[mpich-discuss] Questions About using g95 to install MPICH2
    Anthony Chan
    chan at mcs.anl.gov
    Mon Jun 25 06:16:59 CDT 2012
Your first c.txt ends with
checking for md5_calc function... no
configure: error: SMPD requires MD5 support, and configure could not find either md5_calc in md5.h or MD5 in openssl/md5.h
configure: error: src/pm/smpd configure failed
which means your cygwin installation lacks the MD5 support required by the SMPD.
I think you could install MD5 through cygwin's setup.exe though I am not 100% sure.
Your second c.txt ends with
Configuration completed.
which means configure ran successfully
----- Original Message -----
> Thank you, Rajeev Thakur.
> Sorry! I delayed to send this e-mail, because I had some other
> problems.
> Before, I used the command.
> User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4
> $./configure F77=g95 FC=g95 2>&1 | tee c.txt
> The configuration completed, and saved in the file(c.txt).
> How do you know configure step failed? Is the default hydra process
> manager not
> suitable for cygwin?
> And then I had trying to add --with-pm=smpd option, then I got other
> problem.
> Now, I used the command.
> $./configure F77=g95 FC=g95 --with-pm=smpd 2>&1 | tee c.txt
> However, I still got the error.
> find
> 2012/6/13 Rajeev Thakur <thakur at mcs.anl.gov>
> > Your configure step failed. Can you try configuring without the
> > --with-pm=smpd option. That will use the default hydra process
> > manager.
> > Rajeev
> > On Jun 13, 2012, at 1:46 AM, 謝奇哲 wrote:
> > > Hi,
> > > I'm a new user about MPICH2, and using WindosXP, Cygwin and g95.
> > > Then I install MPICH2-1.4 to my computers.
> > > Using the command
> > > $make 2>&1 | tee m.txt
> > > $make install 2>&1 | tee mi.txt
> > > $PATH=/cygdrive/cygwin/usr/local/bin:$PATH ; export PATH
> > > The MPICH2 installed to the default location /usr/local/
> > > And then I got errors message(saved in mtest.test), when I used
> > > command
> > make testing in test file.
> > > But I could run the cpi in examples file.
> > > Can you give me some advices to solve the problem?
> > > Thank you for your help
> > > Best regards,
> > > Chi-Che Hsieh
> > <mtest.txt><c.txt><config.log><m.txt><mi.txt>_______________________________________________
> > > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > > To manage subscription options or unsubscribe:
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
