[mpich-discuss] Memory leaks using ROMIO
Akram Smaali
akram.smaali at gmail.com
Thu Jul 12 06:29:38 CDT 2012
Hello,
i'm using mpich2 in a C program that reads several buffers from a data text
files.
I noticed that even when i free the buffer at the end, the global memory
usage still increase but the memory usage per process still the same.
I changed the MPI_File_read_at() with fseek/fread and the problem has
dissapeared.
I'm wondering if that i should do some extra instriuctions to avoid that
because it seems that mpi_read allocate an intermediate buffer for reading
(sieving optimization maybe) from the user space memory and the OS (
windosws 7) don't get it back.
i'm using MPICH2 1.4 on w windows 7 with NTFS file system.
Thank you for your help.
here is my code :
#include <stdio.h>
#include <stdlib.h>
#include <mpi.h>
#include <omp.h>
#include <string.h>
#include <time.h>
#include "queue.h"
#include "KhiopsNativeInterface.h"
#include <windows.h>
#define maxLength 100000
double CPUtime(){ return ((double) clock())/CLOCKS_PER_SEC;}
int main(int argc, char* argv []){
if(argc != 5) {
printf("\t[Dictionary file] [Dictionary] [Input file] [Buffer size]\n");
exit(0);
char* sDictionaryFileName = argv[1];
char* sDictionaryName = argv[2];
char* filename = argv[3];
int Mbuffer = atoi(argv[4]);
int maxBuffer = Mbuffer*1024*1024;
int over = 10000;
int rank,numprocess;
long int offset;
char* buffer;
char* opbuffer;
double tstart=CPUtime();
MPI_Init( &argc, &argv );
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
/* mpi version */
/* open the file*/
MPI_File fh;
int err;
err = MPI_File_open(MPI_COMM_WORLD, filename, MPI_MODE_RDONLY,
MPI_INFO_NULL, &fh);
if (err != MPI_SUCCESS) {
char errstr[MPI_MAX_ERROR_STRING];
int errlen;
MPI_Error_string(err, errstr, &errlen);
printf("Error at opening file %s (%s)\n",filename,errstr);
MPI_Finalize();
exit(1);
// get offsets and buffer size
MPI_Offset sfile;
MPI_File_get_size(fh,&sfile);
MPI_Status status;
/* C version */
/*FILE* fh;
long int sfile;
fh =fopen( filename,"rb");
if (fh==NULL) {
printf("Error at opening file %s\n",filename);
exit(1);
fseek(fh, 0L, SEEK_END);
sfile = ftell(fh);
fseek(fh, 0L, SEEK_SET);*/
MPI_Comm_size( MPI_COMM_WORLD, &numprocess );
/* number of iterations */
long int data_size = (long int)(sfile/(numprocess));
int nbIter = data_size/maxBuffer;
if(nbIter<=1){
nbIter = 1;
maxBuffer = data_size;
/* offsets */
offset = data_size*(rank);
long int cursor = offset;
char* header;
if(rank==0){
FILE* fh;
if (fh==NULL) {
exit(1);
/* read the header and broadcast it */
header = malloc(sizeof(char)*1000);
fgets(header,1000,fh);
fclose(fh);
//broadcast header
int sndHeader = strlen(header);
//cursor+=sndHeader;
int process_counter;
for(process_counter=1;process_counter<numprocess;process_counter++){
int ierr = MPI_Send(&sndHeader,sizeof(int), MPI_INT, process_counter,
42,MPI_COMM_WORLD);
if (ierr != MPI_SUCCESS) {
int errclass,resultlen;
char err_buffer[MPI_MAX_ERROR_STRING];
MPI_Error_class(ierr,&errclass);
if (errclass== MPI_ERR_RANK) {
fprintf(stderr,"Invalid rank used in MPI send call\n");
MPI_Error_string(ierr,err_buffer,&resultlen);
fprintf(stderr,err_buffer);
MPI_Finalize();
MPI_Send(header, sndHeader, MPI_CHAR, process_counter, 43, MPI_COMM_WORLD);
else{
/* receive the header */
int sizeofHeader;
MPI_Status s ;
MPI_Recv(&sizeofHeader,sizeof(int),MPI_INT,0,42,MPI_COMM_WORLD,&s);
header = malloc (sizeof(char)*sizeofHeader+1);
MPI_Recv(header,sizeofHeader,MPI_CHAR,0,43,MPI_COMM_WORLD,&s);
/* Synchronization barrier */
MPI_Barrier(MPI_COMM_WORLD);
int count;
opbuffer = malloc(sizeof(char)*maxBuffer);
/* C version */
//fseek(fh,cursor,SEEK_SET);
for(count=0;count<nbIter;count++){
if(count==0 && rank==numprocess-1){ //init ring
//send the token to p0
int token=1;
MPI_Send(&token,sizeof(int),MPI_INT,0,55,MPI_COMM_WORLD);
//recv
int token;
int sender;
if(rank==0)
sender = numprocess-1;
else
sender=rank-1;
MPI_Status s;
MPI_Recv(&token,sizeof(int),MPI_INT,sender,55,MPI_COMM_WORLD,&s);
fflush(stdout);printf("P%d got the token at %G\n",rank,CPUtime());
//read
double start=CPUtime();
/*double readtime;
double sread=CPUtime();//read time*/
//read
if(token==1){
/* MPI version */
int err=MPI_File_read_at(fh, cursor,opbuffer, sizeof(char)*maxBuffer,
MPI_CHAR, &status);
if(err!=MPI_SUCCESS){
int errlen;
printf("Error reading file %s (%s)\n",filename,errstr);
MPI_Finalize();
exit(0);
/* C version of read */
/*int k=fread(opbuffer,sizeof(char),maxBuffer,fh);
if(k==0)
perror("fread");*/
cursor+=maxBuffer;
buffer=opbuffer;
else{
printf("Error token!\n");
token=1;
//printf("P%d readtime=%G\n",rank,CPUtime()-sread);
//Isend
int next = (rank+1)%numprocess;
MPI_Send(&token,sizeof(int),MPI_INT,next,55,MPI_COMM_WORLD);
//i perform processing buffer here!
free(opbuffer);
/* mpi version */
int er=MPI_File_close(&fh);
if(er!=MPI_SUCCESS){
printf("Error closing file\n");
MPI_Finalize();
exit(1);
/* c version */
//fclose(fh);
MPI_Finalize();
printf("Global time : %G\n",CPUtime()-tstart);
return 0;
Best Regards
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120712/f5fb5ccb/attachment-0001.html>
