[mpich-discuss] Configure error 77
Pavan Balaji balaji at mcs.anl.gov
Tue Jul 10 09:23:27 CDT 2012
[please keep mpich-discuss cc'ed]
The CFLAGS are causing your C compiler to fail.  This is not an MPICH
problem.  Try compiling a simple C program with these CFLAGS.
  -- Pavan
On 07/10/2012 09:19 AM, BAKER, MYLES D. (LARC-E302) wrote:
> Pavan,
> Those are the default flags that are used to compile C programs in the
> software project that I work on. I don't do very much C development and
> the code that I am developing is not in C, but I would like to refrain
> from changing those setting if I can. Why is CFLAGS causing this to fail?
> Thanks,
> Myles
> *BAKER, MYLES D. (LARC-E302)*
> *Mail Stop 420, B1250 R177
> myles.d.baker at nasa.gov <mailto:myles.d.baker at nasa.gov>
> LaRC Ext:  x46393
> On Jul 10, 2012, at 10:11 AM, Pavan Balaji wrote:
>> It looks like you have CFLAGS and other variables set in your
>> environment.  Is that intentional?  If not, try unsetting them.
>>  -- Pavan
>> On 07/10/2012 09:06 AM, BAKER, MYLES D. (LARC-E302) wrote:
>>> Dear all,
>>> I am installing mpich2-1.4.1p1 locally on a cluster that I do not have
>>> root permissions. I am following along with the v1.4.1 installer's guide
>>> and the guidelines posted here:
>>> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2012-July/012752.html
>>> After decompressing the file I try to configure the installation
>>> pointing to the installation directory (tcsh):
>>>> cd $HOME/mpi/mpich2-1.4.1p1
>>>> ./configure --prefix=$HOME/mpi/mpich2-1.4.1p1 --enable-shared
>>> but the configuration fails with the following errors:
>>> Configuring MPICH2 version 1.4.1p1 with
>>>  '--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
>>> 'CC=/usr/local/bin/gcc' 'CFLAGS=-c -m64 -mcpu=power6 -DLINUX -D_LP64'
>>> 'CPP=/usr/local/bin/g++' 'F77=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'
>>> 'FFLAGS=-O2 -c -qextname -q64 -qwarn64'
>>> Running on system: Linux tisa2-blue 2.6.16.60-0.42.9-ppc64 #1 SMP Thu
>>> Jan 28 23:39:37 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
>>> checking for C compiler default output file name...
>>> configure: error: in `/homedir/mdbaker2/mpi/mpich2-1.4.1p1':
>>> configure: error: C compiler cannot create executables
>>> See `config.log' for more details.
>>> Most of my development will be done in Fortran so I need the F77 and F90
>>> bindings, and my gcc, g++, and gfortran compilers are located in
>>> /usr/bin. However, I use the IBM XLF compiler so my F77 and F90 env
>>> variables point to another location, which the configuration executable
>>> seems to find just fine (the locations match up to my env file).
>>> In the core tests I see that the error seems to come from my CFLAGS
>>> variable. Does this correct? Can anyone give me some direction? I have
>>> attached the full configuration file below.
>>> Thanks,
>>> Myles
>>> Here is the full config.log file:
>>> This file contains any messages produced by compilers while
>>> running configure, to aid debugging if configure makes a mistake.
