[mpich-discuss] different directories for each process using host file
Zachary Stanko zstanko at usgs.gov
Thu Aug 23 15:15:18 CDT 2012
Hello,
Can you please help me understand the syntax of process managers and how
to get a job running.
If I am using a windows cluster, do I have to use smpd or can I use hydra?
Is it possible to use a host file to specify a separate working directory
for each process?
host1:4 -dir dir\1 dir\2 dir\3 dir\4
host2:4 -dir dir\1 dir\2 dir\3 dir\4
host3:4 -dir dir\1 dir\2 dir\3 dir\4
or does the -dir command only work as an argument to mpiexec?
How then do I create multiple processes on multiple hosts each with their
own directory?
Should I only use one process for each host and let MPICH2 decide how to
distribute threads among the cores or should I use as many processes as I
have cores?
What would be the default working directory if I just tried to run:
host1
host2
host3
Thanks
Zak
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120823/c6111975/attachment.html>
