[mpich-discuss] Using g95 to test mpich2-1.4/test file problems
謝奇哲
991546107 at stu.nkmu.edu.tw
Thu Aug 9 07:59:07 CDT 2012
Thank you, Anthony Chan.
I tried to install the latest version of mpich2-1.4.1p1.
But I still got error messages (detail saves in testing_1p1.txt).
Processing directory coll
Looking in ./coll/testlist
Unexpected output in allred3: Fatal error in MPI_Init_thread: Other MPI
error, error stack:
Unexpected output in allred3: MPIR_Init_thread(392).........
Unexpected output in allred3: MPID_Init(139)........................:
channel initialization failed
Unexpected output in allred3: MPIDI_CH3_Init(38)....................:
Unexpected output in allred3: MPID_nem_init(196)....................:
Unexpected output in allred3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allred3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allred3: MPIU_SHMW_Seg_create_attach_templ(637):
open failed - No such file or directory
Unexpected output in alltoallw1: [mpiexec at PC03] control_cb
(./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback
returned error status
HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:181): error
waiting for event
Unexpected output in alltoallw1: [mpiexec at PC03] main
(./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Program alltoallw1 exited without No Errors
Processing directory spawn
Looking in ./spawn/testlist
Unexpected output in spawnmult2: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in spawnmult2: [proxy:0:0 at PC03]
HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed)
failed
Unexpected output in spawnmult2: [proxy:0:0 at PC03] main
(./pm/pmiserv/pmip.c:226): demux engine error waiting for event
HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one
of the processes terminated badly; aborting
HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23):
launcher returned error waiting for completion
HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher
Unexpected output in spawnmult2: [mpiexec at PC03] main
Program spawnmult2 exited without No Errors
Unexpected output in taskmaster: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in taskmaster: [proxy:0:0 at PC03]
failed
Unexpected output in taskmaster: [proxy:0:0 at PC03] main
Unexpected output in taskmaster: [proxy:126:0 at PC03]
failed
Unexpected output in taskmaster: [proxy:126:0 at PC03] main
Unexpected output in taskmaster: [mpiexec at PC03] main
Program taskmaster exited without No Errors
Unexpected output in disconnect_reconnect: [mpiexec at PC03] APPLICATION
TIMED OUT
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03]
failed
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03] main
Unexpected output in disconnect_reconnect: [mpiexec at PC03] main
Program disconnect_reconnect exited without No Errors
Can anyone give me some advices to solve the problem?
Best regards,
Chi-Che Hsieh
2012/8/9 謝奇哲 <991546107 at stu.nkmu.edu.tw>
> Hi,
> error, error stack:
> Unexpected output in allred3: MPIR_Init_thread(392).................:
> waiting for event
> failed
> failed
> failed
> TIMED OUT
> failed
> Best regards,
> Chi-Che Hsieh
> 2012/8/8 Anthony Chan <chan at mcs.anl.gov>
>> Can you try the latest stable release, 1.4.1p1 ?
>> ----- Original Message -----
>> > Hi,
>> > I'm sorry if I'm asking too many times.
>> > My case will need using mpi_init, so I install the MPICH2-1.4.
>> > I'm using WindosXP, Cygwin, g95 and single-node systems.
>> > And thank you, Jayesh Krishna. Answering my questions to let me know I
>> > should
>> > install latest Cygwin version.
>> > So, I installed the latest Cygwin version on another computer.
>> > And then the Cygwin Information was CYGWIN_NT-5.1 PC03
>> > 1.7.16(0.262/5/3)
>> > 2012-07-20 22:55 i686 Cygwin.
>> > Now, I can use mpiexec running cpi. And I can use -n <number> equal or
>> > greater than 4.
>> > daizy at PC03 /cygdrive/c/cygwin/mpich2-1.4
>> > $ mpiexec -n 4 ./examples/cpi
>> > Process 0 of 4 is on PC03
>> > pi is approximately 3.1415926544231239, Error is 0.0000000008333307
>> > wall clock time = 0.000000
>> > Process 1 of 4 is on PC03
>> > Process 2 of 4 is on PC03
>> > Process 3 of 4 is on PC03
>> > $ mpiexec -n 5 ./examples/cpi
>> > Process 0 of 5 is on PC03
>> > pi is approximately 3.1415926544231230, Error is 0.0000000008333298
>> > Process 1 of 5 is on PC03
>> > Process 2 of 5 is on PC03
>> > Process 3 of 5 is on PC03
>> > Process 4 of 5 is on PC03
>> > I would appreciate if someone can help me with the following problem:
>> > When I use command make testing in mpich2-1.4/test file, I still got
>> > error messages (detail saves in testing.txt).