>>> It was created by configure, which was
>>> generated by GNU Autoconf 2.63.  Invocation command line was
>>>   $ ./configure --prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1
>>> ## Platform. ##
>>> hostname = tisa2-blue
>>> uname -m = ppc64
>>> uname -r = 2.6.16.60-0.42.9-ppc64
>>> uname -s = Linux
>>> uname -v = #1 SMP Thu Jan 28 23:39:37 UTC 2010
>>> /usr/bin/uname -p = unknown
>>> /bin/uname -X     = unknown
>>> /bin/arch              = ppc64
>>> /usr/bin/arch -k       = unknown
>>> /usr/convex/getsysinfo = unknown
>>> /usr/bin/hostinfo      = unknown
>>> /bin/machine           = unknown
>>> /usr/bin/oslevel       = unknown
>>> /bin/universe          = unknown
>>> PATH: /SPG_ops/utils/univa/bin/lx-ppc64
>>> PATH: /SPG_ops/utils/ppc64/FileZilla/FileZilla-3.1.0.1/bin
>>> PATH: /usr/bin
>>> PATH: /bin
>>> PATH: /usr/sbin
>>> PATH: /sbin
>>> PATH: /usr/games
>>> PATH: /opt/gnome/bin
>>> PATH: /usr/bin/X11
>>> PATH: /usr/lib/mit/bin
>>> PATH: /usr/lib/mit/sbin
>>> PATH:
>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/bin/linux
>>> PATH:
>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/hdf/linux64/HDF4.2r4/bin
>>> PATH:
>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/zlib/linux64/zlib-1.2.3/zlib/bin
>>> PATH:
>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/jpeg/linux64/jpeg-6b/bin
>>> PATH:
>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/hdf5/linux64/hdf5-1.8.3/bin
>>> PATH:
>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/szip/linux64/szip-2.1/szip/bin
>>> PATH: /usr/local/bin
>>> PATH: /etc
>>> PATH: /usr/etc
>>> PATH: /usr/X11/bin
>>> PATH: /usr/local/bin/
>>> PATH: /usr/sbin/
>>> PATH: /usr/local/R/bin/
>>> PATH: /homedir/mdbaker2/bin
>>> ## Core tests. ##
>>> configure:3182: checking for C compiler version
>>> configure:3190: /usr/local/bin/gcc --version >&5
>>> gcc (GCC) 4.2.2
>>> Copyright (C) 2007 Free Software Foundation, Inc.
>>> This is free software; see the source for copying conditions.  There
>>> is NO
>>> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
>>> PURPOSE.
>>> configure:3194: $? = 0
>>> configure:3201: /usr/local/bin/gcc -v >&5
>>> Using built-in specs.
>>> Target: powerpc64-linux
>>> Configured with: ../configure --prefix=/SPG_ops/utils/ppc64
>>> --build=powerpc64-linux --host=powerpc64-linux --target=powerpc64-linux
>>> --with-cpu=default64 --with-as=/usr/bin/as --with-ld=/usr/bin/ld
>>> --enable-threads=posix --enable-shared --enable-__cxa_atexit
>>> --enable-checking --with-mpfr=/SPG_ops/utils/ppc64
>>> --enable-languages=c,c++
>>> Thread model: posix
>>> gcc version 4.2.2
>>> configure:3205: $? = 0
>>> configure:3212: /usr/local/bin/gcc -V >&5
>>> gcc: '-V' option must have argument
>>> configure:3216: $? = 1
