[mpich-discuss] MPICH deadlock error
Gustavo Correa
gus at ldeo.columbia.edu
Tue Feb 14 12:04:52 CST 2012
On Feb 13, 2012, at 8:05 PM, Sarika K wrote:
> Thanks! Gus. I appreciate your feedback.
> I looked through the MPI communication and driver code (written way back in 2001) , it does includes calls to MPI_Bcast (Attached below is a sample code). I am not sure why MPI_send /MPI_Recv is used in some places and MPI_Bcast in others. I have started to learn more details about MPI calls only after encountering this deadlock error. Are there any particular cases/instances where MPI_send /MPI_Recv call set up is preferred over MPI_bcast or vice-versa?
> Best regards,
> Sarika
Hi Sarika
When one process sends the *same* data to all other processes in a communicator,
the situation begs for MPI_Bcast.
Point to point communication (send/recv) is preferred when the data exchanged across
different pairs of processes is different.
MPI_Bcast is but one type of MPI collective procedures.
There are several others with different goals [e.g. MPI_Scatter[v] and MPI_Gather[v], say,
when parts of an array is distributed/collected by a master process].
Check these MPI tutorials:
http://www.citutor.org/browse.php
https://computing.llnl.gov/tutorials/mpi/
http://www.mcs.anl.gov/research/projects/mpi/tutorial/
http://www.mcs.anl.gov/research/projects/mpi/tutorial/gropp/talk.html
http://www.cs.usfca.edu/~peter/ppmpi/
I hope this helps,
Gus Correa
> (MPI_Bcast sample code)
> Nbuf = ix+iy+iz+is+4
> if (Master) then
> k=0
> buf(k+1:k+ix)=dx(1:ix) ; k=k+ix
> buf(k+1:k+iy)=dy(1:iy) ; k=k+iy
> buf(k+1:k+iz)=sigmaz(1:iz) ; k=k+iz
> buf(k+1)=dht ; k=k+1
> buf(k+1)=baseh ; k=k+1
> buf(k+1:k+is)=rmw(1:is) ; k=k+is
> buf(k+1)=dt ; k=k+1
> buf(k+1)=ut ; k=k+1
> if (k.ne.Nbuf) then
> print*, 'Error in real_distrib. Nbuf=',Nbuf,
> & ' needed=',k
> stop
> endif
> endif
> c
> call MPI_BCAST(buf(1),Nbuf,MPI_REAL,0,MPI_COMM_WORLD,Ierr)
> c
> if (Worker) then
> k=0
> dx(1:ix)=buf(1:ix) ; k=ix
> dy(1:iy)=buf(k+1:k+iy) ; k=k+iy
> sigmaz(1:iz)=buf(k+1:k+iz) ; k=k+iz
> dht=buf(k+1) ; k=k+1
> baseh=buf(k+1) ; k=k+1
> rmw(1:is)=buf(k+1:k+is); k=k+is
> dt=buf(k+1); k=k+1
> ut=buf(k+1); k=k+1
> endif
> On Mon, Feb 13, 2012 at 4:05 PM, Gustavo Correa <gus at ldeo.columbia.edu> wrote:
> Hi Sarika
> I think you may also need an MPI_Wait or MPI_Waitall after the MPI_Recv.
> However, your code seems to broadcast the same 'buf' from Master to all Workers, right?
> Have you tried to use MPI_Bcast, instead of MPI_Send & MPI_Recv?
> A collective call, and is likely to perform better.
> Something like this:
> if (Master) then
> ...load buf with data
> endif
> call MPI_Bcast(buf, ...) ! every process calls it
> if (Worker) then
> ... unload data from buf
> endif
> I hope this helps,
> Gus Correa
> On Feb 13, 2012, at 5:03 PM, Sarika K wrote:
> > Thanks! Rajeev for the quick feedback. I really appreciate it. I have used but never never written/modified MPI code. I am assuming that I need to use the nonblocking routine MPI_Isend within the if (master) part of the sample code. Is that right?
> > Best regards,
> > Sarika
> > On Mon, Feb 13, 2012 at 1:45 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> > This will happen if the master is also sending to itself, and calls MPI_Send(to itself) before MPI_Recv(from itself). You need to either use a nonblocking send or post a nonblocking receive before the blocking send.