>> > Unexpected output in allred: Fatal error in MPI_Init_thread: Other MPI
>> > error, error stack:
>> > Unexpected output in allred: MPIR_Init_thread(388).................:
>> > Unexpected output in allred: MPID_Init(139)........................:
>> > Unexpected output in allred: MPIDI_CH3_Init(38)....................:
>> > Unexpected output in allred: MPID_nem_init(196)....................:
>> > Unexpected output in allred: MPIDI_CH3I_Seg_commit(366)............:
>> > Unexpected output in allred: MPIU_SHMW_Hnd_deserialize(324)........:
>> > Unexpected output in allred: MPIU_SHMW_Seg_open(863)...............:
>> > Unexpected output in allred: MPIU_SHMW_Seg_create_attach_templ(637):
>> > open
>> > failed - Device or resource busy
>> > Program allred exited without No Errors
>> > Processing directory info
>> > Looking in ./info/testlist
>> > Processing directory init
>> > Looking in ./init/testlist
>> > Processing directory pt2pt
>> > Looking in ./pt2pt/testlist
>> > Unexpected output in sendflood: Fatal error in MPI_Init: Other MPI
>> > error,
>> > error stack:
>> > open failed - Permission denied
>> > Unexpected output in sendflood: [proxy:0:0 at PC03] HYDU_sock_read
>> > (./utils/sock/sock.c:272): read error (Software caused connection
>> > abort)
>> > Unexpected output in sendflood: [proxy:0:0 at PC03] pmi_cb
>> > (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
>> > callback
>> > Unexpected output in sendflood: [proxy:0:0 at PC03] main
>> > Are these error messages related with single-node systems?
>> > Can you give me some advices to solve the problem?
>> > Best regards,
>> > Chi-Che Hsieh
>> > _______________________________________________
>> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> > To manage subscription options or unsubscribe:
>> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120809/c55edbf3/attachment-0001.html>
(NOXMLCLOSE=YES && export NOXMLCLOSE && cd mpi && make testing)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi'
./runtests -srcdir=. -tests=testlist \
-mpiexec=/usr/local/bin/mpiexec \
-xmlfile=summary.xml
Looking in ./testlist
Processing directory attr
Looking in ./attr/testlist
Unexpected output in allred3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred3: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in allred3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allred3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allred3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allred3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allred3 exited without No Errors
Unexpected output in allred5: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allred5: MPIR_Init_thread(392).................:
Unexpected output in allred5: MPID_Init(139)........................: channel initialization failed
Unexpected output in allred5: MPIDI_CH3_Init(38)....................:
Unexpected output in allred5: MPID_nem_init(196)....................:
Unexpected output in allred5: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allred5: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allred5: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in allred5: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allred5: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allred5: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allred5: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allred5 exited without No Errors
Unexpected output in red3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in red3: MPIR_Init_thread(392).................:
Unexpected output in red3: MPID_Init(139)........................: channel initialization failed
Unexpected output in red3: MPIDI_CH3_Init(38)....................:
Unexpected output in red3: MPID_nem_init(196)....................:
Unexpected output in red3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in red3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in red3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in red3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program red3 exited without No Errors
Unexpected output in red4: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in red4: MPIR_Init_thread(392).................:
Unexpected output in red4: MPID_Init(139)........................: channel initialization failed
Unexpected output in red4: MPIDI_CH3_Init(38)....................:
Unexpected output in red4: MPID_nem_init(196)....................:
Unexpected output in red4: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in red4: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in red4: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in red4: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in red4: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in red4: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in red4: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program red4 exited without No Errors
Unexpected output in alltoall1: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in alltoall1: MPIR_Init_thread(392).................:
Unexpected output in alltoall1: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoall1: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoall1: MPID_nem_init(196)....................:
Unexpected output in alltoall1: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoall1: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoall1: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in alltoall1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in alltoall1: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program alltoall1 exited without No Errors
Unexpected output in alltoallv0: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in alltoallv0: MPIR_Init_thread(392).................:
Unexpected output in alltoallv0: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoallv0: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoallv0: MPID_nem_init(196)....................:
Unexpected output in alltoallv0: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoallv0: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoallv0: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in alltoallv0: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in alltoallv0: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in alltoallv0: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in alltoallv0: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program alltoallv0 exited without No Errors
Unexpected output in alltoallw1: [mpiexec at PC03] control_cb (./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
Unexpected output in alltoallw1: [mpiexec at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in alltoallw1: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:181): error waiting for event
Unexpected output in alltoallw1: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Unexpected output in allgather3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allgather3: MPIR_Init_thread(392).................:
Unexpected output in allgather3: MPID_Init(139)........................: channel initialization failed
Unexpected output in allgather3: MPIDI_CH3_Init(38)....................:
Unexpected output in allgather3: MPID_nem_init(196)....................:
Unexpected output in allgather3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allgather3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allgather3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in allgather3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allgather3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allgather3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allgather3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allgather3 exited without No Errors
Unexpected output in allgatherv2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in allgatherv2: MPIR_Init_thread(392).................:
Unexpected output in allgatherv2: MPID_Init(139)........................: channel initialization failed
Unexpected output in allgatherv2: MPIDI_CH3_Init(38)....................:
Unexpected output in allgatherv2: MPID_nem_init(196)....................:
Unexpected output in allgatherv2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in allgatherv2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in allgatherv2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in allgatherv2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program allgatherv2 exited without No Errors
Unexpected output in bcast2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in bcast2: MPIR_Init_thread(392).................:
Unexpected output in bcast2: MPID_Init(139)........................: channel initialization failed
Unexpected output in bcast2: MPIDI_CH3_Init(38)....................:
Unexpected output in bcast2: MPID_nem_init(196)....................:
Unexpected output in bcast2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in bcast2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in bcast2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in bcast2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in bcast2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in bcast2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in bcast2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program bcast2 exited without No Errors
Unexpected output in bcast3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in bcast3: MPIR_Init_thread(392).................:
Unexpected output in bcast3: MPID_Init(139)........................: channel initialization failed
Unexpected output in bcast3: MPIDI_CH3_Init(38)....................:
Unexpected output in bcast3: MPID_nem_init(196)....................:
Unexpected output in bcast3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in bcast3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in bcast3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in bcast3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in bcast3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in bcast3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in bcast3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program bcast3 exited without No Errors
Unexpected output in coll5: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll5: MPIR_Init_thread(392).................:
Unexpected output in coll5: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll5: MPIDI_CH3_Init(38)....................:
Unexpected output in coll5: MPID_nem_init(196)....................:
Unexpected output in coll5: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll5: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll5: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll5: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll5 exited without No Errors
Unexpected output in coll7: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll7: MPIR_Init_thread(392).................:
Unexpected output in coll7: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll7: MPIDI_CH3_Init(38)....................:
Unexpected output in coll7: MPID_nem_init(196)....................:
Unexpected output in coll7: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in coll7: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in coll7: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program coll7 exited without No Errors
Unexpected output in coll8: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in coll8: MPIR_Init_thread(392).................:
Unexpected output in coll8: MPID_Init(139)........................: channel initialization failed
Unexpected output in coll8: MPIDI_CH3_Init(38)....................:
Unexpected output in coll8: MPID_nem_init(196)....................:
Unexpected output in coll8: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in coll8: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in coll8: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Unexpected output in coll8: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in coll8: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in coll8: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in coll8: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in coll8: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program coll8 exited without No Errors
Unexpected output in redscatinter: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in redscatinter: MPIR_Init_thread(392).................:
Unexpected output in redscatinter: MPID_Init(139)........................: channel initialization failed
Unexpected output in redscatinter: MPIDI_CH3_Init(38)....................:
Unexpected output in redscatinter: MPID_nem_init(196)....................:
Unexpected output in redscatinter: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in redscatinter: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in redscatinter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in redscatinter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in redscatinter: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in redscatinter: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in redscatinter: MPIU_SHMW_Seg_open(863)...............:
Program redscatinter exited without No Errors
Unexpected output in redscatblk3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in redscatblk3: MPIR_Init_thread(392).................:
Unexpected output in redscatblk3: MPID_Init(139)........................: channel initialization failed
Unexpected output in redscatblk3: MPIDI_CH3_Init(38)....................:
Unexpected output in redscatblk3: MPID_nem_init(196)....................:
Unexpected output in redscatblk3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in redscatblk3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in redscatblk3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in redscatblk3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in redscatblk3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in redscatblk3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in redscatblk3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program redscatblk3 exited without No Errors
Unexpected output in exscan: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in exscan: MPIR_Init_thread(392).................:
Unexpected output in exscan: MPID_Init(139)........................: channel initialization failed
