[mpich-discuss] Mpdboot problem.
    Reuti
    reuti at staff.uni-marburg.de
    Wed Feb 22 04:27:10 CST 2012
Am 22.02.2012 um 11:23 schrieb Sandra Mendez:
> Hi Krishma,
> The last version MPICH doesn't use the mpdboot. To run only need:
> PATH_MPICH/bin/mpirun -n NumberProcesses -f NameMachineFile PATH_ProgramUser
> if you want to select the machines to run the application, you must put:
> Regards.
> Sandra.-
Sorry for repeating the same info, you beat me by a minute. - Reuti
> ----------------mensaje original-----------------
> De: "medini chaitanya" mach512 at gmail.com
> Para: mpich-discuss at mcs.anl.gov
> Fecha: Wed, 22 Feb 2012 14:55:38 +0530
>> Hi,
>> I have installed MPICH2 package on beowulf cluster and after executing
>> mpdboot -n 2 -f mpd.hosts file, it returned me an error like:
>> mpdboot_krishna (handle_mpd_output 426): from mpd on krishna, invalid port
>> info:
>> no_port
>> I have installed all the packages and it installed correctly without any
>> errors. Is there anything haven't done properly? Any help would be greatly
>> appreciated.
>> Thank you.
>> Krishna Chaitanya
>> Ph.D Scholar,
>> School of Biotechnology,
>> Amrita Vishwa Vidyapeetham
> __________________________________________________
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