>>> configure:3239: checking for C compiler default output file name
>>> configure:3261: /usr/local/bin/gcc -c -m64 -mcpu=power6 -DLINUX -D_LP64
>>>      conftest.c   >&5
>>> configure:3265: $? = 0
>>> configure:3303: result:
>>> configure: failed program was:
>>> | /* confdefs.h.  */
>>> | #define PACKAGE_NAME ""
>>> | #define PACKAGE_TARNAME ""
>>> | #define PACKAGE_VERSION ""
>>> | #define PACKAGE_STRING ""
>>> | #define PACKAGE_BUGREPORT ""
>>> | #define USE_SMP_COLLECTIVES 1
>>> | /* end confdefs.h.  */
>>> | int
>>> | main ()
>>> |   return 0;
>>> configure:3309: error: in `/homedir/mdbaker2/mpi/mpich2-1.4.1p1':
>>> configure:3312: error: C compiler cannot create executables
>>> ## Cache variables. ##
>>> ac_cv_env_AR_FLAGS_set=
>>> ac_cv_env_AR_FLAGS_value=
>>> ac_cv_env_CCC_set=
>>> ac_cv_env_CCC_value=
>>> ac_cv_env_CC_set=set
>>> ac_cv_env_CC_value=/usr/local/bin/gcc
>>> ac_cv_env_CFLAGS_set=set
>>> ac_cv_env_CFLAGS_value='-c -m64 -mcpu=power6 -DLINUX -D_LP64'
>>> ac_cv_env_CPPFLAGS_set=
>>> ac_cv_env_CPPFLAGS_value=
>>> ac_cv_env_CPP_set=set
>>> ac_cv_env_CPP_value=/usr/local/bin/g++
>>> ac_cv_env_CXXCPP_set=
>>> ac_cv_env_CXXCPP_value=
>>> ac_cv_env_CXXFLAGS_set=
>>> ac_cv_env_CXXFLAGS_value=
>>> ac_cv_env_CXX_set=
>>> ac_cv_env_CXX_value=
>>> ac_cv_env_F77_set=set
>>> ac_cv_env_F77_value=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77
>>> ac_cv_env_FCFLAGS_set=
>>> ac_cv_env_FCFLAGS_value=
>>> ac_cv_env_FC_set=
>>> ac_cv_env_FC_value=
>>> ac_cv_env_FFLAGS_set=set
>>> ac_cv_env_FFLAGS_value='-O2 -c -qextname -q64 -qwarn64'
>>> ac_cv_env_FROM_MPICH2_set=
>>> ac_cv_env_FROM_MPICH2_value=
>>> ac_cv_env_LDFLAGS_set=
>>> ac_cv_env_LDFLAGS_value=
>>> ac_cv_env_LIBS_set=
>>> ac_cv_env_LIBS_value=
>>> ac_cv_env_MPICH2LIB_CFLAGS_set=
>>> ac_cv_env_MPICH2LIB_CFLAGS_value=
>>> ac_cv_env_MPICH2LIB_CPPFLAGS_set=
>>> ac_cv_env_MPICH2LIB_CPPFLAGS_value=
>>> ac_cv_env_MPICH2LIB_CXXFLAGS_set=
>>> ac_cv_env_MPICH2LIB_CXXFLAGS_value=
>>> ac_cv_env_MPICH2LIB_FCFLAGS_set=
>>> ac_cv_env_MPICH2LIB_FCFLAGS_value=
>>> ac_cv_env_MPICH2LIB_FFLAGS_set=
>>> ac_cv_env_MPICH2LIB_FFLAGS_value=
>>> ac_cv_env_MPICH2LIB_LDFLAGS_set=
>>> ac_cv_env_MPICH2LIB_LDFLAGS_value=
>>> ac_cv_env_MPICH2LIB_LIBS_set=
>>> ac_cv_env_MPICH2LIB_LIBS_value=
>>> ac_cv_env_build_alias_set=
>>> ac_cv_env_build_alias_value=
>>> ac_cv_env_host_alias_set=
>>> ac_cv_env_host_alias_value=
>>> ac_cv_env_target_alias_set=
>>> ac_cv_env_target_alias_value=
>>> pac_cv_my_conf_dir=/homedir/mdbaker2/mpi/mpich2-1.4.1p1
>>> ## Output variables. ##
>>> ABIVERSION='3:3'
>>> ADDRESS_KIND=''
>>> ALLOCA=''
>>> AR=''
>>> AR_FLAGS=''
>>> BASH_SHELL=''
>>> BSEND_OVERHEAD=''
>>> BUILD_BASH_SCRIPTS=''
>>> BUILD_DLLS=''
>>> BUILD_TVDLL=''
>>> CC='/usr/local/bin/gcc'
>>> CC_SHL=''
>>> CC_SHL_DBG=''