> > Rajeev
> > On Feb 13, 2012, at 3:28 PM, Sarika K wrote:
> > > Dear MPICH-discuss group:
> > > My work involves working with Fortran Code using MPICH for parallelization. But I have a very limited experience with the details of MPICH implementation. (I have always treated the MPICh part of the code as a black box).
> > > I am now working on porting the code across different machine configurations. My modeling code works fine on some machines/servers. But it also generates random MPI deadlock errors when running the simulations across other machines/servers.
> > > The error message is below.
> > > "Fatal error in MPI_Send: Other MPI error, error stack:
> > > MPI_Send(174): MPI_Send(buf=0x7f4d9b375010, count=1, dtype=USER<vector>, dest=1, tag=10001, MPI_COMM_WORLD) failed
> > > MPID_Send(53): DEADLOCK: attempting to send a message to the local process without a prior matching receive"
> > > I searched this list/other resources for this error code and strongly believe that there is a bug in the model MPI implementation code which remains dormant in some environments and works fine due to the internal buffering threshold dependance.
> > > I am not sure if this is sufficient information, but attached below sample subroutine (there are many inside the code) which generates the deadlock error.
> > > I would really appreciate any help/pointers from the group to fix this error in our code.
> > > Thanks in advance for your time and assistance,
> > > Sarika
> > > c-----------------------------------------------------------------------------------------------------------------------------
> > > subroutine int_distrib1(iend)
> > > c Master distributes another bunch of integers to Workers
> > > c
> > > use ParallelDataMap
> > > use CommDataTypes
> > > implicit none
> > > include 'mpif.h'
> > > c
> > > include 'aqmax.param'
> > > include 'aqindx.cmm'
> > > c
> > > integer :: iend
> > > integer, parameter :: Nbuf=35
> > > integer :: i, j, k, buf(Nbuf), Ierr, status(MPI_STATUS_SIZE)
> > > c
> > > if (Master) then
> > > ! arguments
> > > buf(1) = iend
> > > ! /aqspid/ in aqindx.cmm stuff
> > > buf(2) = iair
> > > buf(3) = ih2o
> > > buf(4) = io2
> > > buf(5) = ico
> > > buf(6) = ino2
> > > buf(7) = iho2
> > > buf(8) = iso2
> > > buf(9) = io3
> > > buf(10)= ich4
> > > buf(11)= ico2
> > > buf(12)= ih2
> > > buf(13)= in2
> > > buf(14)= itrace
> > > k=15
> > > buf(k:k+9) = ispg_idx(1:10); k=k+10
> > > buf(k:k+9) = ispl_idx(1:10); k=k+10
> > > do i=1,Nworkers
> > > call MPI_SEND(buf, Nbuf, MPI_INTEGER,
> > > & i, i, MPI_COMM_WORLD, Ierr)
> > > enddo
> > > print*, ''
> > > print*, 'done sending int_distrib1'
> > > print*, ''
> > > endif ! (Master)
> > > c
> > > c
> > > if (Worker) then
> > > call MPI_RECV(buf, Nbuf, MPI_INTEGER, 0, MyId,
> > > & MPI_COMM_WORLD, status, ierr)
> > > iend = buf(1)
> > > iair = buf(2)
> > > ih2o = buf(3)
> > > io2 = buf(4)
> > > ico = buf(5)
> > > ino2 = buf(6)
> > > iho2 = buf(7)
> > > iso2 = buf(8)
> > > io3 = buf(9)
> > > ich4 = buf(10)
> > > ico2 = buf(11)
> > > ih2 = buf(12)
> > > in2 = buf(13)
> > > itrace= buf(14)
> > > k=15
> > > ispg_idx(1:10) = buf(k:k+9); k=k+10
> > > ispl_idx(1:10) = buf(k:k+9); k=k+10
> > > print*, ''
> > > print*, 'done receiving int_distrib1'
> > > print*, ''
> > > endif ! (Worker)
> > > c
> > > end subroutine int_distrib1
> > > _______________________________________________
> > > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > > To manage subscription options or unsubscribe:
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
