[mpich-discuss] knight's ferry and opa
    Nick Radcliffe
    nradclif at cray.com
    Fri Feb 10 15:56:31 CST 2012
Does anyone know how to compile MPICH2-1.4.1p1 so that it's possible to run MPI programs natively on the Mic co-processor (Knight's Ferry)? I'm able to compile the mpich2 library and an MPI program using the library (both using -mmic so that they can run natively on the Mic), but the program crashes in MPI_Init when I run it. In particular, it crashes during OPA_write_barrier.
The particular instance of OPA_write_barrier being used is defined in opa_gcc_intel_32_64_p3barrier.h:
#define OPA_write_barrier() __asm__ __volatile__ ( "sfence" ::: "memory" )
This instance of the barrier is being used because I have to use the --host option to get the configure script to run (--host=x86_64-linux, otherwise the script tries to run a program compiled for the Mic on a Xeon, and the config fails).
If anyone knows how to deal with this problem I would appreciate their advice.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120210/31c4c317/attachment.htm>