Unexpected output in exscan: MPIDI_CH3_Init(38)....................:
Unexpected output in exscan: MPID_nem_init(196)....................:
Unexpected output in exscan: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in exscan: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in exscan: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in exscan: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in exscan: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in exscan: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in exscan: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program exscan exited without No Errors
Unexpected output in exscan2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in exscan2: MPIR_Init_thread(392).................:
Unexpected output in exscan2: MPID_Init(139)........................: channel initialization failed
Unexpected output in exscan2: MPIDI_CH3_Init(38)....................:
Unexpected output in exscan2: MPID_nem_init(196)....................:
Unexpected output in exscan2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in exscan2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in exscan2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in exscan2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in exscan2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in exscan2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in exscan2: MPIU_SHMW_Seg_open(863)...............:
Program exscan2 exited without No Errors
Unexpected output in icreduce: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icreduce: MPIR_Init_thread(392).................:
Unexpected output in icreduce: MPID_Init(139)........................: channel initialization failed
Unexpected output in icreduce: MPIDI_CH3_Init(38)....................:
Unexpected output in icreduce: MPID_nem_init(196)....................:
Unexpected output in icreduce: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icreduce: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icreduce: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icreduce exited without No Errors
Unexpected output in icscatter: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icscatter: MPIR_Init_thread(392).................:
Unexpected output in icscatter: MPID_Init(139)........................: channel initialization failed
Unexpected output in icscatter: MPIDI_CH3_Init(38)....................:
Unexpected output in icscatter: MPID_nem_init(196)....................:
Unexpected output in icscatter: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icscatter: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icscatter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icscatter: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icscatter: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icscatter: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icscatter: MPIU_SHMW_Seg_open(863)...............:
Program icscatter exited without No Errors
Unexpected output in icbarrier: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icbarrier: MPIR_Init_thread(392).................:
Unexpected output in icbarrier: MPID_Init(139)........................: channel initialization failed
Unexpected output in icbarrier: MPIDI_CH3_Init(38)....................:
Unexpected output in icbarrier: MPID_nem_init(196)....................:
Unexpected output in icbarrier: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icbarrier: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icbarrier: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icbarrier exited without No Errors
Unexpected output in icallgatherv: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icallgatherv: MPIR_Init_thread(392).................:
Unexpected output in icallgatherv: MPID_Init(139)........................: channel initialization failed
Unexpected output in icallgatherv: MPIDI_CH3_Init(38)....................:
Unexpected output in icallgatherv: MPID_nem_init(196)....................:
Unexpected output in icallgatherv: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icallgatherv: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icallgatherv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program icallgatherv exited without No Errors
Unexpected output in icgatherv: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icgatherv: MPIR_Init_thread(392).................:
Unexpected output in icgatherv: MPID_Init(139)........................: channel initialization failed
Unexpected output in icgatherv: MPIDI_CH3_Init(38)....................:
Unexpected output in icgatherv: MPID_nem_init(196)....................:
Unexpected output in icgatherv: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icgatherv: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icgatherv: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icgatherv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icgatherv: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icgatherv: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icgatherv: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icgatherv exited without No Errors
Unexpected output in icalltoall: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icalltoall: MPIR_Init_thread(392).................:
Unexpected output in icalltoall: MPID_Init(139)........................: channel initialization failed
Unexpected output in icalltoall: MPIDI_CH3_Init(38)....................:
Unexpected output in icalltoall: MPID_nem_init(196)....................:
Unexpected output in icalltoall: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icalltoall: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icalltoall: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icalltoall: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in icalltoall: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icalltoall: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icalltoall: MPIU_SHMW_Seg_open(863)...............:
Program icalltoall exited without No Errors
Unexpected output in icalltoallw: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icalltoallw: MPIR_Init_thread(392).................:
Unexpected output in icalltoallw: MPID_Init(139)........................: channel initialization failed
Unexpected output in icalltoallw: MPIDI_CH3_Init(38)....................:
Unexpected output in icalltoallw: MPID_nem_init(196)....................:
Unexpected output in icalltoallw: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icalltoallw: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icalltoallw: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icalltoallw: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icalltoallw: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icalltoallw: MPIU_SHMW_Seg_open(863)...............:
Program icalltoallw exited without No Errors
Unexpected output in opland: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opland: MPIR_Init_thread(392).................:
Unexpected output in opland: MPID_Init(139)........................: channel initialization failed
Unexpected output in opland: MPIDI_CH3_Init(38)....................:
Unexpected output in opland: MPID_nem_init(196)....................:
