[mpich-discuss] Include file problem
Erhan Erdogan
Erhan.Erdogan at ankara.edu.tr
Thu May 10 00:26:43 CDT 2012
You are right. I'm trying to insert my own include files.
mpif90 -show :
gfortran -I/usr/lib64/mpi/gcc/openmpi/include -pthread -I/usr/lib64/mpi/gcc/openmpi/lib64 -L/usr/lib64/mpi/gcc/openmpi/lib64 -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
The error code is :
MT2DFEM.f90:17: Error: Can't open included file 'MPI_variables.h'
Erhan
On May 9, 2012, at 11:25 PM, Anthony Chan wrote:
> I assume you are trying to insert your own profiling library ?
> What is the output of "mpif90 -show" ?
>> Dear group members,
>> I have asked before for the mpich2 compiling problems. I have solved
>> the problem. I can compile and run the examples on my multi-processor
>> server. But I can't compile my parallel program. It was running on
>> windows with Visual Studio. But now when i compile it on open suse
>> using mpif90 it gives ' can't find include file *.h ' error. My
>> include files are in the same directory with the code. How can i fix
>> this problem?
>> I tried
>> PROFILE_PRELIB="-L/usr/local/myprof/lib -lmyprof"
>> PROFILE_INCPATHS="-I/usr/local/myprof/include"
>> but it did not work.
>> Thank you
>> Erhan
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
