[mpich-discuss] different directories for each process using host file
Jayesh Krishna jayesh at mcs.anl.gov
Mon Aug 27 09:49:59 CDT 2012
 SMPD is the process manager supported on Windows (MPICH2 install using Windows installers).
 You can find all the options available with mpiexec (SMPD) in the Windows developer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs).
>> Is it possible to use a host file to specify a separate working directory for each process?
  Can you try running your job as an MPMD program (mpiexec -host host1 -dir c:\host1_dir1 test.exe : -host host2 -dir c:\host2_dir2 test.exe )?
>> Should I only use one process for each host and let MPICH2 decide how to distribute threads among the cores or should I use as many processes as I have cores?
 It is recommended to launch as many processes as there are cores on each host.
Jayesh
----- Original Message -----
Sent: Thursday, August 23, 2012 3:15:18 PM
Subject: [mpich-discuss] different directories for each process using host file
Hello,
Can you please help me understand the syntax of process managers and how to get a job running.
If I am using a windows cluster, do I have to use smpd or can I use hydra?
host1:4 -dir dir\1 dir\2 dir\3 dir\4
host2:4 -dir dir\1 dir\2 dir\3 dir\4
host3:4 -dir dir\1 dir\2 dir\3 dir\4
or does the -dir command only work as an argument to mpiexec?
How then do I create multiple processes on multiple hosts each with their own directory?
What would be the default working directory if I just tried to run:
host1
host2
host3
Thanks
Zak_______________________________________________
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
