[mpich-discuss] MPICH2 test not running properly
McBroom, Robert C
McBroomRC at oro.doe.gov
Thu Mar 1 10:36:31 CST 2012
Alex
There are some tricks involved. The attached file will give you some clues. The scheme works for both the 32 bit install and the 64 bit with the appropriate source file changes. Note the installation as administrator and the use of the command line options on the installer.
Robert McBroom
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Alejandro Allievi
Sent: Wednesday, February 29, 2012 5:26 PM
Subject: [mpich-discuss] MPICH2 test not running properly
Hi.
I'm new to this list and would appreciate some help with this beginners issue. I just installed MPICH2 and am running the recommended test. The output is as follows.
D:\mpiexec -n 2 cpi.exe
Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Connect on sock (host=ACE-eggnog.wds.mun.ca<http://ACE-eggnog.wds.mun.ca>, port=8676) failed, exhaused all end points
Unable to connect to 'ACE-eggnog.wds.mun.ca:8676<http://ACE-eggnog.wds.mun.ca:8676>',
sock error: Error = -1
Has anybody encountered this problem before??
Thank you.
Alex
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120301/defd1374/attachment-0001.htm>
Name: Windows 7 PC mpich2 installation.docx
Type: application/vnd.openxmlformats-officedocument.wordprocessingml.document
Desc: Windows 7 PC mpich2 installation.docx
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120301/defd1374/attachment-0001.bin>
