[mpich-discuss] credentials rejected
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Jan  5 12:09:27 CST 2012
 If you need your MPI job run as the domain user (say "Angelescu") who is part of the domain "MyDomain" you need to register "MyDomain\Angelescu" as the username (and enter the password for the domain user when prompted). If you would like your job run locally on your computer, I would recommend creating a user in your machine with a password and register that user/password with mpiexec.
 Let us know if it works.
Jayesh
----- Original Message -----
From: "Angelescu Ioana" <duveteux_angel at yahoo.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, January 5, 2012 11:16:04 AM
Subject: Re: credentials rejected
Ok, no problem.I just want to get this fixed, cause i need to sustain a project in it and if i can run it, i can not finish the project.I do not want a ticket to be issued, for me as long as i get this fixed, there is no problem for me.
I do not have any windows password, i am the admin of the computer i am using(i also tried to install it on my laptop but i get the same problem)
When i put in command prompt, mpiexec - register and i am asked for the account, i just hit enter, so it can take the default username shown in the prompt, i only enter the password.
Yes, my user is a domain user, but i do not understand what u mean by prepend.
Sincerely, Ioana.
To: duveteux_angel at yahoo.com
Cc: mpich-discuss at mcs.anl.gov
Sent: Thursday, January 5, 2012 6:51 PM
Subject: credentials rejected
Your problem may or may not be related to the one mentioned in the ticket 1151. Let us discuss the issue on mpich-discuss and if needed you can go ahead and create a new ticket for the issue.
Did you enter a valid Windows username/password when you registered a username/password with mpiexec (mpiexec -register)? If your user is a domain user did you prepend the username with the domain name ?
Jayesh
Sent: Wednesday, January 4, 2012 8:33:26 AM
Subject: Re: [mpich2-maint] #1151: credentials rejected
Reporter: frankeng@… | Owner: jayesh
Type: bug | Status: reopened
Priority: blocker | Milestone:
Component: mpich2 | Resolution:
Keywords: |
Changes (by duveteux_angel@…):
* priority: minor => blocker
* status: closed => reopened
* resolution: fixed =>
Comment:
Hello, i am confronting myself with a problem, i installed MPICH2 version
1.4.1 i did all the steps that were mentioned above,(added the path to
environment variable, from cmd i put mpiexec -register, hit enter, than
added a password,retyped it) but when i do mpiexec -validate from cmd, it
returns FAIL, i tried uninstalling, reboot than installing again and did
the same steps, but still i get FAIL at validate.
I do not know what to do anymore, i hope you can help., Ioana.
Ticket URL: <http://trac.mcs.anl.gov/projects/mpich2/ticket/1151#comment:7>
mpich2 <http://www.mcs.anl.gov/research/projects/mpich2>
MPICH2 is a high-performance and widely portable implementation of MPI
