[mpich-discuss] Fwd: About using g95 to compile MPICH2 problem
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Oct 1 14:10:39 CDT 2012
Dear Jayesh:
In my program compiler opions
FFLAGS := -fno-second-underscore
But, when I configured MPICH2 just using F77=g95 FC=g95 --prefix=/MPICH2/
So, Should I set FFLAGS=-fno-second-underscore when I configure MPICH2?
Best regards,
Chi-Che Hsieh
2012/10/1 Jayesh Krishna < jayesh at mcs.anl.gov >
You seem to be using specific compiler options (like "-fno-second-underscore") when you are compiling your code. Did you specify the same options when building MPICH2 ?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" < jayesh at mcs.anl.gov >, mpich-discuss at mcs.anl.gov
Sent: Monday, October 1, 2012 8:30:54 AM
Subject: About using g95 to compile MPICH2 problem
Dear MPICH2 users,
I'm sorry if I'm asking too many times.
My case will need using mpi_init, so I install the MPICH2-1.4.1p1
I'm using WindosXP, Cygwin, and g95 to compile.
And I Used the command
User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4.1p1
$./configure F77=g95 FC=g95 --prefix=/MPICH2/ 2>&1 | tee c.txt
$make 2>&1 | tee m.txt
$make install 2>&1 | tee mi.txt
I added right path in cygwin/etc/prfile
MPI_BINDIR=/MPICH2/bin
export MPI_BINDIR
MPI_INCDIR=/MPICH2/include
export MPI_INCDIR
MPI_LIBDIR=/MPICH2/lib
export MPI_LIBDIR
Then, I try to run the examples hellw and cpi
User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4.1p1/examples
$ make hellow
CC hellow.c
../bin/mpicc -o hellow hellow.o
$ mpirun -n 5 ./hellow
Hello world from process 0 of 5
Hello world from process 1 of 5
Hello world from process 2 of 5
Hello world from process 3 of 5
Hello world from process 4 of 5
$ mpirun -n 5 ./cpi
Process 0 of 5 is on 980622-05
Process 1 of 5 is on 980622-05
Process 2 of 5 is on 980622-05
Process 3 of 5 is on 980622-05
Process 4 of 5 is on 980622-05
pi is approximately 3.1415926544231230, Error is 0.0000000008333298
wall clock time = 0.000000
I thought that I finish installing.
And then, I compiled my program, set build.bash
USE_MPI = on
USE_MPIF90 = on
I got some undefined reference about MPI (detail saved in make_sh_mpif90_on_0928.txt)
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build;
/MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math master.f90
mpif90 -fno-second-underscore -O3 -ffast-math
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_coupler.o
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/propagator.o -o
/cygdrive/d/ROMS_for_Square_Harbor/trunk/oceanM.exe
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libNLM.a
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libANA.a
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libICE.a
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libMODS.a -L/usr/local/lib -lnetcdf
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0xe): undefined reference to `mpi_init_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0x34): undefined reference to `mpi_comm_rank_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0x5d): undefined reference to `mpi_finalize_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o:ocean_control.f90:(.text+0x3e6): undefined reference to `mpi_comm_rank_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o:ocean_control.f90:(.text+0x3fd): undefined reference to `mpi_comm_size_'
Can anyone give me some advices to solved this problem?
Best regards,
Chi-Che Hsieh
