[mpich-discuss] some questions about MPI
Jayesh Krishna jayesh at mcs.anl.gov
Thu Jul 26 09:57:54 CDT 2012
>> 1/ I wanted to configure a MFC project ...
 It would be difficult to guess the source of your problem. One thing I can recommend is performing a diff on the VS proj files.
>> 2/ Since MPI_Publish_Name doesn't work across applications...
 You can manually write the port name to a file (and read it from other MPI processes).
 Are you referring to MPICH_PORT_RANGE? MPICH_PORT_RANGE specifies the range of ports to be used by the MPICH library (Try specifying a bigger range, say with 10 port numbers).
>> 3/ I have to launch my application in a remote node...
 Do you have the same username (with the same password) on all the machines/nodes? MPICH uses the same registered username/password to launch processes on all the nodes.
Jayesh
----- Original Message -----
Sent: Wednesday, July 25, 2012 11:22:41 AM
Subject: [mpich-discuss] some questions about MPI
I am working on windows 7 using mpich2-1.4.1-p1. during that, I encountered some problems, which are:
1/ I wanted to configure a MFC project with MPI using the usual configuration but during the compilation some errors appeared like:"'CDialogEx' : base class undefined
c:\users\toufik\documents\visual studio 2010\projects\mfcapp\mfcapp\mfcappdlg.h" which didn't appear before the configuration. I don't know if there is some extra
options to adjust or it follows another method of configuration.
2/ Since MPI_Publish_Name doesn't work across applications, I want that MPI_Open_port opens a predetermined port (not some random port), when I digged a little, I found
that there is an environment variable MPI_PORT_RANGE whom could do it, when i tried it (mpiexec -env MPI_PORT_RANGE 1000..1000), nothing happened.
3/ I have to launch my application in a remote node but that didn't work giving me the error message: "unable to connect to otherNode". what could be the problem,
knowing that, all firewalls are off and all nodes have the same version of windows 7 and of mpich2.
so, could anyone give some tips to help me with these questions? and thanks.
Toufik.
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
