[mpich-discuss] Is anybody successfully using MPICH2 with MCNP5
    Sterling Bailey
    Sterling.Bailey at att.net
    Tue Jan 31 18:26:55 CST 2012
I'm trying to get MPICH2 to work with MCNP5. I have mpich2 installed and
I can run simple codes on parallel processors OK. I also have mcnp5
installed to run on one machine and it works fine. The mcnp5
documentation deals with using mpich1 but ANL says they don't support
that any longer. So I'd like to see if anyone has been successful with
the two, mpich2 and mcnp5, running on parallel processors together. If
so, what compilers did you use with mcnp5 and did you use the install
script?
Thanks in advance for any help,
Sterling
