[mpich-discuss] Detecting process exit
Steve Krueger Steve.Krueger at sas.com
Sat Mar 31 21:19:55 CDT 2012
I built the 1.4.1p1 MPICH2, then added in hydra-r9660, and everything
works as it should. Thank you for the fix.
sk
> Yes, it does seem to work fine on multiple nodes for me, but I'm using
> trunk not 1.4.1p1.  Can you try downloading the entire mpiexec tarball
> and run your application?
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nig
> htly/hydra/
> You can continue to use your mpicc from the 1.4.1p1 installation.
> If this works for you, we'll know that some other fix that went in after
> 1.4.1p1 was released is required.
>   -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