Unexpected output in opland: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opland: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opland: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opland: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program opland exited without No Errors
Unexpected output in oplxor: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in oplxor: MPIR_Init_thread(392).................:
Unexpected output in oplxor: MPID_Init(139)........................: channel initialization failed
Unexpected output in oplxor: MPIDI_CH3_Init(38)....................:
Unexpected output in oplxor: MPID_nem_init(196)....................:
Unexpected output in oplxor: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in oplxor: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in oplxor: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in oplxor: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in oplxor: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in oplxor: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in oplxor: MPIU_SHMW_Seg_attach(925).............:
Program oplxor exited without No Errors
Unexpected output in opmaxloc: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in opmaxloc: MPIR_Init_thread(392).................:
Unexpected output in opmaxloc: MPID_Init(139)........................: channel initialization failed
Unexpected output in opmaxloc: MPIDI_CH3_Init(38)....................:
Unexpected output in opmaxloc: MPID_nem_init(196)....................:
Unexpected output in opmaxloc: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in opmaxloc: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in opmaxloc: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in opmaxloc: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program opmaxloc exited without No Errors
Processing directory comm
Looking in ./comm/testlist
Unexpected output in icsplit: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icsplit: MPIR_Init_thread(392).................:
Unexpected output in icsplit: MPID_Init(139)........................: channel initialization failed
Unexpected output in icsplit: MPIDI_CH3_Init(38)....................:
Unexpected output in icsplit: MPID_nem_init(196)....................:
Unexpected output in icsplit: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icsplit: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icsplit: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icsplit: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icsplit: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Program icsplit exited without No Errors
Unexpected output in iccreate: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in iccreate: MPIR_Init_thread(392).................:
Unexpected output in iccreate: MPID_Init(139)........................: channel initialization failed
Unexpected output in iccreate: MPIDI_CH3_Init(38)....................:
Unexpected output in iccreate: MPID_nem_init(196)....................:
Unexpected output in iccreate: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in iccreate: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in iccreate: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in iccreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program iccreate exited without No Errors
Processing directory datatype
Looking in ./datatype/testlist
Processing directory errhan
Looking in ./errhan/testlist
Processing directory group
Looking in ./group/testlist
Unexpected output in groupcreate: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in groupcreate: MPIR_Init_thread(392).................:
Unexpected output in groupcreate: MPID_Init(139)........................: channel initialization failed
Unexpected output in groupcreate: MPIDI_CH3_Init(38)....................:
Unexpected output in groupcreate: MPID_nem_init(196)....................:
Unexpected output in groupcreate: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in groupcreate: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in groupcreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in groupcreate: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in groupcreate: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in groupcreate: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in groupcreate: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program groupcreate exited without No Errors
Unexpected output in gtranksperf: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in gtranksperf: MPIR_Init_thread(392).................:
Unexpected output in gtranksperf: MPID_Init(139)........................: channel initialization failed
Unexpected output in gtranksperf: MPIDI_CH3_Init(38)....................:
Unexpected output in gtranksperf: MPID_nem_init(196)....................:
Unexpected output in gtranksperf: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in gtranksperf: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in gtranksperf: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in gtranksperf: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program gtranksperf exited without No Errors
Unexpected output in icsend: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icsend: MPIR_Init_thread(392).................:
Unexpected output in icsend: MPID_Init(139)........................: channel initialization failed
Unexpected output in icsend: MPIDI_CH3_Init(38)....................:
Unexpected output in icsend: MPID_nem_init(196)....................:
Unexpected output in icsend: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icsend: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icsend: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icsend: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icsend exited without No Errors
Processing directory rma
Looking in ./rma/testlist
Unexpected output in putfidx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in putfidx: MPIR_Init_thread(392).................:
Unexpected output in putfidx: MPID_Init(139)........................: channel initialization failed
Unexpected output in putfidx: MPIDI_CH3_Init(38)....................:
Unexpected output in putfidx: MPID_nem_init(196)....................:
Unexpected output in putfidx: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in putfidx: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in putfidx: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in putfidx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program putfidx exited without No Errors
Unexpected output in adlb_mimic1: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in adlb_mimic1: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in adlb_mimic1: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in adlb_mimic1: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Program adlb_mimic1 exited without No Errors
Unexpected output in fetchandadd_tree: Fatal error in MPI_Init: Other MPI error, error stack:
Unexpected output in fetchandadd_tree: MPIR_Init_thread(392).................:
Unexpected output in fetchandadd_tree: MPID_Init(139)........................: channel initialization failed
