[mpich-discuss] MPI_Bcast error
Pavan Balaji
balaji at mcs.anl.gov
Tue Feb 28 17:08:46 CST 2012
Can you send us a test program where it fails? Below are the answers to
your questions.
On 02/28/2012 05:03 PM, Luiz Carlos Costa Junior wrote:
> 1) Is there any limitation on the size of the buffer that is sent?
No. You might run into a limit with the "int" parameter for the
datatype count if you send more than 2 billion elements, but you can
easily workaround that by creating a datatype with larger datatypes
(double or larger contiguous types). But with 12MB data, that's irrelevant.
> 2) If this limit exists, would it be related to the number of the
> process of the communicator? in this case, I am using 32 processes, but
> I commonly had success with bigger clusters (over 200 processes).
Number of processes don't matter.
> 3) Is the content of data being sent relevant? If I have some
> uninitialized data, would it be a concern? In other words, I understand
> that the only thing that matters is that the buffer size must be correct
> in all process (any combination of datatype/array size) and there must
> be enough allocated space to receive the data, right?
No. MPI doesn't care what you are sending.
> 4) How is the best way to send this data? Split it in smaller broadcasts
> might be better/safer?
One broadcast is the best. If you see better performance by doing
multiple smaller broadcasts, that'll be classified as a bug in our code.
> 5) How should I classify a 12 MB message? Small? Big? I believe it
> should be pretty small because I also have other typical executions
> instances with messages over 100 MB that had sucess.
It's small enough that it should work fine.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
