 10:13:05 AM
>>Forgot to put -log to the options.
>>Am 09.10.12 15:32 schrieb "Grischa Jacobs" unter
>><jacobs at gsc.tu-darmstadt.de>:
>>>Hi,
>>>I would like to configure MPE automatic logging on Windows 7 x64. In
>>>VS2012 C++ I linked to mpe.lib and mpi.lib in this order. Unfortunately
>>>there is no logging file in my working directory after executing.
>>>Any ideas what the problem might be? Do I need compiler options? I tried
>>>/mpe=mpilog at the linking command line.
>>>Thanks, Grischa
>>>_______________________________________________
>>>mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>To manage subscription options or unsubscribe:
>>>https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
