[mpich-discuss] Configure error 77
Pavan Balaji balaji at mcs.anl.gov
Tue Jul 10 09:11:46 CDT 2012
It looks like you have CFLAGS and other variables set in your
environment.  Is that intentional?  If not, try unsetting them.
  -- Pavan
On 07/10/2012 09:06 AM, BAKER, MYLES D. (LARC-E302) wrote:
> Dear all,
> I am installing mpich2-1.4.1p1 locally on a cluster that I do not have
> root permissions. I am following along with the v1.4.1 installer's guide
> and the guidelines posted here:
> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2012-July/012752.html
> After decompressing the file I try to configure the installation
> pointing to the installation directory (tcsh):
>  > cd $HOME/mpi/mpich2-1.4.1p1
>  > ./configure --prefix=$HOME/mpi/mpich2-1.4.1p1 --enable-shared
> but the configuration fails with the following errors:
> Configuring MPICH2 version 1.4.1p1 with
>   '--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
> 'CC=/usr/local/bin/gcc' 'CFLAGS=-c -m64 -mcpu=power6 -DLINUX -D_LP64'
> 'CPP=/usr/local/bin/g++' 'F77=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'
> 'FFLAGS=-O2 -c -qextname -q64 -qwarn64'
> Running on system: Linux tisa2-blue 2.6.16.60-0.42.9-ppc64 #1 SMP Thu
> Jan 28 23:39:37 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
> checking for C compiler default output file name...
> configure: error: in `/homedir/mdbaker2/mpi/mpich2-1.4.1p1':
> configure: error: C compiler cannot create executables
> See `config.log' for more details.
> Most of my development will be done in Fortran so I need the F77 and F90
> bindings, and my gcc, g++, and gfortran compilers are located in
> /usr/bin. However, I use the IBM XLF compiler so my F77 and F90 env
> variables point to another location, which the configuration executable
> seems to find just fine (the locations match up to my env file).
> In the core tests I see that the error seems to come from my CFLAGS
> variable. Does this correct? Can anyone give me some direction? I have
> attached the full configuration file below.
> Thanks,
> Myles
> Here is the full config.log file:
> This file contains any messages produced by compilers while
> running configure, to aid debugging if configure makes a mistake.
> It was created by configure, which was
> generated by GNU Autoconf 2.63.  Invocation command line was
>    $ ./configure --prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1
> ## Platform. ##
> hostname = tisa2-blue
> uname -m = ppc64
> uname -r = 2.6.16.60-0.42.9-ppc64
> uname -s = Linux
> uname -v = #1 SMP Thu Jan 28 23:39:37 UTC 2010
> /usr/bin/uname -p = unknown
> /bin/uname -X     = unknown
> /bin/arch              = ppc64
> /usr/bin/arch -k       = unknown
> /usr/convex/getsysinfo = unknown
> /usr/bin/hostinfo      = unknown
> /bin/machine           = unknown
> /usr/bin/oslevel       = unknown
> /bin/universe          = unknown
> PATH: /SPG_ops/utils/univa/bin/lx-ppc64
> PATH: /SPG_ops/utils/ppc64/FileZilla/FileZilla-3.1.0.1/bin
> PATH: /usr/bin
> PATH: /bin
> PATH: /usr/sbin
> PATH: /sbin
> PATH: /usr/games
> PATH: /opt/gnome/bin
> PATH: /usr/bin/X11
> PATH: /usr/lib/mit/bin
> PATH: /usr/lib/mit/sbin
> PATH:
> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/bin/linux
> PATH:
> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/hdf/linux64/HDF4.2r4/bin
> PATH:
> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/zlib/linux64/zlib-1.2.3/zlib/bin
> PATH:
> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/jpeg/linux64/jpeg-6b/bin
> PATH:
> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/hdf5/linux64/hdf5-1.8.3/bin
> PATH:
> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/szip/linux64/szip-2.1/szip/bin
> PATH: /usr/local/bin
> PATH: /etc
> PATH: /usr/etc
> PATH: /usr/X11/bin
> PATH: /usr/local/bin/
> PATH: /usr/sbin/
> PATH: /usr/local/R/bin/
> PATH: /homedir/mdbaker2/bin
> ## Core tests. ##
> configure:3182: checking for C compiler version
> configure:3190: /usr/local/bin/gcc --version >&5
> gcc (GCC) 4.2.2
> Copyright (C) 2007 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.  There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> configure:3194: $? = 0
> configure:3201: /usr/local/bin/gcc -v >&5
> Using built-in specs.