Unexpected output in fetchandadd_tree: MPIDI_CH3_Init(38)....................:
Unexpected output in fetchandadd_tree: MPID_nem_init(196)....................:
Unexpected output in fetchandadd_tree: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in fetchandadd_tree: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in fetchandadd_tree: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in fetchandadd_tree: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in fetchandadd_tree: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in fetchandadd_tree: MPIU_SHMW_Seg_open(863)...............:
Program fetchandadd_tree exited without No Errors
Unexpected output in fetchandadd_am: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in fetchandadd_am: MPIR_Init_thread(392).................:
Unexpected output in fetchandadd_am: MPID_Init(139)........................: channel initialization failed
Unexpected output in fetchandadd_am: MPIDI_CH3_Init(38)....................:
Unexpected output in fetchandadd_am: MPID_nem_init(196)....................:
Unexpected output in fetchandadd_am: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in fetchandadd_am: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in fetchandadd_am: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in fetchandadd_am: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in fetchandadd_am: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in fetchandadd_am: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in fetchandadd_am: MPIU_SHMW_Seg_attach(925).............:
Program fetchandadd_am exited without No Errors
Unexpected output in spawnmult2: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in spawnmult2: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in spawnmult2: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in spawnmult2: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in spawnmult2: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in spawnmult2: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher returned error waiting for completion
Unexpected output in spawnmult2: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Unexpected output in taskmaster: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in taskmaster: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in taskmaster: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in taskmaster: [proxy:126:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in taskmaster: [proxy:126:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in taskmaster: [proxy:126:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in taskmaster: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in taskmaster: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in taskmaster: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher returned error waiting for completion
Unexpected output in taskmaster: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Unexpected output in disconnect_reconnect: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in disconnect_reconnect: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in disconnect_reconnect: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in disconnect_reconnect: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher returned error waiting for completion
Unexpected output in disconnect_reconnect: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Unexpected output in disconnect_reconnect2: Fatal error in MPI_Comm_connect: Invalid port, error stack:
Unexpected output in disconnect_reconnect2: MPI_Comm_connect(127).............: MPI_Comm_connect(port="tag#0$description#PC03$port#4704$ifname#10.67.254.216$", MPI_INFO_NULL, root=0, MPI_COMM_WORLD, newcomm=0x22ac40) failed
Unexpected output in disconnect_reconnect2: MPID_Comm_connect(191)............:
Unexpected output in disconnect_reconnect2: MPIDI_Comm_connect(546)...........: Named port tag#0$description#PC03$port#4704$ifname#10.67.254.216$ does not exist
Unexpected output in disconnect_reconnect2: MPIDI_Comm_connect(401)...........:
Unexpected output in disconnect_reconnect2: MPIC_Sendrecv(192)................:
Unexpected output in disconnect_reconnect2: MPIC_Wait(540)....................:
Unexpected output in disconnect_reconnect2: MPIDI_CH3I_Progress(402)..........:
Unexpected output in disconnect_reconnect2: MPID_nem_mpich2_blocking_recv(905):
Unexpected output in disconnect_reconnect2: MPID_nem_tcp_connpoll(1838).......:
Unexpected output in disconnect_reconnect2: state_c_tmpvcsent_handler(1264)...: Failure during connection protocol
Unexpected output in disconnect_reconnect2: recv_cmd_pkt(739).................: read from socket failed - Connection reset by peer
Unexpected output in disconnect_reconnect2: MPI_Comm_connect(127)..: MPI_Comm_connect(port="", MPI_INFO_NULL, root=0, MPI_COMM_WORLD, newcomm=0x22ac40) failed
Unexpected output in disconnect_reconnect2: MPID_Comm_connect(191).:
Unexpected output in disconnect_reconnect2: MPIDI_Comm_connect(412): Named port does not exist
Unexpected output in disconnect_reconnect2: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in disconnect_reconnect2: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in disconnect_reconnect2: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in disconnect_reconnect2: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in disconnect_reconnect2: [proxy:2:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in disconnect_reconnect2: [proxy:2:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in disconnect_reconnect2: [proxy:2:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in disconnect_reconnect2: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in disconnect_reconnect2: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in disconnect_reconnect2: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher returned error waiting for completion
Unexpected output in disconnect_reconnect2: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Program disconnect_reconnect2 exited without No Errors
Unexpected output in disconnect_reconnect3: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in disconnect_reconnect3: MPIR_Init_thread(392).................:
Unexpected output in disconnect_reconnect3: MPID_Init(139)........................: channel initialization failed
Unexpected output in disconnect_reconnect3: MPIDI_CH3_Init(38)....................:
Unexpected output in disconnect_reconnect3: MPID_nem_init(196)....................:
Unexpected output in disconnect_reconnect3: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in disconnect_reconnect3: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in disconnect_reconnect3: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in disconnect_reconnect3: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in disconnect_reconnect3: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in disconnect_reconnect3: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in disconnect_reconnect3: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in disconnect_reconnect3: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Program disconnect_reconnect3 exited without No Errors
