[mpich-discuss] best/fastest way to get a node communicator
Dave Goodell
goodell at mcs.anl.gov
Tue Jan 17 16:46:42 CST 2012
If you want to work with IP addresses, which seems preferable to me, then I would avoid MPI_Get_processor_name altogether and grab the IP addresses directly. IIRC ioctl(…,SIOCGIFADDR,…) and/or getifaddrs is your friend here.
You'll have to be careful using the IP address as a key, since they are really unsigned integers, but MPI_Comm_split takes a signed integer, and at least one negative value (MPI_UNDEFINED) has special meaning. Also, IPv6 addresses obviously won't fit in that integer spot without some sort of transformation.
-Dave
On Jan 17, 2012, at 4:23 PM CST, Jeff Hammond wrote:
> Thanks for the helpful suggestions, Rhys.
> Using a perfect hash function was the first thing to jump into my
> head. Unfortunately, I do not know how to write perfect hash
> functions for MPI_MAX_PROCESSOR_NAME-length character arrays and the
> value of optimization for memory usage on clusters, which almost
> always have fewer than 20000 cores and more than 20 GB of DRAM, isn't
> worth me learning how to use gperf. The memory use required for the
> Gather is an issue on a Blue Gene or a Cray, but like I said, I have
> another solution there.
> Whenever MPI_Get_processor_name returns an IP address, I don't need a
> hash function because I can just convert the IP address into an
> integer (32-bit for IPv4 and 128-bit for IPv6) and use that as the
> key. A straightforward optimization is to test if all nodes have
> returned an IP address and if true, use that, otherwise fall back to
> the gather+qsort implementation.
> Jeff
> On Tue, Jan 17, 2012 at 3:39 PM, Rhys Ulerich <rhys.ulerich at gmail.com> wrote:
>>> On 01/17/2012 01:24 PM, Jeff Hammond wrote:
>>>> I'm interested in being able to create a communicator for each node.
>>>> I have custom APIs for this on Blue Gene and Cray, but that doesn't
>>>> help on clusters.
>>>> I was thinking of doing the following:
>>>> - call gethostname on each rank
>>>> - gather these values to root
>>>> - sort the array and assign a different color number for each unique
>>>> value in a new array
>>>> - scatter the color array and call comm_split
>>>> Does anyone know of a better/faster way to do this?
>> This may avoid the memory overhead on root and avoids the sort.
>> - call MPI_Get_processor_name as Jim Dinan suggested
>> - hash the processor name into a nonnegative int color (with care as
>> to the chosen hash function)
>> - MPI_Comm_split on the color
>> - Set value '1' into some integer buffer on all ranks.
>> - MPI_Allreduce MPI_SUM on each integer buffer to find the number of
>> ranks in each rank's color-communicator
>> - MPI_Allreduce to find the minimum and maximum of the ranks in each
>> color-communicator across COMM_WORLD
>> - If minimum and maximum are not identical, throw away the bad
>> node-specific communicators (you encountered a hash collision), add
>> some salt to the hash (maybe an iteration number), and repeat the
>> process.
>> Presumably you won't be hit by hash collisions indefinitely. With a
>> good hash function, you probably won't hit any collisions at all.
>> It is likely not faster (as it is a bit chatty) but I've never
>> measured it. Nor implemented it.
>> - Rhys
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/old/index.php/User:Jhammond