> Target: powerpc64-linux
> Configured with: ../configure --prefix=/SPG_ops/utils/ppc64
> --build=powerpc64-linux --host=powerpc64-linux --target=powerpc64-linux
> --with-cpu=default64 --with-as=/usr/bin/as --with-ld=/usr/bin/ld
> --enable-threads=posix --enable-shared --enable-__cxa_atexit
> --enable-checking --with-mpfr=/SPG_ops/utils/ppc64 --enable-languages=c,c++
> Thread model: posix
> gcc version 4.2.2
> configure:3205: $? = 0
> configure:3212: /usr/local/bin/gcc -V >&5
> gcc: '-V' option must have argument
> configure:3216: $? = 1
> configure:3239: checking for C compiler default output file name
> configure:3261: /usr/local/bin/gcc -c -m64 -mcpu=power6 -DLINUX -D_LP64
>       conftest.c   >&5
> configure:3265: $? = 0
> configure:3303: result:
> configure: failed program was:
> | /* confdefs.h.  */
> | #define PACKAGE_NAME ""
> | #define PACKAGE_TARNAME ""
> | #define PACKAGE_VERSION ""
> | #define PACKAGE_STRING ""
> | #define PACKAGE_BUGREPORT ""
> | #define USE_SMP_COLLECTIVES 1
> | /* end confdefs.h.  */
> | int
> | main ()
> |   return 0;
> configure:3309: error: in `/homedir/mdbaker2/mpi/mpich2-1.4.1p1':
> configure:3312: error: C compiler cannot create executables
> ## Cache variables. ##
> ac_cv_env_AR_FLAGS_set=
> ac_cv_env_AR_FLAGS_value=
> ac_cv_env_CCC_set=
> ac_cv_env_CCC_value=
> ac_cv_env_CC_set=set
> ac_cv_env_CC_value=/usr/local/bin/gcc
> ac_cv_env_CFLAGS_set=set
> ac_cv_env_CFLAGS_value='-c -m64 -mcpu=power6 -DLINUX -D_LP64'
> ac_cv_env_CPPFLAGS_set=
> ac_cv_env_CPPFLAGS_value=
> ac_cv_env_CPP_set=set
> ac_cv_env_CPP_value=/usr/local/bin/g++
> ac_cv_env_CXXCPP_set=
> ac_cv_env_CXXCPP_value=
> ac_cv_env_CXXFLAGS_set=
> ac_cv_env_CXXFLAGS_value=
> ac_cv_env_CXX_set=
> ac_cv_env_CXX_value=
> ac_cv_env_F77_set=set
> ac_cv_env_F77_value=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77
> ac_cv_env_FCFLAGS_set=
> ac_cv_env_FCFLAGS_value=
> ac_cv_env_FC_set=
> ac_cv_env_FC_value=
> ac_cv_env_FFLAGS_set=set
> ac_cv_env_FFLAGS_value='-O2 -c -qextname -q64 -qwarn64'
> ac_cv_env_FROM_MPICH2_set=
> ac_cv_env_FROM_MPICH2_value=
> ac_cv_env_LDFLAGS_set=
> ac_cv_env_LDFLAGS_value=
> ac_cv_env_LIBS_set=
> ac_cv_env_LIBS_value=
> ac_cv_env_MPICH2LIB_CFLAGS_set=
> ac_cv_env_MPICH2LIB_CFLAGS_value=
> ac_cv_env_MPICH2LIB_CPPFLAGS_set=
> ac_cv_env_MPICH2LIB_CPPFLAGS_value=
> ac_cv_env_MPICH2LIB_CXXFLAGS_set=
> ac_cv_env_MPICH2LIB_CXXFLAGS_value=
> ac_cv_env_MPICH2LIB_FCFLAGS_set=
> ac_cv_env_MPICH2LIB_FCFLAGS_value=
> ac_cv_env_MPICH2LIB_FFLAGS_set=
> ac_cv_env_MPICH2LIB_FFLAGS_value=
> ac_cv_env_MPICH2LIB_LDFLAGS_set=
> ac_cv_env_MPICH2LIB_LDFLAGS_value=
> ac_cv_env_MPICH2LIB_LIBS_set=
> ac_cv_env_MPICH2LIB_LIBS_value=
> ac_cv_env_build_alias_set=
