[mpich-discuss] [EXTERNAL] Re: Modifying ssh calls for MPICH2
Reuti
reuti at staff.uni-marburg.de
Tue Jan 17 17:34:52 CST 2012
Am 18.01.2012 um 00:32 schrieb Kekatpure, Rohan Deodatta (-EXP):
> Reuti,
> I dont remember installing OpenMPI. I downloaded "mpich2-1.4.1p1.tar.gz" from
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/1.4.1p1/
> and followed the install instructions in the README file. Is there a way to confirm that I dont have OpenMPI installed (and to remove it if it is present for some reason?)
which mpicc
mpicc -v
> Thanks,
> Rohan
> On Jan 17, 2012, at 3:22 PM, Reuti wrote:
>> Am 17.01.2012 um 23:19 schrieb Kekatpure, Rohan Deodatta (-EXP):
>>> I think I have more basic problems than what you are referring to:
>>> I copy-pasted Reuti's code into a file named mpitest.c and tried to compile with
>>> gcc -Wall mpitest.c
>>> It failed to compile and issued following error(s):
>>> Undefined symbols:
>>> "_ompi_mpi_comm_world", referenced from:
>> ompi - do you have Open MPI installed too?
>> -- Reuti
>>> _main in cc8tNiKW.o
>>> "_MPI_Comm_rank", referenced from:
>>> _main in cc8tNiKW.o
>>> "_MPI_Finalize", referenced from:
>>> _main in cc8tNiKW.o
>>> "_MPI_Init", referenced from:
>>> _main in cc8tNiKW.o
>>> ld: symbol(s) not found
>>> collect2: ld returned 1 exit status
>>> Rohan
>>> On Jan 17, 2012, at 3:09 PM, Jed Brown wrote:
>>>> On Tue, Jan 17, 2012 at 16:02, Reuti <reuti at staff.uni-marburg.de> wrote:
>>>> main(int argc, char **argv)
>>>> int node;
>>>> int i,j;
>>>> float f;
>>>> MPI_Init(NULL,NULL);
>>>> MPI_Comm_rank(MPI_COMM_WORLD, &node);
>>>> printf("Hello World from Node %d.\n", node);
>>>> for(j=0; j <= 100000; j++)
>>>> for(i=0;i <= 100000; i++)
>>>> f=i*2.718281828*i+i+i*3.141592654;
>>>> Well this is an odd spin loop because the compiler will happily remove it for you (note that MPICH2's mpicc wrapper very frequently has optimization flags in it). I would suggest sleep(3) instead, or, if you must, force the loop to actually be executed (e.g. seed the loop with the rank and use the result).
>>>> _______________________________________________
>>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>> To manage subscription options or unsubscribe:
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