Unexpected output in disconnect: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in disconnect: MPIR_Init_thread(392).................:
Unexpected output in disconnect: MPID_Init(139)........................: channel initialization failed
Unexpected output in disconnect: MPIDI_CH3_Init(38)....................:
Unexpected output in disconnect: MPID_nem_init(196)....................:
Unexpected output in disconnect: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in disconnect: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in disconnect: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in disconnect: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program disconnect exited without No Errors
Unexpected output in concurrent_spawns: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in concurrent_spawns: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in concurrent_spawns: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77[proxy:44:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in concurrent_spawns: [proxy:44:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in concurrent_spawns: [proxy:44:0 at PC03] main): callback returned error status
Unexpected output in concurrent_spawns: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226 (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in concurrent_spawns: ): demux engine error waiting for event
Unexpected output in concurrent_spawns: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in concurrent_spawns: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in concurrent_spawns: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher returned error waiting for completion
Unexpected output in concurrent_spawns: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Program concurrent_spawns exited without No Errors
Processing directory topo
Looking in ./topo/testlist
Unexpected output in dgraph_unwgt: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in dgraph_unwgt: MPIR_Init_thread(392).................:
Unexpected output in dgraph_unwgt: MPID_Init(139)........................: channel initialization failed
Unexpected output in dgraph_unwgt: MPIDI_CH3_Init(38)....................:
Unexpected output in dgraph_unwgt: MPID_nem_init(196)....................:
Unexpected output in dgraph_unwgt: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in dgraph_unwgt: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in dgraph_unwgt: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program dgraph_unwgt exited without No Errors
Processing directory io
Looking in ./io/testlist
Unexpected output in async_any: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in async_any: MPIR_Init_thread(392).................:
Unexpected output in async_any: MPID_Init(139)........................: channel initialization failed
Unexpected output in async_any: MPIDI_CH3_Init(38)....................:
Unexpected output in async_any: MPID_nem_init(196)....................:
Unexpected output in async_any: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in async_any: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in async_any: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program async_any exited without No Errors
Processing directory f77
Looking in ./f77/testlist
Looking in ./f77/attr/testlist
Failed to build baseattrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
F77 baseattrf.f
(cd ../util && make mtestf.o)
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/util'
F77 mtestf.f
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/util'
/usr/local/bin/mpif77 ../util/mtestf.o -o baseattrf baseattrf.o
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_free.o):comm_free.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:63: recipe for target `baseattrf' failed
make[2]: *** [baseattrf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
Failed to build baseattr2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
F77 baseattr2f.f
/usr/local/bin/mpif77 ../util/mtestf.o -o baseattr2f baseattr2f.o
Makefile:61: recipe for target `baseattr2f' failed
make[2]: *** [baseattr2f] Error 1
Failed to build commattrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
F77 commattrf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o commattrf commattrf.o
Makefile:65: recipe for target `commattrf' failed
make[2]: *** [commattrf] Error 1
Failed to build commattr2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
F77 commattr2f.f
/usr/local/bin/mpif77 ../util/mtestf.o -o commattr2f commattr2f.o
Makefile:67: recipe for target `commattr2f' failed
make[2]: *** [commattr2f] Error 1
Failed to build commattr3f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
F77 commattr3f.f
/usr/local/bin/mpif77 ../util/mtestf.o -o commattr3f commattr3f.o
Makefile:69: recipe for target `commattr3f' failed
make[2]: *** [commattr3f] Error 1
Failed to build typeattrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
F77 typeattrf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o typeattrf typeattrf.o
Makefile:59: recipe for target `typeattrf' failed
make[2]: *** [typeattrf] Error 1
Failed to build typeattr2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
F77 typeattr2f.f
/usr/local/bin/mpif77 ../util/mtestf.o -o typeattr2f typeattr2f.o
Makefile:73: recipe for target `typeattr2f' failed
make[2]: *** [typeattr2f] Error 1
Failed to build typeattr3f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/attr'
F77 typeattr3f.f
/usr/local/bin/mpif77 ../util/mtestf.o -o typeattr3f typeattr3f.o
Makefile:71: recipe for target `typeattr3f' failed
make[2]: *** [typeattr3f] Error 1
Looking in ./f77/coll/testlist
Failed to build uallreducef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/coll'
F77 uallreducef.f
/usr/local/bin/mpif77 ../util/mtestf.o -o uallreducef uallreducef.o
Makefile:65: recipe for target `uallreducef' failed
make[2]: *** [uallreducef] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/coll'
Failed to build exscanf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/coll'
F77 exscanf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o exscanf exscanf.o
Makefile:67: recipe for target `exscanf' failed
make[2]: *** [exscanf] Error 1
Failed to build alltoallwf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/coll'
F77 alltoallwf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o alltoallwf alltoallwf.o
Makefile:69: recipe for target `alltoallwf' failed
make[2]: *** [alltoallwf] Error 1
Failed to build inplacef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/coll'
F77 inplacef.f
/usr/local/bin/mpif77 ../util/mtestf.o -o inplacef inplacef.o
Makefile:57: recipe for target `inplacef' failed
make[2]: *** [inplacef] Error 1
Failed to build reducelocalf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/coll'
F77 reducelocalf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o reducelocalf reducelocalf.o
Makefile:63: recipe for target `reducelocalf' failed
make[2]: *** [reducelocalf] Error 1
Looking in ./f77/datatype/testlist
Failed to build typenamef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
F77 typenamef.f
/usr/local/bin/mpif77 ../util/mtestf.o -o typenamef typenamef.o
Makefile:71: recipe for target `typenamef' failed