> ac_cv_env_build_alias_value=
> ac_cv_env_host_alias_set=
> ac_cv_env_host_alias_value=
> ac_cv_env_target_alias_set=
> ac_cv_env_target_alias_value=
> pac_cv_my_conf_dir=/homedir/mdbaker2/mpi/mpich2-1.4.1p1
> ## Output variables. ##
> ABIVERSION='3:3'
> ADDRESS_KIND=''
> ALLOCA=''
> AR=''
> AR_FLAGS=''
> BASH_SHELL=''
> BSEND_OVERHEAD=''
> BUILD_BASH_SCRIPTS=''
> BUILD_DLLS=''
> BUILD_TVDLL=''
> CC='/usr/local/bin/gcc'
> CC_SHL=''
> CC_SHL_DBG=''
> CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64 '
> CMB_1INT_ALIGNMENT=''
> CMB_STATUS_ALIGNMENT=''
> CONFIGURE_ARGS_CLEAN='--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
> CONFIGURE_ARGUMENTS='
> '\''--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'\''
> '\''CC=/usr/local/bin/gcc'\'' '\''CFLAGS=-c -m64 -mcpu=power6 -DLINUX
> -D_LP64'\'' '\''CPP=/usr/local/bin/g++'\''
> '\''F77=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'\'' '\''FFLAGS=-O2 -c
> -qextname -q64 -qwarn64'\'''
> CPP='/usr/local/bin/g++'
> CPPFLAGS=' '
> CREATESHLIB=''
> CXX=''
> CXXCPP=''
> CXXFLAGS=' '
> CXX_DEFS=''
> CXX_LINKPATH_SHL=''
> CXX_SHL=''
> C_LINKPATH_SHL=''
> C_LINK_SHL=''
> C_LINK_SHL_DBG=''
> DBG_SHLIB_TYPE=''
> DEFS=''
> DEVICE=''
> DEVICE_ARGS=''
> DEVICE_NAME=''
> DLLIMPORT=''
> DOCTEXT=''
> DOCTEXTSTYLE=''
> ECHO_C=''
> ECHO_N='-n'
> ECHO_T=''
> EGREP=''
> ENABLE_SHLIB=''
> EXEEXT=''
> EXTERNAL_SRC_DIRS=''
> EXTRA_STATUS_DECL=''
> F77='/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'
> F77CPP=''
> F77_COMPLEX16=''
> F77_COMPLEX32=''
> F77_COMPLEX8=''
> F77_INCDIR=''
> F77_INTEGER16=''
> F77_INTEGER1=''
> F77_INTEGER2=''
> F77_INTEGER4=''
> F77_INTEGER8=''
> F77_LIBDIR_LEADER=''
> F77_LINKPATH_SHL=''
> F77_NAME_MANGLE=''
> F77_OTHER_LIBS=''
> F77_REAL16=''
> F77_REAL4=''
> F77_REAL8=''
> F77_SHL=''
> FC=''
> FCCPP=''
> FCEXT=''
> FCFLAGS=' '
> FCINC=''
> FCINCFLAG=''
> FCMODEXT=''
> FCMODINCFLAG=''
> FCMODINCSPEC=''
> FC_LINKPATH_SHL=''
> FC_OTHER_LIBS=''
> FC_SHL=''
> FC_WORK_FILES_ARG=''
> FFLAGS='-O2 -c -qextname -q64 -qwarn64 '
> FGREP=''
> FILE=''
> FINCLUDES=''
> FLIBS=''
> FORTRAN_BINDING=''
> FORTRAN_MPI_OFFSET=''
> FROM_MPICH2='yes'
> FWRAPNAME='fmpich'
> GCC=''
> GNUCXX_MINORVERSION=''
> GNUCXX_VERSION=''
> GREP=''
> HAVE_CXX_EXCEPTIONS=''
> HAVE_ROMIO=''
> INCLUDE_MPICXX_H=''
> INCLUDE_MPIDDEFS_H=''
> INSTALL_DATA=''
> INSTALL_PROGRAM=''
> INSTALL_SCRIPT=''
> KILLALL=''
> LDFLAGS=' '
> LDFLAGS_DEPS=''
> LIBOBJS=''
> LIBS=' '
> LIBTOOL=''
> LIB_DEPS=''
> LTLIBOBJS=''
> MAKE=''
> MAKE_DEPEND_C=''
> MANY_PM=''
> MKDIR_P=''
> MPIBASEMODNAME=''
> MPICC=''
> MPICH2LIB_CFLAGS=''
> MPICH2LIB_CPPFLAGS=''
> MPICH2LIB_CXXFLAGS=''
> MPICH2LIB_FCFLAGS=''
> MPICH2LIB_FFLAGS=''
