[mpich-discuss] LNK2019 error on Windows 7 and Visual Studio 2008 using MPI
Jayesh Krishna jayesh at mcs.anl.gov
Thu Jul 26 10:03:25 CDT 2012
 Are you linking your application with the correct libraries? If you have installed 64-bit version of MPICH2 make sure that you are building a 64-bit application (to link with the libs).
Jayesh
----- Original Message -----
From: "Darcy Allison" <plasma.simulation at gmail.com>
Sent: Wednesday, July 25, 2012 3:55:05 PM
Subject: Re: [mpich-discuss] LNK2019 error on Windows 7 and Visual Studio 2008 using MPI
Thanks for the suggestion but I still get the same five errors which are:
1>Linking...
1>main.obj : error LNK2019: unresolved external symbol _MPI_Finalize referenced in function _main
1>main.obj : error LNK2019: unresolved external symbol _MPI_Comm_rank referenced in function _main
1>main.obj : error LNK2019: unresolved external symbol _MPI_Comm_size referenced in function _main
1>main.obj : error LNK2019: unresolved external symbol _MPI_Init referenced in function _main
1>Y:\ModelCenter_LinkingCodes\zonair_mpi\Debug\zonair_mpi.exe : fatal error LNK1120: 4 unresolved externals
On 7/25/2012 4:42 PM, Scott Hill wrote:
Try adding cxx.lib in the Additional Dependencies where you added mpi.lib.
On Jul 25, 2012, at 12:43 PM, Darcy Allison wrote:
Finally, I go to Project->Properties->Configuration Properties->Linker->Input->Additional Dependencies. I then put mpi.lib into the box.
mpich-discuss mailing list mpich-discuss at mcs.anl.gov To manage subscription options or unsubscribe: https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
