[mpich-discuss] Include file problem
Anthony Chan
chan at mcs.anl.gov
Thu May 10 01:48:59 CDT 2012
----- Original Message -----
> You are right. I'm trying to insert my own include files.
> mpif90 -show :
> gfortran -I/usr/lib64/mpi/gcc/openmpi/include -pthread
> -I/usr/lib64/mpi/gcc/openmpi/lib64 -L/usr/lib64/mpi/gcc/openmpi/lib64
> -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl
> -Wl,--export-dynamic -lnsl -lutil -lm -ldl
The mpif90 that you are using is not from mpich2. It is openmpi's mpif90
which probably does not read PROFILE_PRELIB and PROFILE_INCPATHS
> The error code is :
> MT2DFEM.f90:17: Error: Can't open included file 'MPI_variables.h'
Is MPI_variables.h in $PROFILE_INCPATHS ?
> Erhan
> On May 9, 2012, at 11:25 PM, Anthony Chan wrote:
> > I assume you are trying to insert your own profiling library ?
> > What is the output of "mpif90 -show" ?
> >> Dear group members,
> >> I have asked before for the mpich2 compiling problems. I have
> >> solved
> >> the problem. I can compile and run the examples on my
> >> multi-processor
> >> server. But I can't compile my parallel program. It was running on
> >> windows with Visual Studio. But now when i compile it on open suse
> >> using mpif90 it gives ' can't find include file *.h ' error. My
> >> include files are in the same directory with the code. How can i
> >> fix
> >> this problem?
> >> I tried
> >> PROFILE_PRELIB="-L/usr/local/myprof/lib -lmyprof"
> >> PROFILE_INCPATHS="-I/usr/local/myprof/include"
> >> but it did not work.
> >> Thank you
> >> Erhan
> >> _______________________________________________
> >> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> >> To manage subscription options or unsubscribe:
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