> MPICH2LIB_LDFLAGS=''
> MPICH2LIB_LIBS=''
> MPICH2_NUMVERSION='10401301'
> MPICH2_RELEASE_DATE='Thu Sep  1 13:53:02 CDT 2011'
> MPICH2_VERSION='1.4.1p1'
> MPICH_TIMER_KIND=''
> MPICONSTMODNAME=''
> MPICXX=''
> MPICXXLIBNAME=''
> MPID_TIMER_TYPE=''
> MPIF77=''
> MPIFC=''
> MPIFLIBNAME=''
> MPIFPMPI=''
> MPILIBNAME=''
> MPIMODNAME=''
> MPIR_CXX_BOOL=''
> MPIR_CXX_COMPLEX=''
> MPIR_CXX_DOUBLE_COMPLEX=''
> MPIR_CXX_LONG_DOUBLE_COMPLEX=''
> MPISIZEOFMODNAME=''
> MPIU_DLL_SPEC_DEF=''
> MPIU_THREAD_LIB_NAME=''
> MPI_2COMPLEX=''
> MPI_2DOUBLE_COMPLEX=''
> MPI_2DOUBLE_PRECISION=''
> MPI_2INT=''
> MPI_2INTEGER=''
> MPI_2REAL=''
> MPI_AINT=''
> MPI_AINT_DATATYPE=''
> MPI_AINT_FMT_DEC_SPEC=''
> MPI_AINT_FMT_HEX_SPEC=''
> MPI_BYTE=''
> MPI_CHAR=''
> MPI_CHARACTER=''
> MPI_COMPLEX16=''
> MPI_COMPLEX32=''
> MPI_COMPLEX8=''
> MPI_COMPLEX=''
> MPI_C_BOOL=''
> MPI_C_DOUBLE_COMPLEX=''
> MPI_C_FLOAT_COMPLEX=''
> MPI_C_LONG_DOUBLE_COMPLEX=''
> MPI_DOUBLE=''
> MPI_DOUBLE_COMPLEX=''
> MPI_DOUBLE_INT=''
> MPI_DOUBLE_PRECISION=''
> MPI_F77_2INT=''
> MPI_F77_AINT=''
> MPI_F77_BYTE=''
> MPI_F77_CHAR=''
> MPI_F77_C_BOOL=''
> MPI_F77_C_COMPLEX=''
> MPI_F77_C_DOUBLE_COMPLEX=''
> MPI_F77_C_FLOAT_COMPLEX=''
> MPI_F77_C_LONG_DOUBLE_COMPLEX=''
> MPI_F77_DOUBLE=''
> MPI_F77_DOUBLE_INT=''
> MPI_F77_FLOAT=''
> MPI_F77_FLOAT_INT=''
> MPI_F77_INT16_T=''
> MPI_F77_INT32_T=''
> MPI_F77_INT64_T=''
> MPI_F77_INT8_T=''
> MPI_F77_INT=''
> MPI_F77_LB=''
> MPI_F77_LONG=''
> MPI_F77_LONG_DOUBLE=''
> MPI_F77_LONG_DOUBLE_INT=''
> MPI_F77_LONG_INT=''
> MPI_F77_LONG_LONG=''
> MPI_F77_LONG_LONG_INT=''
> MPI_F77_OFFSET=''
> MPI_F77_PACKED=''
> MPI_F77_SHORT=''
> MPI_F77_SHORT_INT=''
> MPI_F77_SIGNED_CHAR=''
> MPI_F77_UB=''
> MPI_F77_UINT16_T=''
> MPI_F77_UINT32_T=''
> MPI_F77_UINT64_T=''
> MPI_F77_UINT8_T=''
> MPI_F77_UNSIGNED=''
> MPI_F77_UNSIGNED_CHAR=''
> MPI_F77_UNSIGNED_LONG=''
> MPI_F77_UNSIGNED_LONG_LONG=''
> MPI_F77_UNSIGNED_SHORT=''
> MPI_F77_WCHAR=''
> MPI_FINT=''
> MPI_FLOAT=''
> MPI_FLOAT_INT=''
> MPI_INT16_T=''
> MPI_INT32_T=''
> MPI_INT64_T=''
> MPI_INT8_T=''
> MPI_INT=''
> MPI_INTEGER16=''
> MPI_INTEGER1=''
> MPI_INTEGER2=''
> MPI_INTEGER4=''
> MPI_INTEGER8=''
> MPI_INTEGER=''
> MPI_LB=''
> MPI_LOGICAL=''
> MPI_LONG=''
> MPI_LONG_DOUBLE=''
> MPI_LONG_DOUBLE_INT=''
> MPI_LONG_INT=''
> MPI_LONG_LONG=''
> MPI_MAX_PROCESSOR_NAME=''
> MPI_OFFSET=''
> MPI_OFFSET_DATATYPE=''
> MPI_OFFSET_TYPEDEF=''
> MPI_PACKED=''
> MPI_REAL16=''
> MPI_REAL4=''
> MPI_REAL8=''
> MPI_REAL=''
> MPI_SHORT=''
> MPI_SHORT_INT=''
> MPI_SIGNED_CHAR=''
> MPI_STATUS_SIZE=''
> MPI_UB=''
> MPI_UINT16_T=''
> MPI_UINT32_T=''
> MPI_UINT64_T=''
> MPI_UINT8_T=''
> MPI_UNSIGNED_CHAR=''
> MPI_UNSIGNED_INT=''
