[mpich-discuss] MPICH install Fail on XP HOME SP3
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri May 25 14:09:23 CDT 2012
 Yes that should work.
 After re-install check the status of the process manager, SMPD, by typing "smpd -status" at the command prompt.
-Jayesh
----- Original Message -----
From: "Celestino Abrego" <Celestino.Abrego at parsons.com>
To: jayesh at mcs.anl.gov
Cc: mpich-discuss at mcs.anl.gov
Sent: Friday, May 25, 2012 1:25:05 PM
Subject: Re: [mpich-discuss] MPICH install Fail on XP HOME SP3
No I don't believe I do.  Will the standard uninstall from the control panel suffice?
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Friday, May 25, 2012 01:17 PM
To: Abrego, Celestino
Cc: mpich-discuss at mcs.anl.gov <mpich-discuss at mcs.anl.gov>
>> I typed in "mpiexec -n 2 hostname"
>> And received the same Launch Failed errors.
 Looks like there is some problem with your MPICH2 installation. Can you try uninstalling and reinstalling MPICH2? Do you have any other MPI libraries installed on your system?
-Jayesh
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Friday, May 25, 2012 12:38:31 PM
Subject: RE: [mpich-discuss] MPICH install Fail on XP HOME SP3
I am not sure I understand what you are asking- to run the cpi example, I did not think it was necessary to use hostname on a local system.
Can you tell me exactly what you want me to type in the command prompt?
Celestino Abrego
-----Original Message-----
Sent: Friday, May 25, 2012 12:26 PM
 Shouldn't you be using "mpiexec -n 2 hostname" instead of "mpiexec -n 2 asusnetbook"?
-Jayesh
Sent: Friday, May 25, 2012 12:10:41 PM
Jayesh,
Thanks for the response.  Your questions-
AsusNetBook is the hostname.
Smpd running on AsusNetbook
It also seems that the error messages beyond launch failed: fail I showed in the previous email is not consistently reproducible, so I am not sure how relevant it is.  I reformatted the message a few replies below to make it a bit more clear.
Celestino Abrego
Sent: Friday, May 25, 2012 11:52 AM
 I could not follow some outputs of the commands (What does "mpiexec -n 2 asusnetbook" do?).
 Is SMPD running on your machine (smpd -status)? Can you run "mpiexec -n 2 hostname"?
Jayesh
Sent: Thursday, May 24, 2012 2:36:54 PM
Subject: FW: [mpich-discuss] MPICH install Fail on XP HOME SP3
Jayesh anything I should try? I haven't received any response on the forum from this question below.  Just basic installation problem-I have installed before and got further than this on a different system.
Not sure what else to do here.
Celestino Abrego
Sent: Thursday, May 10, 2012 11:29 AM
To: Jayesh Krishna; mpich-discuss at mcs.anl.gov
(See below) First two fails are with firewall on allowing MPI process manager and process launcher.  Last pair of failures are with firewall off completely.  Initially, my account did not have a password and I could not validate but I figured out that I needed a password.
C:\Program Files\MPICH2\bin>mpiexec -validate SUCCESS
C:\Program Files\MPICH2\bin>mpiexec.exe -n 2 cpi
launch failed: FAIL
launch failed: FAIL
Error posting readv, An established connection was aborted by the software in yo ur host machine.(10053)
C:\Program Files\MPICH2\bin>mpiexec -n 2 asusnetbook; mpiexec -n 2 cpi
launch failed: FAIL
launch failed: FAIL
launch failed: FAIL
launch failed: FAIL
launch failed: FAIL
launch failed: FAIL
Celestino Abrego
Sent: Thursday, May 10, 2012 11:15 AM
Cc: Abrego, Celestino
 Ignore the error message from the mpiexec wrapper (It is a known bug).
 Can you run jobs with mpiexec (mpiexec -n 2 hostname; mpiexec -n 2 C:\Progra~1\MPICH2\examples\cpi.exe)? Did you register a valid Windows username/password with mpiexec (mpiexec -register)? Please provide us with the complete error message.
Jayesh
Sent: Thursday, May 10, 2012 10:29:48 AM
Subject: [mpich-discuss] MPICH install Fail on XP HOME SP3
I am in the process of troubleshooting a problem that I was having with MCNPX program. My idea was that there was a firewall on my primary system preventing MPI to run properly. I am not working on a netbook now with XP home SP3 and I cannot get cpi example to run properly.
I am the only user on this computer, therefore I am the administrator.
I get this message for each process I am trying to run.
“Launch filed: FAIL”
Through some digging I found someone with a similar problems and the board asked for log files. I have attached those, but I am not really sure what to look for. MPICH2 Configuration wrapper indicates an error- “MPICH2 not installed or unable to query host”.
I have tried uninstalling and reinstalling MPICH2 with no changes.
Any ideas?
Celestino Abrego
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
