[mpich-discuss] running mpich2 on windows 7
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Feb 10 10:58:54 CST 2012
Bruce,
 It looks like your MPICH2 installation did not complete successfully (Since you are requested the passphrase each time you run a job).
 I would recommend the following,
# Uninstall your existing version of MPICH2 (Add/Remove Programs)
# Install MPICH2 following the instructions in Section 9.4 (NOT 9.1) of the "MPICH2 Installer's guide" (available at http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs)
# Try running a simple job ("mpiexec -n 2 hostname") and when prompted for your username/password enter a valid Windows username/password.
 Let us know if it works.
Jayesh
----- Original Message -----
Sent: Thursday, February 9, 2012 5:47:12 PM
Subject: Re: [mpich-discuss] running mpich2 on windows 7
Robert.
Can you provide more details on how to setup through wmpiconfig.exe and wmpiregister.exe?
Here is what I did:
1. I ran wmpiregister.exe first to provide user account name and password
2. Click register, then OK
3. Open wmpiconfig.exe, saw the host
4. Not sure what to set, so decided to use all defaults.
5. Click apply all
6. Open wmpiexec.exe
7. Loa d the application cpi.exe, use 1 processor
8. Click the execute
9. Saw the following message:
Error: No smpd passphrase specified through the registry or .smpd file, exiting.
What I have missed?
Bruce
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of McBroom, Robert C
Sent: Thursday, February 09, 2012 2:28 PM
To: 'mpich-discuss at mcs.anl.gov'
Bruce
Start>program files>mpich2
Environment and setup routines for your host.
Wmpiconfig.exe
Wmpiregister.exe
Robert McBroom
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Bruce Xu
Sent: Wednesday, February 08, 2012 4:18 PM
Subject: [mpich-discuss] running mpich2 on windows 7
I am new to MPICH2. I have installed the software as administer, then I try to run the example. Here is what I did:
1. %smpd –start
2. %mpiexec –n 2 cpi.exe
Each time when I use only one processor, every think worked. But as long as I use more than one processor, after entering pass phrase, it will be stuck in there forever. Then, I have to kill the job. Can someone tell me if I have missed any setup steps? I am running on a multicore laptop with windows 7 operating system.
Many thanks.
Bruce Xu
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
