[mpich-discuss] Problem during running a parallel processing.
Sinta Kartika Maharani sintakm114080010 at gmail.com
Sat May 26 20:59:02 CDT 2012
I'm using the debugger in visual c++. The error was "Unhandled
exception at 0x00f0157e in lastproject.exe: 0x0000094 : integer
division by zero" the code is attached.
The error is in "averow = NRA/numworkers;" whereas I declare the
number of processor when running it with mpiexec.
2012/5/26 Jeff Hammond <jhammond at alcf.anl.gov>:
> You need to include the code if you want helpful responses.  An
> infinite loop of "do you call X?" for all X is not a viable support
> solution.
> Have you run your code through valgrind and gdb to ensure it is not a
> simple bug unrelated to MPI?  Does the program run without error in
> serial?
> Jeff
> On Fri, May 25, 2012 at 12:06 PM, Sinta Kartika Maharani
> <sintakm114080010 at gmail.com> wrote:
>> Yes I do. Do I need to include the codes?
>> 2012/5/25 Ju JiaJia <jujj603 at gmail.com>:
>>> Did you call MPI_Finalize ?
>>> On Fri, May 25, 2012 at 10:00 AM, Sinta Kartika Maharani
>>>> I have some codes, matrix multiplication in MPI. When i run it, appear an
>>>> error,
>>>> job aborted
>>>> rank: node : exit code[: error message]
>>>> 0: sinta-PC: -1073741676: process 0 exited without calling finalize
>>>> why was appear the error?
>>>> _______________________________________________
>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>> To manage subscription options or unsubscribe:
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120527/739ef7d6/attachment-0001.c>
