[mpich-discuss] mpiexec problem on cluster.
    medini chaitanya
    mach512 at gmail.com
    Fri Feb 24 01:36:52 CST 2012
Hi Gustavo,
Thank you very much for providing me answer. I solved that error by setting
up library path in .bashrc file and after that it ran without any error.
Thanks a lot again for your kind reply.
On Thu, Feb 23, 2012 at 10:11 PM, Gustavo Correa <gus at ldeo.columbia.edu>wrote:
> Hi Krishna
> Did you install MPICH2 on both machines?
> Is it installed in /usr/local in both machines?
> Alternatively, did you install MPICH2 in /usr/local and is this directory
> shared
> across the two machines [perhaps via NFS]?
> You can check this out.
> Login to each machine, and search /usr/local/bin and /usr/local/lib [or
> lib64] for the MPICH2
> files.
> I hope this helps,
> Gus Correa
> On Feb 23, 2012, at 12:50 AM, medini chaitanya wrote:
> > Hi,
> > When I am trying to execute mpiexec command on a cluster of two
> machines, it gives me this error:
> > "/usr/local/bin/hydra_pmi_proxy: error while loading shared libraries:
> libmpl.so.1: cannot open shared object file: No such file or directory".
> > But it is running well on single machine. Please let me know your
> suggestions. Thank you.
> > Krishna Chaitanya
> > Ph.D Scholar,
> > School of Biotechnology,
> > Amrita Vishwa Vidyapeetham
> > _______________________________________________
> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Krishna Chaitanya
Ph.D Scholar,
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120224/7d461e56/attachment.htm>
