[mpich-discuss] Compiled applications working standalone, but not using mpiexec
Hugh Cassidy
hcassid2 at uwo.ca
Mon Feb 27 13:47:05 CST 2012
No effect, still not producing any output.
On 2/27/2012 2:36 PM, Jayesh Krishna wrote:
> Hi,
> Please follow the steps below and let us know the results,
> # Rename c:\Program Files\MPICH2\lib\libfmpich2g.a to c:\Program Files\MPICH2\lib\libmpifmpich2g.a
> # Re-compile your code as follows,
> gfortran -o fpi fpi.f -lmpifmpich2g -lmpi
> # Re-run fpi with/without mpiexec and let us know the results.
> Regards,
> Jayesh
> From: "Hugh Cassidy"<hcassid2 at uwo.ca>
> To: "Jayesh Krishna"<jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Monday, February 27, 2012 12:50:58 PM
> Subject: Re: [mpich-discuss] Compiled applications working standalone, but not using mpiexec
> Hello,
> -localonly option has no effect - no output is produced.
> I am able to compile and run successfully the icpi.c example, however,
> which leads me to believe the problem is related to compiling fortran
> code specifically.
> I'm running MinGW, using GNU Fortran version 4.6.1. To compile fpi.f, I
> execute the following command:
> gfortran -o fpi fpi.f -lfmpich2g
> Which successfully compiles the program. I've read that there is an
> issue using the windows installer and fortran, since the libraries are
> compiled with the intel fortran compiler - is this correct?
> On 2/27/2012 11:33 AM, Jayesh Krishna wrote:
>> Hi,
>> Try running your job with the "-localonly" option and see if it prints an error message.
>> Regards,
>> Jayesh
>> To: mpich-discuss at mcs.anl.gov
>> Sent: Sunday, February 26, 2012 4:41:48 PM
>> Subject: [mpich-discuss] Compiled applications working standalone, but not using mpiexec
>> Hello,
>> I have MPICH2 32 installed on Windows 7. The cpi.exe example works fine
>> when I run, for example, the command:
>> mpiexec -n 4 cpi.exe
>> I have been able to compile, using gfortran, the fpi.f example.
>> Furthermore, I can run the generate application in a standalone fashion:
>> fpi.exe
>> However, when I attempt to use mpiexec, it doesn't work:
>> mpiexec -n 4 fpi.exe
>> Doesn't seem to do anything - I'm just returned immediately to the
>> command prompt with no output displayed. Does anyone know why this may
>> be happening? I'm experiencing the same problem trying to run another
>> application that makes use of mpi - it runs standalone, but not using
>> the mpiexec command. I'm guessing this means there is some problem with
>> the compilation step?
>> Thanks!
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
