[mpich-discuss] credentials rejected
Jayesh Krishna
jayesh at mcs.anl.gov
Thu Jan 5 10:51:18 CST 2012
Your problem may or may not be related to the one mentioned in the ticket 1151. Let us discuss the issue on mpich-discuss and if needed you can go ahead and create a new ticket for the issue.
Did you enter a valid Windows username/password when you registered a username/password with mpiexec (mpiexec -register)? If your user is a domain user did you prepend the username with the domain name ?
Jayesh
----- Original Message -----
Sent: Wednesday, January 4, 2012 8:33:26 AM
Subject: Re: [mpich2-maint] #1151: credentials rejected
Reporter: frankeng@… | Owner: jayesh
Type: bug | Status: reopened
Priority: blocker | Milestone:
Component: mpich2 | Resolution:
Keywords: |
Changes (by duveteux_angel@…):
* priority: minor => blocker
* status: closed => reopened
* resolution: fixed =>
Comment:
Hello, i am confronting myself with a problem, i installed MPICH2 version
1.4.1 i did all the steps that were mentioned above,(added the path to
environment variable, from cmd i put mpiexec -register, hit enter, than
added a password,retyped it) but when i do mpiexec -validate from cmd, it
returns FAIL, i tried uninstalling, reboot than installing again and did
the same steps, but still i get FAIL at validate.
I do not know what to do anymore, i hope you can help., Ioana.
Ticket URL: <http://trac.mcs.anl.gov/projects/mpich2/ticket/1151#comment:7>
mpich2 <http://www.mcs.anl.gov/research/projects/mpich2>
MPICH2 is a high-performance and widely portable implementation of MPI