>>> CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64 '
>>> CMB_1INT_ALIGNMENT=''
>>> CMB_STATUS_ALIGNMENT=''
>>> CONFIGURE_ARGS_CLEAN='--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
>>> CONFIGURE_ARGUMENTS='
>>> '\''--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'\''
>>> '\''CC=/usr/local/bin/gcc'\'' '\''CFLAGS=-c -m64 -mcpu=power6 -DLINUX
>>> -D_LP64'\'' '\''CPP=/usr/local/bin/g++'\''
>>> '\''F77=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'\'' '\''FFLAGS=-O2 -c
>>> -qextname -q64 -qwarn64'\'''
>>> CPP='/usr/local/bin/g++'
>>> CPPFLAGS=' '
>>> CREATESHLIB=''
>>> CXX=''
>>> CXXCPP=''
>>> CXXFLAGS=' '
>>> CXX_DEFS=''
>>> CXX_LINKPATH_SHL=''
>>> CXX_SHL=''
>>> C_LINKPATH_SHL=''
>>> C_LINK_SHL=''
>>> C_LINK_SHL_DBG=''
>>> DBG_SHLIB_TYPE=''
>>> DEFS=''
>>> DEVICE=''
>>> DEVICE_ARGS=''
>>> DEVICE_NAME=''
>>> DLLIMPORT=''
>>> DOCTEXT=''
>>> DOCTEXTSTYLE=''
>>> ECHO_C=''
>>> ECHO_N='-n'
>>> ECHO_T=''
>>> EGREP=''
>>> ENABLE_SHLIB=''
>>> EXEEXT=''
>>> EXTERNAL_SRC_DIRS=''
>>> EXTRA_STATUS_DECL=''
>>> F77='/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'
>>> F77CPP=''
>>> F77_COMPLEX16=''
>>> F77_COMPLEX32=''
>>> F77_COMPLEX8=''
>>> F77_INCDIR=''
>>> F77_INTEGER16=''
>>> F77_INTEGER1=''
>>> F77_INTEGER2=''
>>> F77_INTEGER4=''
>>> F77_INTEGER8=''
>>> F77_LIBDIR_LEADER=''
>>> F77_LINKPATH_SHL=''
>>> F77_NAME_MANGLE=''
>>> F77_OTHER_LIBS=''
>>> F77_REAL16=''
>>> F77_REAL4=''
>>> F77_REAL8=''
>>> F77_SHL=''
>>> FC=''
>>> FCCPP=''
>>> FCEXT=''
>>> FCFLAGS=' '
>>> FCINC=''
>>> FCINCFLAG=''
>>> FCMODEXT=''
>>> FCMODINCFLAG=''
>>> FCMODINCSPEC=''
>>> FC_LINKPATH_SHL=''
>>> FC_OTHER_LIBS=''
>>> FC_SHL=''
>>> FC_WORK_FILES_ARG=''
>>> FFLAGS='-O2 -c -qextname -q64 -qwarn64 '
>>> FGREP=''
>>> FILE=''
>>> FINCLUDES=''
>>> FLIBS=''
>>> FORTRAN_BINDING=''
>>> FORTRAN_MPI_OFFSET=''
>>> FROM_MPICH2='yes'
>>> FWRAPNAME='fmpich'
>>> GCC=''
>>> GNUCXX_MINORVERSION=''
>>> GNUCXX_VERSION=''
>>> GREP=''
>>> HAVE_CXX_EXCEPTIONS=''
>>> HAVE_ROMIO=''
>>> INCLUDE_MPICXX_H=''
>>> INCLUDE_MPIDDEFS_H=''
>>> INSTALL_DATA=''
>>> INSTALL_PROGRAM=''
>>> INSTALL_SCRIPT=''
>>> KILLALL=''
>>> LDFLAGS=' '
>>> LDFLAGS_DEPS=''
>>> LIBOBJS=''
>>> LIBS=' '
>>> LIBTOOL=''
>>> LIB_DEPS=''
>>> LTLIBOBJS=''
>>> MAKE=''
>>> MAKE_DEPEND_C=''
>>> MANY_PM=''
>>> MKDIR_P=''
>>> MPIBASEMODNAME=''
>>> MPICC=''
>>> MPICH2LIB_CFLAGS=''
>>> MPICH2LIB_CPPFLAGS=''
>>> MPICH2LIB_CXXFLAGS=''
>>> MPICH2LIB_FCFLAGS=''
>>> MPICH2LIB_FFLAGS=''
>>> MPICH2LIB_LDFLAGS=''
>>> MPICH2LIB_LIBS=''
>>> MPICH2_NUMVERSION='10401301'
>>> MPICH2_RELEASE_DATE='Thu Sep  1 13:53:02 CDT 2011'
>>> MPICH2_VERSION='1.4.1p1'
>>> MPICH_TIMER_KIND=''
>>> MPICONSTMODNAME=''
>>> MPICXX=''
>>> MPICXXLIBNAME=''
>>> MPID_TIMER_TYPE=''
>>> MPIF77=''
>>> MPIFC=''
>>> MPIFLIBNAME=''
>>> MPIFPMPI=''
