[mpich-discuss] Jumpshot to visualize csv files
Anthony Chan
chan at mcs.anl.gov
Sat Mar 10 13:45:04 CST 2012
The simplest route is to merge the cvs files into the ASCII text
file format that slogsdk understands and then converts the text format
to slog2 file and using the convertor, textlogTOslog2, provided by slog2sdk.
The latest documentation for the ASCII text file format can be found here
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpe2/src/slog2sdk/trace_sample/README
Sample ASCII text logfile is here
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpe2/src/slog2sdk/trace_sample/logfiles/data1.txt
There is some recent significant change to these ASCII text format in the respository
that has not made to the mpich2's stable release, 1.4.x. So you may want to check out slog2sdk
and build it yourself.
svn co https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/mpe2/src/slog2sdk <slog2sdk_home>
(cd <slog2sdk && ./autogen.sh)
mkdir <build>
cd <build>
../slog2sdk/configure --disable-source --prefix=<....>
make
make install
A.Chan
----- Original Message -----
> Hello,
> I have a bunch of csv files (one for each parallel processor) which
> contain events in the form of
> name, start time, length
> I would like to try and visualize this with jumpshot. I'm trying to
> figure out how to modify this data to a format that jumpshot will
> understand. Could anyone please point me at documentation of one of
> the formats that jumpshot supports so that I can see if I can convert
> this data to the right format?
> Thanks,
> Justin
> This email message is for the sole use of the intended recipient(s)
> and may contain
> confidential information. Any unauthorized review, use, disclosure or
> distribution
> is prohibited. If you are not the intended recipient, please contact
> the sender by
> reply email and destroy all copies of the original message.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