> MPI_UNSIGNED_LONG=''
> MPI_UNSIGNED_LONG_LONG=''
> MPI_UNSIGNED_SHORT=''
> MPI_WCHAR=''
> NEEDSPLIB=''
> NO_WEAK_SYM=''
> NO_WEAK_SYM_TARGET=''
> OBJEXT=''
> OFFSET_KIND=''
> PACKAGE_BUGREPORT=''
> PACKAGE_NAME=''
> PACKAGE_STRING=''
> PACKAGE_TARNAME=''
> PACKAGE_VERSION=''
> PATH_SEPARATOR=':'
> PERL=''
> PMPIFLIBNAME=''
> PMPILIBNAME=''
> PROFILE_DEF_MPI=''
> RANLIB=''
> RANLIB_AFTER_INSTALL=''
> REQD=''
> REQI1=''
> REQI2=''
> REQI8=''
> SET_CFLAGS=''
> SET_MAKE=''
> SHELL='/bin/sh'
> SHLIB_EXT=''
> SHLIB_FROM_LO=''
> SHLIB_INSTALL=''
> SIZEOF_FC_CHARACTER=''
> SIZEOF_FC_DOUBLE_PRECISION=''
> SIZEOF_FC_INTEGER=''
> SIZEOF_FC_REAL=''
> SIZEOF_MPI_STATUS=''
> USER_CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64'
> USER_CPPFLAGS=''
> USER_CXXFLAGS=''
> USER_FCFLAGS=''
> USER_FFLAGS='-O2 -c -qextname -q64 -qwarn64'
> USER_LDFLAGS=''
> USER_LIBS=''
> VPATH=''
> WRAPPER_CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64 '
> WRAPPER_CPPFLAGS=' '
> WRAPPER_CXXFLAGS=' '
> WRAPPER_FCFLAGS=' '
> WRAPPER_FFLAGS='-O2 -c -qextname -q64 -qwarn64 '
> WRAPPER_LDFLAGS=''
> WRAPPER_LIBS=''
> WTIME_DOUBLE_TYPE=''
> XARGS_NODATA_OPT=''
> ac_ct_CC=''
> ac_ct_CXX=''
> ac_ct_F77=''
> ac_ct_FC=''
> bindings=''
> bindings_dirs=''
> bindir='${exec_prefix}/bin'
> build=''
> build_alias=''
> build_cpu=''
> build_os=''
> build_vendor=''
> datadir='${datarootdir}'
> datarootdir='${prefix}/share'
> debugger_dir=''
> device_name=''
> docdir='${datarootdir}/doc/${PACKAGE}'
> dvidir='${docdir}'
> exec_prefix='NONE'
> host=''
> host_alias=''
> host_cpu=''
> host_os=''
> host_vendor=''
> htmldir='${docdir}'
> includedir='${prefix}/include'
> infodir='${datarootdir}/info'
> libdir='${exec_prefix}/lib'
> libexecdir='${exec_prefix}/libexec'
> localedir='${datarootdir}/locale'
> localstatedir='${prefix}/var'
> logging_dir=''
> logging_name=''
> logging_subdirs=''
> mandir='${datarootdir}/man'
> master_top_builddir=''
> master_top_srcdir=''
> modincdir=''
> mpe_dir=''
> nameserv_name=''
> oldincludedir='/usr/include'
> opadir=''
> other_install_dirs=''
> other_pm_names=''
> pac_prog=''
> pdfdir='${docdir}'
> pm_name=''
> pmi_name=''
> prefix='/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
> program_transform_name='s,x,x,'
> psdir='${docdir}'
> romio_dir=''
> sbindir='${exec_prefix}/sbin'
> sharedstatedir='${prefix}/com'
> subdirs=''
> subsystems=''
> sysconfdir='${prefix}/etc'
> target_alias=''
> ## confdefs.h. ##
> configure: exit 77
> *BAKER, MYLES D. (LARC-E302)*
> *Mail Stop 420, B1250 R177
> myles.d.baker at nasa.gov <mailto:myles.d.baker at nasa.gov>
> LaRC Ext:  x46393
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Pavan Balaji
http://www.mcs.anl.gov/~balaji