>>> MPILIBNAME=''
>>> MPIMODNAME=''
>>> MPIR_CXX_BOOL=''
>>> MPIR_CXX_COMPLEX=''
>>> MPIR_CXX_DOUBLE_COMPLEX=''
>>> MPIR_CXX_LONG_DOUBLE_COMPLEX=''
>>> MPISIZEOFMODNAME=''
>>> MPIU_DLL_SPEC_DEF=''
>>> MPIU_THREAD_LIB_NAME=''
>>> MPI_2COMPLEX=''
>>> MPI_2DOUBLE_COMPLEX=''
>>> MPI_2DOUBLE_PRECISION=''
>>> MPI_2INT=''
>>> MPI_2INTEGER=''
>>> MPI_2REAL=''
>>> MPI_AINT=''
>>> MPI_AINT_DATATYPE=''
>>> MPI_AINT_FMT_DEC_SPEC=''
>>> MPI_AINT_FMT_HEX_SPEC=''
>>> MPI_BYTE=''
>>> MPI_CHAR=''
>>> MPI_CHARACTER=''
>>> MPI_COMPLEX16=''
>>> MPI_COMPLEX32=''
>>> MPI_COMPLEX8=''
>>> MPI_COMPLEX=''
>>> MPI_C_BOOL=''
>>> MPI_C_DOUBLE_COMPLEX=''
>>> MPI_C_FLOAT_COMPLEX=''
>>> MPI_C_LONG_DOUBLE_COMPLEX=''
>>> MPI_DOUBLE=''
>>> MPI_DOUBLE_COMPLEX=''
>>> MPI_DOUBLE_INT=''
>>> MPI_DOUBLE_PRECISION=''
>>> MPI_F77_2INT=''
>>> MPI_F77_AINT=''
>>> MPI_F77_BYTE=''
>>> MPI_F77_CHAR=''
>>> MPI_F77_C_BOOL=''
>>> MPI_F77_C_COMPLEX=''
>>> MPI_F77_C_DOUBLE_COMPLEX=''
>>> MPI_F77_C_FLOAT_COMPLEX=''
>>> MPI_F77_C_LONG_DOUBLE_COMPLEX=''
>>> MPI_F77_DOUBLE=''
>>> MPI_F77_DOUBLE_INT=''
>>> MPI_F77_FLOAT=''
>>> MPI_F77_FLOAT_INT=''
>>> MPI_F77_INT16_T=''
>>> MPI_F77_INT32_T=''
>>> MPI_F77_INT64_T=''
>>> MPI_F77_INT8_T=''
>>> MPI_F77_INT=''
>>> MPI_F77_LB=''
>>> MPI_F77_LONG=''
>>> MPI_F77_LONG_DOUBLE=''
>>> MPI_F77_LONG_DOUBLE_INT=''
>>> MPI_F77_LONG_INT=''
>>> MPI_F77_LONG_LONG=''
>>> MPI_F77_LONG_LONG_INT=''
>>> MPI_F77_OFFSET=''
>>> MPI_F77_PACKED=''
>>> MPI_F77_SHORT=''
>>> MPI_F77_SHORT_INT=''
>>> MPI_F77_SIGNED_CHAR=''
>>> MPI_F77_UB=''
>>> MPI_F77_UINT16_T=''
>>> MPI_F77_UINT32_T=''
>>> MPI_F77_UINT64_T=''
>>> MPI_F77_UINT8_T=''
>>> MPI_F77_UNSIGNED=''
>>> MPI_F77_UNSIGNED_CHAR=''
>>> MPI_F77_UNSIGNED_LONG=''
>>> MPI_F77_UNSIGNED_LONG_LONG=''
>>> MPI_F77_UNSIGNED_SHORT=''
>>> MPI_F77_WCHAR=''
>>> MPI_FINT=''
>>> MPI_FLOAT=''
>>> MPI_FLOAT_INT=''
>>> MPI_INT16_T=''
>>> MPI_INT32_T=''
>>> MPI_INT64_T=''
>>> MPI_INT8_T=''
>>> MPI_INT=''
>>> MPI_INTEGER16=''
>>> MPI_INTEGER1=''
>>> MPI_INTEGER2=''
>>> MPI_INTEGER4=''
>>> MPI_INTEGER8=''
>>> MPI_INTEGER=''
>>> MPI_LB=''
>>> MPI_LOGICAL=''
>>> MPI_LONG=''
>>> MPI_LONG_DOUBLE=''
>>> MPI_LONG_DOUBLE_INT=''
>>> MPI_LONG_INT=''
>>> MPI_LONG_LONG=''
>>> MPI_MAX_PROCESSOR_NAME=''
>>> MPI_OFFSET=''
>>> MPI_OFFSET_DATATYPE=''
>>> MPI_OFFSET_TYPEDEF=''
>>> MPI_PACKED=''
>>> MPI_REAL16=''
>>> MPI_REAL4=''
>>> MPI_REAL8=''
>>> MPI_REAL=''
>>> MPI_SHORT=''
>>> MPI_SHORT_INT=''
>>> MPI_SIGNED_CHAR=''
>>> MPI_STATUS_SIZE=''
>>> MPI_UB=''
>>> MPI_UINT16_T=''
>>> MPI_UINT32_T=''
>>> MPI_UINT64_T=''
>>> MPI_UINT8_T=''
>>> MPI_UNSIGNED_CHAR=''
>>> MPI_UNSIGNED_INT=''
>>> MPI_UNSIGNED_LONG=''
>>> MPI_UNSIGNED_LONG_LONG=''
>>> MPI_UNSIGNED_SHORT=''
>>> MPI_WCHAR=''
>>> NEEDSPLIB=''
>>> NO_WEAK_SYM=''
>>> NO_WEAK_SYM_TARGET=''
