[mpich-discuss] Problem during running a parallel processing.
    Jeff Hammond
    jhammond at alcf.anl.gov
    Fri May 25 14:57:34 CDT 2012
You need to include the code if you want helpful responses.  An
infinite loop of "do you call X?" for all X is not a viable support
solution.
Have you run your code through valgrind and gdb to ensure it is not a
simple bug unrelated to MPI?  Does the program run without error in
serial?
Jeff
On Fri, May 25, 2012 at 12:06 PM, Sinta Kartika Maharani
<sintakm114080010 at gmail.com> wrote:
> Yes I do. Do I need to include the codes?
> 2012/5/25 Ju JiaJia <jujj603 at gmail.com>:
>> Did you call MPI_Finalize ?
>> On Fri, May 25, 2012 at 10:00 AM, Sinta Kartika Maharani
>>> I have some codes, matrix multiplication in MPI. When i run it, appear an
>>> error,
>>> job aborted
>>> rank: node : exit code[: error message]
>>> 0: sinta-PC: -1073741676: process 0 exited without calling finalize
>>> why was appear the error?
>>> _______________________________________________
>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
