[mpich-discuss] problems with wmpiconfig on Windows Server 2008 SP2
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Jun 29 10:58:26 CDT 2012
These are known bugs with wmpiexec. Unfortunately we don't have enough developer bandwidth to fix these issues right now.
Can you run your job (with Rmpi) from the command prompt?
Jayesh
----- Original Message -----
From: "Timothy Handley" <Timothy_Handley at nps.gov>
Sent: Friday, June 29, 2012 10:20:37 AM
Subject: [mpich-discuss] problems with wmpiconfig on Windows Server 2008 SP2
Hello folks,
I'm having trouble with MPICH2. I've tried a few different things, but have
been unable to resolve the problem. If any of you could help me to figure
this out, I'd greatly appreciate it.
Details:
{All this was done from an administrator account}
) I have an 8-core box running Windows Server 2008 SP2 64-bit
) Yesterday, I downloaded and installed MPICH2 1.4.1p1 from the .msi file
) I ran wmpiregister, and gave it a local account.
) I ran wmpiconfig, but am unable to do much with it. If I click 'scan for
versions', then it reports that MPICH2 1.4.1p1 is installed on this
machine. However, if I click 'Get Settings', then I get an error "MPICH2
not installed or unable to query the host". In the left-hand box, the name
of the host remains black rather than green.
) I ran some tests via the command prompt. It turns out that I can use
mpiexec to run the example cpi program on a specified number of cores:
C:\Program Files\MPICH2>cd examples
C:\Program Files\MPICH2\examples>mpiexec -n 3 cpi
Enter the number of intervals: (0 quits) 100000000000
pi is approximately 3.1415926535897443, Error is 0.0000000000000488
wall clock time = 3.466131
Enter the number of intervals: (0 quits) 0
C:\Program Files\MPICH2\examples>mpiexec -n 6 cpi
pi is approximately 3.1415926535897096, Error is 0.0000000000000835
wall clock time = 1.731985
C:\Program Files\MPICH2\examples>smpd -status
smpd running on INPSAMO-CHUGGA.nps.doi.net
) This is great, and it suggests that MPICH2 is installed correctly. So why
am I having trouble with wmpiconfig?
) I turned off Windows Firewall
) Same deal. I can run mpiexec via command prompt, but wmpiconfig still
cannot get settings. Hostname is black.
) I right-click wmpiconfig, and 'run as Administrator'
) Same deal. wmpiconfig cannot get settings. Hostname is black.
) The goal is to do parallel processing via R and the Rmpi library. Just
for fun, I started R, loaded the Rmpi library, and asked for 2 slaves. This
caused R to hang.
) Right-click on R, 'run as Administrator', load the Rmpi library, and ask
for two slaves. R hangs.
So some parts of this system are working (mpiexec via command prompt) but
some parts are not (wmpiconfig, R/Rmpi). Unfortunately, I don't know where
the problem might be. Any advice would be greatly appreciated,
Tim Handley
Biological Science Technician
Mediterranean Network, NPS
805-658-5759 (CHIS)
805-370-2396 (SAMO)
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