>>> OBJEXT=''
>>> OFFSET_KIND=''
>>> PACKAGE_BUGREPORT=''
>>> PACKAGE_NAME=''
>>> PACKAGE_STRING=''
>>> PACKAGE_TARNAME=''
>>> PACKAGE_VERSION=''
>>> PATH_SEPARATOR=':'
>>> PERL=''
>>> PMPIFLIBNAME=''
>>> PMPILIBNAME=''
>>> PROFILE_DEF_MPI=''
>>> RANLIB=''
>>> RANLIB_AFTER_INSTALL=''
>>> REQD=''
>>> REQI1=''
>>> REQI2=''
>>> REQI8=''
>>> SET_CFLAGS=''
>>> SET_MAKE=''
>>> SHELL='/bin/sh'
>>> SHLIB_EXT=''
>>> SHLIB_FROM_LO=''
>>> SHLIB_INSTALL=''
>>> SIZEOF_FC_CHARACTER=''
>>> SIZEOF_FC_DOUBLE_PRECISION=''
>>> SIZEOF_FC_INTEGER=''
>>> SIZEOF_FC_REAL=''
>>> SIZEOF_MPI_STATUS=''
>>> USER_CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64'
>>> USER_CPPFLAGS=''
>>> USER_CXXFLAGS=''
>>> USER_FCFLAGS=''
>>> USER_FFLAGS='-O2 -c -qextname -q64 -qwarn64'
>>> USER_LDFLAGS=''
>>> USER_LIBS=''
>>> VPATH=''
>>> WRAPPER_CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64 '
>>> WRAPPER_CPPFLAGS=' '
>>> WRAPPER_CXXFLAGS=' '
>>> WRAPPER_FCFLAGS=' '
>>> WRAPPER_FFLAGS='-O2 -c -qextname -q64 -qwarn64 '
>>> WRAPPER_LDFLAGS=''
>>> WRAPPER_LIBS=''
>>> WTIME_DOUBLE_TYPE=''
>>> XARGS_NODATA_OPT=''
>>> ac_ct_CC=''
>>> ac_ct_CXX=''
>>> ac_ct_F77=''
>>> ac_ct_FC=''
>>> bindings=''
>>> bindings_dirs=''
>>> bindir='${exec_prefix}/bin'
>>> build=''
>>> build_alias=''
>>> build_cpu=''
>>> build_os=''
>>> build_vendor=''
>>> datadir='${datarootdir}'
>>> datarootdir='${prefix}/share'
>>> debugger_dir=''
>>> device_name=''
>>> docdir='${datarootdir}/doc/${PACKAGE}'
>>> dvidir='${docdir}'
>>> exec_prefix='NONE'
>>> host=''
>>> host_alias=''
>>> host_cpu=''
>>> host_os=''
>>> host_vendor=''
>>> htmldir='${docdir}'
>>> includedir='${prefix}/include'
>>> infodir='${datarootdir}/info'
>>> libdir='${exec_prefix}/lib'
>>> libexecdir='${exec_prefix}/libexec'
>>> localedir='${datarootdir}/locale'
>>> localstatedir='${prefix}/var'
>>> logging_dir=''
>>> logging_name=''
>>> logging_subdirs=''
>>> mandir='${datarootdir}/man'
>>> master_top_builddir=''
>>> master_top_srcdir=''
>>> modincdir=''
>>> mpe_dir=''
>>> nameserv_name=''
>>> oldincludedir='/usr/include'
>>> opadir=''
>>> other_install_dirs=''
>>> other_pm_names=''
>>> pac_prog=''
>>> pdfdir='${docdir}'
>>> pm_name=''
>>> pmi_name=''
>>> prefix='/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
>>> program_transform_name='s,x,x,'
>>> psdir='${docdir}'
>>> romio_dir=''
>>> sbindir='${exec_prefix}/sbin'
>>> sharedstatedir='${prefix}/com'
>>> subdirs=''
>>> subsystems=''
>>> sysconfdir='${prefix}/etc'
>>> target_alias=''
>>> ## confdefs.h. ##
>>> configure: exit 77
>>> LaRC Ext:  x46393
>>> _______________________________________________
>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>> <mailto:mpich-discuss at mcs.anl.gov>
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
Pavan Balaji
