[mpich-discuss] linking error in moab
Iulian Grindeanu iulian at mcs.anl.gov
Mon Jun 4 18:55:43 CDT 2012
Hello,
I am trying to compile moab on my laptop, ubuntu 12.04, and I am getting this error in make check
link: mpicxx -O0 -g -Wall -pipe -pedantic -Wno-long-long -g -o test_prog_opt test_prog_opt-test_prog_opt.o -L/home/iulian/3rdparty/netcdf-par/lib -L/home/iulian/3rdparty/hdf5-1.8.8-par-gcc/lib -L/home/iulian/lib/parallel/cgmcubit/lib -L/home/iulian/3rdparty/Cubit-12.2/bin ../src/.libs/libMOAB.a /home/iulian/3rdparty/netcdf-par/lib/libnetcdf.so -L/home/iulian/3rdparty/zlib-1.2.4/gcc/lib -L/home/iulian/3rdparty/szip-2.1-gcc/lib /home/iulian/3rdparty/hdf5-1.8.8-par-gcc/lib/libhdf5_hl.so /home/iulian/3rdparty/hdf5-1.8.8-par-gcc/lib/libhdf5.so /home/iulian/3rdparty/szip-2.1-gcc/lib/libsz.so -lz /home/iulian/lib/parallel/cgmcubit/lib/libcgm.so -lcubiti19 /usr/lib/libcr.so -lm -Wl,-rpath -Wl,/home/iulian/3rdparty/netcdf-par/lib -Wl,-rpath -Wl,/home/iulian/3rdparty/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/home/iulian/3rdparty/szip-2.1-gcc/lib -Wl,-rpath -Wl,/home/iulian/lib/parallel/cgmcubit/lib -Wl,-rpath -Wl,/home/iulian/3rdparty/netcdf-par/lib -Wl,-rpath -Wl,/home/iulian/3rdparty/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/home/iulian/3rdparty/szip-2.1-gcc/lib -Wl,-rpath -Wl,/home/iulian/lib/parallel/cgmcubit/lib -Wl,-rpath -Wl,/home/iulian/3rdparty/Cubit-12.2/bin
/usr/lib/libmpich.so: undefined reference to `MPL_trfree'
/usr/lib/libmpich.so: undefined reference to `MPL_env2str'
/usr/lib/libmpich.so: undefined reference to `MPL_trlevel'
/usr/lib/libmpich.so: undefined reference to `MPL_trvalid'
I found online this reference to a similar error .
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-November/008397.html
http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-November/008456.html
I installed mpich2 from the binary installation, using ubuntu software center.(from here, latest stable release: http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)
I also tried compiling myself mpich2 from source, but I get the same linking error. Also, that small example from Jed gives the same error, with both versions (one installed from binary, and one compiled by me)
Any clues how to fix my installation, or what I did wrong? Where should I start looking? The configure.in change that seemed to fix the issues in 1.3.1 is already part of 1.4.1.
Also, it seems that some symbols with those names are part of libmpl.a, on my laptop
.. iulian at T520-iuli:/usr/lib$ nm -C libmpl.a | grep MPL_
0000000000000000 T MPL_strncpy
0000000000000070 T MPL_strsep
0000000000001120 T MPL_TrSetMaxMem
U MPL_strncpy
0000000000000d80 T MPL_trDebugLevel
0000000000000000 t MPL_trIsort
0000000000000d20 T MPL_trSummary
0000000000000d90 T MPL_trcalloc
0000000000000bf0 T MPL_trdump
0000000000000fd0 T MPL_trdumpGrouped
00000000000004f0 T MPL_trfree
0000000000000d50 T MPL_trid
0000000000000100 T MPL_trinit
0000000000000d70 T MPL_trlevel
0000000000000930 T MPL_trmalloc
0000000000000de0 T MPL_trrealloc
0000000000000bd0 T MPL_trspace
0000000000000f60 T MPL_trstrdup
00000000000002b0 T MPL_trvalid
0000000000000260 T MPL_env2bool
0000000000000130 T MPL_env2int
0000000000000000 T MPL_env2range
00000000000003d0 T MPL_env2str
00000000000003f0 T MPL_putenv
Iulian
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120604/d0829459/attachment.html>
