[mpich-discuss] Compiled applications working standalone, but not using mpiexec
Jayesh Krishna jayesh at mcs.anl.gov
Mon Feb 27 13:36:46 CST 2012
 Please follow the steps below and let us know the results,
# Rename c:\Program Files\MPICH2\lib\libfmpich2g.a to c:\Program Files\MPICH2\lib\libmpifmpich2g.a
# Re-compile your code as follows,
  gfortran -o fpi fpi.f -lmpifmpich2g -lmpi
# Re-run fpi with/without mpiexec and let us know the results.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Monday, February 27, 2012 12:50:58 PM
Subject: Re: [mpich-discuss] Compiled applications working standalone, but not using mpiexec
Hello,
-localonly option has no effect - no output is produced.
I am able to compile and run successfully the icpi.c example, however,
which leads me to believe the problem is related to compiling fortran
code specifically.
I'm running MinGW, using GNU Fortran version 4.6.1. To compile fpi.f, I
execute the following command:
gfortran -o fpi fpi.f -lfmpich2g
Which successfully compiles the program. I've read that there is an
issue using the windows installer and fortran, since the libraries are
compiled with the intel fortran compiler - is this correct?
On 2/27/2012 11:33 AM, Jayesh Krishna wrote:
> Hi,
>   Try running your job with the "-localonly" option and see if it prints an error message.
> Regards,
> Jayesh
> From: "Hugh Cassidy"<hcassid2 at uwo.ca>
> To: mpich-discuss at mcs.anl.gov
> Sent: Sunday, February 26, 2012 4:41:48 PM
> Subject: [mpich-discuss] Compiled applications working standalone,	but not using mpiexec
> Hello,
> I have MPICH2 32 installed on Windows 7. The cpi.exe example works fine
> when I run, for example, the command:
> mpiexec -n 4 cpi.exe
> I have been able to compile, using gfortran, the fpi.f example.
> Furthermore, I can run the generate application in a standalone fashion:
> fpi.exe
> However, when I attempt to use mpiexec, it doesn't work:
> mpiexec -n 4 fpi.exe
> Doesn't seem to do anything - I'm just returned immediately to the
> command prompt with no output displayed. Does anyone know why this may
> be happening? I'm experiencing the same problem trying to run another
> application that makes use of mpi - it runs standalone, but not using
> the mpiexec command. I'm guessing this means there is some problem with
> the compilation step?
> Thanks!
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
