[mpich-discuss] problem running smpd on a windows machine
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Feb 14 15:12:41 CST 2012
 Can you try re-installing (uninstall MPICH2, and then install it again following instructions in Sec 9.4) following instructions in Section 9.4 (NOT 9.1) of the installer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs)?
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Tuesday, February 14, 2012 1:48:23 PM
Subject: Re: [mpich-discuss] problem running smpd on a windows machine
Hi, Jayesh,
thanks for the quick response. I'm trying everything I can in order to run MCNPX in the MPI version. Whenever I try to launch MPI I constantly get denied access. I have a 12 core processor, and it fails to launch 12 times, each with an error message about not having access.
Would you be amenable to looking at my batch file?
Don
D. K. Steinman
Phone: 281.835.6364
FAX: 281.835.3806
Cell: 281.414.3074
In a message dated 2/14/2012 1:45:52 P.M. Central Standard Time, jayesh at mcs.anl.gov writes:
Why are you manually installing SMPD (smpd -install)? SMPD should have been installed as part of the MPICH2 installation.
Jayesh
Sent: Tuesday, February 14, 2012 1:41:14 PM
Subject: [mpich-discuss] problem running smpd on a windows machine
I'm trying to get MPICH2 to run on my windows machines. I have downloaded and installed both the 32 bit and 64 bit versions. However, when I try to run smpd -install, I get the message that
OpenSCManager failed:
Access is denied. (error 5)
Unable to remove the previous installation, install failed.
I've never had a previous installation.
What am I doing wrong?
thanks,
Don Steinman
Applied Physics and Measurements, Inc.
Missouri City, TX
D. K. Steinman
Phone: 281.835.6364
FAX: 281.835.3806
Cell: 281.414.3074
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
