[mpich-discuss] mpich-discuss Digest, Vol 40, Issue 46 How should I run a source code in C with MPICH2
    Pradheep Kumar
    pradconf at gmail.com
    Tue Jan 31 23:07:22 CST 2012
Hi All,
I have installed MPICH2 on Fedora 13. I need to profile a C program on
MPICH2. Kindly let me know how to do the same.
Pradheep
On Tue, Jan 31, 2012 at 11:51 PM, <mpich-discuss-request at mcs.anl.gov> wrote:
> Send mpich-discuss mailing list submissions to
>        mpich-discuss at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>        https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        mpich-discuss-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mpich-discuss digest..."
> Today's Topics:
>   1. Re:  References for FORTRAN (Gustavo Correa)
>   2.  MPICH2 installation failure (Dute?s)
> Message: 1
> Date: Tue, 31 Jan 2012 13:19:24 -0500
> From: Gustavo Correa <gus at ldeo.columbia.edu>
> Subject: Re: [mpich-discuss] References for FORTRAN
> To: Mpich-Discuss <mpich-discuss at mcs.anl.gov>
> Message-ID: <FA60ADE2-C0A0-46E4-9A70-779272BE3A76 at ldeo.columbia.edu>
> Content-Type: text/plain; charset=us-ascii
> Hi
> Here are some references in MPI+Fortran.
> 1) The LLNL MPI tutorial has some [light weight] MPI examples in Fortran:
> https://computing.llnl.gov/tutorials/mpi/
> 2) NCCS tutorials & references:
> http://www.nccs.gov/user-support/training-education/hpcparallel-computing-links/
> http://www.nccs.gov/user-support/training-education/hpcparallel-computing-links/mpi-examples
> An early version in Fortran of Peter Pacheco's book:
> ladon.iqfr.csic.es/docs/MPI_ug_in_FORTRAN.pdf
> 3) Matrix multiplication:
> http://www.mcs.anl.gov/research/projects/mpi/usingmpi/examples/simplempi/main.htm
> http://www.mcs.anl.gov/research/projects/mpi/usingmpi/examples/simplempi/f90/matmat_f90.htm
> 4) 2D Diffusion PDE solved by the Jacobi method [illustrates the use of
> cartesian
> domain decomposition and PDE solver in MPI+Fortran]:
>  http://beige.ucs.indiana.edu/I590/node71.html
> If you want really to go for large codes [my bias is
> ocean/atmosphereclimate]
> there are several which are publically available, mostly written in
> Fortran, with a few bits in C:
> 5) weather forecast:
> http://www.wrf-model.org/index.php
> 6) coupled climate model:
> http://www.cesm.ucar.edu/
> 7) ocean general circulation and regional models:
> http://mitgcm.org/
> http://www.gfdl.noaa.gov/fms
> 8) molecular dynamics:
> http://www.vasp.at/
> http://ambermd.org/
> 9) NAS parallel benchmarks:
> http://www.nas.nasa.gov/publications/npb.html
> I hope this helps.
> Gus Correa
> On Jan 31, 2012, at 10:16 AM, Anthony Chan wrote:
> > Try doing a google search of "MPI Fortran tutorial"....
> > MPI is a communication library, so you can do numerical
> > intensive calculation between communications.
> > A.Chan
> > ----- Original Message -----
> >> Dear all,
> >> Can someone give me good references to exploit MPICH using Fortran
> >> programs ? A tutorial or an example of a calculation-intensive program
> >> would be appreciated.
> >> Thanks,
> >> Jose
> >> _______________________________________________
> >> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> >> To manage subscription options or unsubscribe:
> Message: 2
> Date: Tue, 31 Jan 2012 18:05:54 +0000
> From: Dute?s, Paul <p.m.duteis at cranfield.ac.uk>
> Subject: [mpich-discuss] MPICH2 installation failure
> To: "mpich-discuss at mcs.anl.gov" <mpich-discuss at mcs.anl.gov>
> Message-ID:
> 82495BE8A8646A49968777B0BE261ACB17E24C85 at CCEXCHMBX-2.central.cranfield.ac.uk
> Content-Type: text/plain; charset="iso-8859-1"
> Good evening,
> For some reasons I can't get MPICH2 to install correctly on my Opensuse
> 12.1 system.
> Everything goes smoothly until I try the first following test
>  mpiexec -n 2 ./examples/cpi
> where it says
> ssh: Could not resolve hostname linux-hpws.site: Name or service not known
> and just crashes.
> Could you help me with whatever is wrong? I've joined the log files.
> Best Regards,
> Paul Dute?s
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: application/x-gzip
> Desc: logfiles.tar.gz
> URL: <
> http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120131/7c472f27/attachment.bin
> End of mpich-discuss Digest, Vol 40, Issue 46
K.Pradheep Kumar
mobile:  +919003079697
email:    pradconf at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120201/c38ad0b1/attachment.htm>
