[mpich-discuss] MP_EAGER_LIMIT and MP_BUFFER_MEM question
Jeff Hammond
jhammond at alcf.anl.gov
Wed Nov 7 19:31:56 CST 2012
The following program, which is only trivially modified from yours,
works for me up to 1M bytes.
I don't fully understand what you're trying to do but I the program
has an error in it. Because it didn't fail for me, I didn't bother to
look too hard for the errors, but the way you're using character
arrays and the arguments to bcast look somewhat sketchy to me.
I find that MPI programs written in C++ that don't work properly often
work properly when converted to C. You might want to do that in this
case.
Best,
Jeff
#include <iostream>
#include <string>
#include <mpi.h>
void master(void);
void slave(void);
int main(int argc, char* argv[])
int myid, numprocs;
MPI_Init(&argc,&argv);
MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
MPI_Comm_rank(MPI_COMM_WORLD,&myid);
if (myid == 0)
master();
else
slave();
MPI_Finalize();
void master(void)
int myid, numprocs;
std::cout << "I am master on process: " << myid << "\n";
std::cout << "Enter the number of bytes to send: ";
int numbytes;
std::cin >> numbytes;
std::string to_send_str = "";
for (int i=0; i<numbytes; ++i)
to_send_str.append("a");
char* to_send = (char*)(to_send_str.c_str());
int vectorlengths[1] = {0};
vectorlengths[0] = to_send_str.size();
MPI_Bcast(&vectorlengths,1, MPI_INT,0, MPI_COMM_WORLD);
MPI_Bcast(&to_send[0], to_send_str.size(), MPI_CHAR, 0, MPI_COMM_WORLD);
return;
void slave(){
int numrocs;
int rank;
int myid;
MPI_Status status;
std::cout << "I am a slave on process: " << myid << "\n";
MPI_Bcast(&vectorlengths, 1, MPI_INT, 0, MPI_COMM_WORLD);
char sent_chars[vectorlengths[0]];
MPI_Bcast(&sent_chars, vectorlengths[0], MPI_CHAR, 0, MPI_COMM_WORLD);
if (myid == 1)
std::cout << "Sent the following character array: \n"
<< sent_chars << "\n"
<< "which is of size: vectorlengths[0] = " <<
vectorlengths[0] << "\n";
return;
On Wed, Nov 7, 2012 at 7:21 PM, Matthew Niemerg
<niemerg at math.colostate.edu> wrote:
> Jeff,
> Here's a quick mpi program that reproduces the problem. All you do is enter
> in some # of bytes that you want to pass (to test what is the max size of an
> array). The max on my machine is 6000 (i.e. 5999 works, but 6000 doesn't).
> I am not sure why that would be the limit. Anyway, the output on my machine
> indicates the null terminating character isn't sent, or the entire array was
> not able to be passed. Regardless, perplexed by this issue.
> I am, however, able to pass larger arrays (I went up to 8381153)
> successfully, but still get some garbage data at the very end (i.e.,
> outputting the character array to the console is fine, except the last byte
> which outputs as : ??_?).
> FYI, the machine I am using is a Mac 10.6.8, and am using mpich2.1.3 with
> the x86_64 architecture.
> Matt
> On Wed, Nov 7, 2012 at 3:10 PM, Jeff Hammond <jhammond at alcf.anl.gov> wrote:
>> Unless you're on a BGQ or IBM machine with LoadLeveler, I don't see
>> how those variables can have any impact on the execution of your code.
>> cc:mpich2-trunk jhammond$ grep MP_EAGER_LIMIT * -R
>> src/mpid/pamid/src/mpidi_env.c: char* names[] = {"PAMID_EAGER",
>> "PAMID_RZV", "MP_EAGER_LIMIT", "PAMI_RVZ", "PAMI_RZV", "PAMI_EAGER",
>> NULL};
>> src/mpid/pamid/src/mpidi_env.c: char* names[] = {"PAMID_RZV_LOCAL",
>> "PAMID_EAGER_LOCAL", "MP_EAGER_LIMIT_LOCAL", "PAMI_RVZ_LOCAL",
>> "PAMI_RZV_LOCAL", "PAMI_EAGER_LOCAL", NULL};
>> src/mpid/pamid/src/mpidi_util.c:
>> MATCHI(eager_limit,"Message Eager Limit (MP_EAGER_LIMIT/Bytes):");
>> src/pm/hydra/tools/bootstrap/external/ll_env.c:
>> "MP_DEBUG_INITIAL_STOP", "MP_DEBUG_LOG", "MP_EAGER_LIMIT",
>> Can you provide a test code that exercises the problem to which you
>> allude?
>> Thanks,
>> Jeff
>> On Wed, Nov 7, 2012 at 4:53 PM, Matthew Niemerg
>> > Hello,
>> > I'm developing a parallel program and have run into MPI hanging on jobs.
>> > I've narrowed the problem down to broadcasting data to other nodes. I
>> > am
>> > curious how to get a hold of and set the environment variables
>> > MP_EAGER_LIMIT and MP_BUFFER_MEM. We need to be able to adjust our code
>> > based off of individual machine's configurations of MPI, which is why I
>> > need
>> > to get what the environment variables are. I tried to use the
>> > getenv("MP_EAGER_LIMIT") call, but that seemed to fail. In addition,
>> > I've
>> > tried to set these environment variables using the export command in the
>> > shell before running my program, but that doesn't seem to work either.
>> > Are these environment variables set at runtime, during the configuration
>> > of
>> > mpich2, or what? The data that is being passed is about 10 megs, which,
>> > I
>> > wouldn't think would be an issue, but apparently is!
>> > Anyway, any help you can provide would be much appreciative.
>> > Sincerely,
>> > Matthew Niemerg
>> > Graduate Research Assistant
>> > Mathematics Department
>> > Colorado State University
>> > _______________________________________________
>> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> > To manage subscription options or unsubscribe:
>> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Jeff Hammond
>> Argonne Leadership Computing Facility
>> University of Chicago Computation Institute
>> jhammond at alcf.anl.gov / (630) 252-5381
>> http://www.linkedin.com/in/jeffhammond
>> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
Jeff Hammond
