[mpich-discuss] One-sided communication: MPI_Win_lock inside	MPI_Win_fence
    Ziaul Haque Olive
    mzh.olive at gmail.com
    Tue May 29 21:13:28 CDT 2012
Thanks Jim,
I am now thinking of changing my code little bit, so that I can avoid using
lock/unlock. lets see what happens.
-Ziaul
On Tue, May 29, 2012 at 8:59 PM, Jim Dinan <dinan at mcs.anl.gov> wrote:
> Hi Ziaul,
> Your use of lock/unlock sounds correct.  Can you use a barrier instead
> of the fence to be sure that all data has arrived?
>  ~Jim.
> On 05/29/2012 05:33 PM, Ziaul Haque Olive wrote:
> > Hello Jim,
> > I was coalescing data communication. data is collected in a buffer
> > instead of sending. let say, size of this temporary buffer size is N.
> > whenever the buffer is filled up, I need to send all the data from
> > buffer, so that it can be reused in later iterations. but, without any
> > synchronization it is not possible to be sure that the buffer is free to
> > reuse. so I used lock/unlock. moreover, it is required at the start of
> > each iteration that all the data transfer from remote processes to local
> > window has been finished. So the fence is used.
> > the  MPI_MODE_NOSUCCEED  in the first fence was a typo. it is not
> > present in the original code.
> > Thanks,
> > Ziaul
> > On Tue, May 29, 2012 at 5:11 PM, Jim Dinan <dinan at mcs.anl.gov
> > <mailto:dinan at mcs.anl.gov>> wrote:
> >     Hi Ziaul,
> >     MPI_MODE_NOSUCCEED is incorrect in the first call to fence since RMA
> >     operations to succeed this synchronization call.  Hopefully this is
> >     just a typo and you meant MPI_MODE_NOPRECEDE.
> >     In terms of the datatypes, the layout at the origin and target need
> >     not be the same.  However, the basic unit types and the total number
> >     of elements must match for accumulate.
> >     In the example given below, you shouldn't need lock/unlock in
> >     addition to the fences.  Can you refine this a little more to
> >     capture why this is needed in your application?
> >     Best,
> >      ~Jim.
> >     On 5/29/12 4:43 PM, Ziaul Haque Olive wrote:
> >         Hello Rajeev,
> >             yes, there is a reason for my program. the I sent you was a
> >         simplified version. the original one is little bit different.
> >         but this
> >         code sometimes work correctly, sometimes do not.
> >         I have another question, about indexed data type and
> MPI_Accumulate,
> >         if the indexed data-type for target process contains indexes
> like,
> >                2, 5, 3, 1 -> out of order
> >         or
> >               2, 4, 5, 4, 2, 2 - out of order and repetition
> >         or
> >                2, 3, 3, 3, 5 -> in order and repetition
> >         would these be a problem?
> >         Thanks,
> >         Ziaul
> >         On Tue, May 29, 2012 at 4:32 PM, Rajeev Thakur
> >         <thakur at mcs.anl.gov <mailto:thakur at mcs.anl.gov>
> >         <mailto:thakur at mcs.anl.gov <mailto:thakur at mcs.anl.gov>>> wrote:
> >            Nesting of synchronization epochs is not allowed. Is there a
> >         reason
> >            to do it this way?
> >            Rajeev
> >            On May 29, 2012, at 4:28 PM, Ziaul Haque Olive wrote:
> >             > Hello Rajeev,
> >             > The whole code is bit large, and the code is from graph500
> >            benchmark. the bfs_one_sided.c. I am trying to transform it a
> >         bit.
> >            here is a portion of the code,
> >             >       MPI_Win_fence(MPI_MODE___NOSUCCEED, queue2_win);
> >             >       int ii=0,jj,count=1;
> >             >        acc_queue2_win_MPI_BOR_data[__ii] =
> >            masks[VERTEX_LOCAL(w)/elts___per_queue_bit%ulong_bits];
> >             >        acc_queue2_win_MPI_BOR_disp[__ii] =
> >            VERTEX_LOCAL(w)/elts_per___queue_bit/ulong_bits;
> >             >        acc_queue2_win_MPI_BOR_target[__ii] =
> VERTEX_OWNER(w);
> >             >       MPI_Datatype target_type;
> >             >       MPI_Type_indexed( count, blength ,
> >            &acc_queue2_win_MPI_BOR_disp[__ii], MPI_UNSIGNED_LONG,
> >         &target_type);
> >             >       MPI_Type_commit(&target_type);
> >             >       int dest =  acc_queue2_win_MPI_BOR_target[__ii];
> >             >       MPI_Win_lock(MPI_LOCK___EXCLUSIVE, dest, 0,
> >         queue2_win );
> >             >         MPI_Accumulate(&acc_queue2___win_MPI_BOR_data[ii],
> >         count,
> >            MPI_UNSIGNED_LONG, dest, 0, 1,target_type, MPI_BOR,
> queue2_win);
> >             >     MPI_Win_unlock(dest, queue2_win );
> >             >       MPI_Type_free(&target_type);
> >             > Let me know if it works.
> >             > Thanks
> >             > Ziaul
> >             > On Tue, May 29, 2012 at 4:13 PM, Rajeev Thakur
> >             > Can you send the complete program if it is small.
> >             > Rajeev
> >             > On May 29, 2012, at 2:54 PM, Ziaul Haque Olive wrote:
> >             > > for smaller number of processes like 4, i was getting
> >         correct
> >            result, but for 8, it was providing incorrect result.
> >             > > I tried with and without lock/unlock. without lock/unlock
> >            provides correct result all the time.
> >             > > Hello,
> >             > > I am getting incorrect result while using lock/unlock
> >            synchronization inside fence. the pattern is as follows,
> >             > >           MPI_Win_fence(win1);
> >             > >           MPI_Win_lock(exclusive, win1);
> >             > >           MPI_Accumulate(MPI_BOR, win1);
> >             > >           MPI_Win_unlock(win1);
> >             > > is it invalid to use lock in this way?
> >             > > Thanks,
> >             > > Ziaul.
> >             > > _________________________________________________
> >             > > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> >         <mailto:mpich-discuss at mcs.anl.gov>
> >            <mailto:mpich-discuss at mcs.anl.__gov
> >         <mailto:mpich-discuss at mcs.anl.gov>>
> >             > > To manage subscription options or unsubscribe:
> >         https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss
> >         <https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120529/b0e1dd91/attachment-0001.html>
