[mpich-discuss] mpiexec problem on cluster.
    Gustavo Correa
    gus at ldeo.columbia.edu
    Thu Feb 23 10:41:33 CST 2012
Hi Krishna
Did you install MPICH2 on both machines?
Is it installed in /usr/local in both machines?
Alternatively, did you install MPICH2 in /usr/local and is this directory shared
across the two machines [perhaps via NFS]?
You can check this out.
Login to each machine, and search /usr/local/bin and /usr/local/lib [or lib64] for the MPICH2
files.
I hope this helps,
Gus Correa
On Feb 23, 2012, at 12:50 AM, medini chaitanya wrote:
> Hi,
> When I am trying to execute mpiexec command on a cluster of two machines, it gives me this error:
> "/usr/local/bin/hydra_pmi_proxy: error while loading shared libraries: libmpl.so.1: cannot open shared object file: No such file or directory".
> But it is running well on single machine. Please let me know your suggestions. Thank you.
> Krishna Chaitanya
> Ph.D Scholar,
> School of Biotechnology,
> Amrita Vishwa Vidyapeetham
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
