[mpich-discuss] One-sided communication: MPI_Win_lock inside MPI_Win_fence
    Jim Dinan
    dinan at mcs.anl.gov
    Tue May 29 20:59:33 CDT 2012
Hi Ziaul,
Your use of lock/unlock sounds correct.  Can you use a barrier instead
of the fence to be sure that all data has arrived?
 ~Jim.
On 05/29/2012 05:33 PM, Ziaul Haque Olive wrote:
> Hello Jim,
> I was coalescing data communication. data is collected in a buffer
> instead of sending. let say, size of this temporary buffer size is N.
> whenever the buffer is filled up, I need to send all the data from
> buffer, so that it can be reused in later iterations. but, without any
> synchronization it is not possible to be sure that the buffer is free to
> reuse. so I used lock/unlock. moreover, it is required at the start of
> each iteration that all the data transfer from remote processes to local
> window has been finished. So the fence is used.
> the  MPI_MODE_NOSUCCEED  in the first fence was a typo. it is not
> present in the original code.
> Thanks,
> Ziaul
> On Tue, May 29, 2012 at 5:11 PM, Jim Dinan <dinan at mcs.anl.gov
> <mailto:dinan at mcs.anl.gov>> wrote:
>     Hi Ziaul,
>     MPI_MODE_NOSUCCEED is incorrect in the first call to fence since RMA
>     operations to succeed this synchronization call.  Hopefully this is
>     just a typo and you meant MPI_MODE_NOPRECEDE.
>     In terms of the datatypes, the layout at the origin and target need
>     not be the same.  However, the basic unit types and the total number
>     of elements must match for accumulate.
>     In the example given below, you shouldn't need lock/unlock in
>     addition to the fences.  Can you refine this a little more to
>     capture why this is needed in your application?
>     Best,
>      ~Jim.
>     On 5/29/12 4:43 PM, Ziaul Haque Olive wrote:
>         Hello Rajeev,
>             yes, there is a reason for my program. the I sent you was a
>         simplified version. the original one is little bit different.
>         but this
>         code sometimes work correctly, sometimes do not.
>         I have another question, about indexed data type and MPI_Accumulate,
>         if the indexed data-type for target process contains indexes like,
>                2, 5, 3, 1 -> out of order
>         or
>               2, 4, 5, 4, 2, 2 - out of order and repetition
>         or
>                2, 3, 3, 3, 5 -> in order and repetition
>         would these be a problem?
>         Thanks,
>         Ziaul
>         On Tue, May 29, 2012 at 4:32 PM, Rajeev Thakur
>         <thakur at mcs.anl.gov <mailto:thakur at mcs.anl.gov>
>         <mailto:thakur at mcs.anl.gov <mailto:thakur at mcs.anl.gov>>> wrote:
>            Nesting of synchronization epochs is not allowed. Is there a
>         reason
>            to do it this way?
>            Rajeev
>            On May 29, 2012, at 4:28 PM, Ziaul Haque Olive wrote:
>             > Hello Rajeev,
>             > The whole code is bit large, and the code is from graph500
>            benchmark. the bfs_one_sided.c. I am trying to transform it a
>         bit.
>            here is a portion of the code,
>             >       MPI_Win_fence(MPI_MODE___NOSUCCEED, queue2_win);
>             >       int ii=0,jj,count=1;
>             >        acc_queue2_win_MPI_BOR_data[__ii] =
>            masks[VERTEX_LOCAL(w)/elts___per_queue_bit%ulong_bits];
>             >        acc_queue2_win_MPI_BOR_disp[__ii] =
>            VERTEX_LOCAL(w)/elts_per___queue_bit/ulong_bits;
>             >        acc_queue2_win_MPI_BOR_target[__ii] = VERTEX_OWNER(w);
>             >       MPI_Datatype target_type;
>             >       MPI_Type_indexed( count, blength ,
>            &acc_queue2_win_MPI_BOR_disp[__ii], MPI_UNSIGNED_LONG,
>         &target_type);
>             >       MPI_Type_commit(&target_type);
>             >       int dest =  acc_queue2_win_MPI_BOR_target[__ii];
>             >       MPI_Win_lock(MPI_LOCK___EXCLUSIVE, dest, 0,
>         queue2_win );
>             >         MPI_Accumulate(&acc_queue2___win_MPI_BOR_data[ii],
>         count,
>            MPI_UNSIGNED_LONG, dest, 0, 1,target_type, MPI_BOR, queue2_win);
>             >     MPI_Win_unlock(dest, queue2_win );
>             >       MPI_Type_free(&target_type);
>             > Let me know if it works.
>             > Thanks
>             > Ziaul
>             > On Tue, May 29, 2012 at 4:13 PM, Rajeev Thakur
>             > Can you send the complete program if it is small.
>             > Rajeev
>             > On May 29, 2012, at 2:54 PM, Ziaul Haque Olive wrote:
>             > > for smaller number of processes like 4, i was getting
>         correct
>            result, but for 8, it was providing incorrect result.
>             > > I tried with and without lock/unlock. without lock/unlock
>            provides correct result all the time.
>             > > Hello,
>             > > I am getting incorrect result while using lock/unlock
>            synchronization inside fence. the pattern is as follows,
>             > >           MPI_Win_fence(win1);
>             > >           MPI_Win_lock(exclusive, win1);
>             > >           MPI_Accumulate(MPI_BOR, win1);
>             > >           MPI_Win_unlock(win1);
>             > > is it invalid to use lock in this way?
>             > > Thanks,
>             > > Ziaul.
>             > > _________________________________________________
>             > > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>         <mailto:mpich-discuss at mcs.anl.gov>
>            <mailto:mpich-discuss at mcs.anl.__gov
>         <mailto:mpich-discuss at mcs.anl.gov>>
>             > > To manage subscription options or unsubscribe:
>         https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss
>         <https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
