[mpich-discuss] Mpdboot problem.
    Sandra Mendez
    sandra.mendez at caos.uab.es
    Wed Feb 22 04:23:59 CST 2012
Hi Krishma,
The last version MPICH doesn't use the mpdboot. To run only need:
PATH_MPICH/bin/mpirun -n NumberProcesses -f NameMachineFile PATH_ProgramUser
if you want to select the machines to run the application, you must put:
Regards.
Sandra.-
----------------mensaje original-----------------
De: "medini chaitanya" mach512 at gmail.com
Para: mpich-discuss at mcs.anl.gov
Fecha: Wed, 22 Feb 2012 14:55:38 +0530
> Hi,
> I have installed MPICH2 package on beowulf cluster and after executing
> mpdboot -n 2 -f mpd.hosts file, it returned me an error like:
> mpdboot_krishna (handle_mpd_output 426): from mpd on krishna, invalid port
> info:
> no_port
> I have installed all the packages and it installed correctly without any
> errors. Is there anything haven't done properly? Any help would be greatly
> appreciated.
> Thank you.
> Krishna Chaitanya
> Ph.D Scholar,
> School of Biotechnology,
> Amrita Vishwa Vidyapeetham
__________________________________________________
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
