[mpich-discuss] MPICH2 test not running properly
Alejandro Allievi
alejandro.allievi at gmail.com
Thu Mar 1 11:58:39 CST 2012
Hi Robert,
Thank you for your reply. I'm not accessing a network, I'm only trying to
run MPI code on my quad core machine. Have some questions regarding your
A) Points (1) and (2) of your file. I did not do the creation of MCNPDATA
and MCNP, I just followed instructions in MPICH2 installer's guide, page 20
(Windows version). However, all example seem to run correctly.
B) Point (7) of your file. I attached a file with "MPICH2 configuration
settings", something does not look right with my computer name "MPICH2 not
installed....". Will that be related to (E) below??
C) Point (9) of your file, I managed to successfully run the example for
cpi.exe. I do not understand what you mean by total CPU = 2/total number of
bars showing in taskbar.
D) When I compile my own HelloWorld MPI code the compile error message is
"Helloworld_MPI.c:20:50: fatal error: mpi.h: No such file or directory". My
path DOES point at MPICH2/bin and MPICH2/include .
E) My Windows Firewall under Control Panel says "The page cannot be loaded"
when I click on "Allow a program or feature to go through a firewall". I do
have Administrator rights.
Thanks again for your help.
Alex
On Thu, Mar 1, 2012 at 1:06 PM, McBroom, Robert C <McBroomRC at oro.doe.gov>wrote:
> Alex****
> There are some tricks involved. The attached file will give you some
> clues. The scheme works for both the 32 bit install and the 64 bit with
> the appropriate source file changes. Note the installation as
> administrator and the use of the command line options on the installer.***
> Robert McBroom****
> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Alejandro Allievi
> *Sent:* Wednesday, February 29, 2012 5:26 PM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* [mpich-discuss] MPICH2 test not running properly****
> Hi. ****
> I'm new to this list and would appreciate some help with this
> beginners issue. I just installed MPICH2 and am running the recommended
> test. The output is as follows. ****
> D:\mpiexec -n 2 cpi.exe
> Error while connecting to host, No connection could be made because the
> target machine actively refused it. (10061)
> Connect on sock (host=ACE-eggnog.wds.mun.ca, port=8676) failed, exhaused
> all end points
> Unable to connect to 'ACE-eggnog.wds.mun.ca:8676',
> sock error: Error = -1
> Has anybody encountered this problem before??****
> Thank you.****
> Alex****
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
*Dr Alejandro Allievi, PhD, PEng*
*"Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre
véritable sentiment n'est pas celui dans lequel nous n'avons jamais
vacillé; mais celui auquel nous sommes le plus habituellement revenus".
Denis Diderot.*
*This email and its attachments are for the sole use of the addressee and
may contain information which is confidential and/or legally privileged.
This email and its attachments are subject to copyright and should not be
partly or wholly reproduced without the consent of the copyright owner. If
you receive this email in error, please immediately delete it from your
system and notify the sender by return email.*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120301/ffc54b2c/attachment-0001.htm>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120301/ffc54b2c/attachment-0001.pdf>