make[2]: *** [typenamef] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
Failed to build typesnamef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
F77 typesnamef.f
/usr/local/bin/mpif77 ../util/mtestf.o -o typesnamef typesnamef.o
Makefile:73: recipe for target `typesnamef' failed
make[2]: *** [typesnamef] Error 1
Failed to build typecntsf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
F77 typecntsf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o typecntsf typecntsf.o
Makefile:65: recipe for target `typecntsf' failed
make[2]: *** [typecntsf] Error 1
Failed to build typem2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
F77 typem2f.f
/usr/local/bin/mpif77 ../util/mtestf.o -o typem2f typem2f.o
Makefile:59: recipe for target `typem2f' failed
make[2]: *** [typem2f] Error 1
Failed to build typesubf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
F77 typesubf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o typesubf typesubf.o
Makefile:61: recipe for target `typesubf' failed
make[2]: *** [typesubf] Error 1
Failed to build packef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
F77 packef.f
In file packef.f:138
call mpi_pack_external( 'external32', inbuf2, insize2,
1
In file packef.f:131
call mpi_pack_external( 'external32', cbuf, csize,
2
Warning (155): Inconsistent types (INTEGER(4)/CHARACTER(1)) in actual argument lists at (1) and (2)
1
In file packef.f:124
call mpi_pack_external( 'external32', rbuf, rsize,
2
Warning (155): Inconsistent types (INTEGER(4)/REAL(8)) in actual argument lists at (1) and (2)
In file packef.f:155
& aintv(2), ioutbuf2, insize2, MPI_INTEGER, ierr )
1
In file packef.f:153
& aintv(2), coutbuf, csize, MPI_CHARACTER, ierr )
2
1
In file packef.f:151
& aintv(2), routbuf, rsize, MPI_DOUBLE_PRECISION, ierr )
2
/usr/local/bin/mpif77 ../util/mtestf.o -o packef packef.o
Makefile:69: recipe for target `packef' failed
make[2]: *** [packef] Error 1
Failed to build gaddressf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
F77 gaddressf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o gaddressf gaddressf.o
Makefile:63: recipe for target `gaddressf' failed
make[2]: *** [gaddressf] Error 1
Failed to build allctypesf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/datatype'
F77 allctypesf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o allctypesf allctypesf.o
Makefile:67: recipe for target `allctypesf' failed
make[2]: *** [allctypesf] Error 1
Looking in ./f77/pt2pt/testlist
Failed to build statusesf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/pt2pt'
F77 statusesf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o statusesf statusesf.o
Makefile:60: recipe for target `statusesf' failed
make[2]: *** [statusesf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/pt2pt'
Failed to build greqf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/pt2pt'
F77 greqf.f
F77 dummyf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o greqf greqf.o dummyf.o
Makefile:58: recipe for target `greqf' failed
make[2]: *** [greqf] Error 1
Looking in ./f77/info/testlist
Failed to build infotestf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/info'
F77 infotestf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o infotestf infotestf.o
Makefile:57: recipe for target `infotestf' failed
make[2]: *** [infotestf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/info'
Failed to build infotest2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/info'
F77 infotest2f.f
/usr/local/bin/mpif77 ../util/mtestf.o -o infotest2f infotest2f.o
Makefile:59: recipe for target `infotest2f' failed
make[2]: *** [infotest2f] Error 1
Processing directory spawn
Looking in ./f77/spawn/testlist
Failed to build namepubf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/spawn'
F77 namepubf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o namepubf namepubf.o
Makefile:68: recipe for target `namepubf' failed
make[2]: *** [namepubf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/spawn'
Failed to build spawnf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/spawn'
F77 spawnf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o spawnf spawnf.o
Makefile:64: recipe for target `spawnf' failed
make[2]: *** [spawnf] Error 1
Failed to build spawnargvf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/spawn'
F77 spawnargvf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o spawnargvf spawnargvf.o
Makefile:66: recipe for target `spawnargvf' failed
make[2]: *** [spawnargvf] Error 1
Failed to build connaccf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/spawn'
F77 connaccf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o connaccf connaccf.o
Makefile:62: recipe for target `connaccf' failed
make[2]: *** [connaccf] Error 1
Failed to build spawnmultf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/spawn'
F77 spawnmultf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o spawnmultf spawnmultf.o
Makefile:60: recipe for target `spawnmultf' failed
make[2]: *** [spawnmultf] Error 1
Failed to build spawnmult2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/spawn'
F77 spawnmult2f.f
/usr/local/bin/mpif77 ../util/mtestf.o -o spawnmult2f spawnmult2f.o
Makefile:58: recipe for target `spawnmult2f' failed
make[2]: *** [spawnmult2f] Error 1
Looking in ./f77/io/testlist
Failed to build iwriteatf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
../../maint/testmerge -defn=../../maint/common.defn \
./ioharness.defn ./ioharness.tlt
Opening ../../maint/common.defn..
F77 iwriteatf.f
/usr/local/bin/mpif77 -o iwriteatf iwriteatf.o ../util/mtestf.o
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_finalize.o):finalize.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:117: recipe for target `iwriteatf' failed
make[2]: *** [iwriteatf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
Failed to build iwritef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 iwritef.f
/usr/local/bin/mpif77 -o iwritef iwritef.o ../util/mtestf.o
Makefile:93: recipe for target `iwritef' failed
make[2]: *** [iwritef] Error 1
Failed to build iwriteshf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 iwriteshf.f
/usr/local/bin/mpif77 -o iwriteshf iwriteshf.o ../util/mtestf.o
Makefile:87: recipe for target `iwriteshf' failed
make[2]: *** [iwriteshf] Error 1
Failed to build writef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writef.f
/usr/local/bin/mpif77 -o writef writef.o ../util/mtestf.o
Makefile:85: recipe for target `writef' failed
make[2]: *** [writef] Error 1
Failed to build writeatf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writeatf.f
/usr/local/bin/mpif77 -o writeatf writeatf.o ../util/mtestf.o
Makefile:91: recipe for target `writeatf' failed
make[2]: *** [writeatf] Error 1
Failed to build writeallf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writeallf.f
/usr/local/bin/mpif77 -o writeallf writeallf.o ../util/mtestf.o
Makefile:89: recipe for target `writeallf' failed
make[2]: *** [writeallf] Error 1
Failed to build writeshf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writeshf.f
/usr/local/bin/mpif77 -o writeshf writeshf.o ../util/mtestf.o
Makefile:115: recipe for target `writeshf' failed
make[2]: *** [writeshf] Error 1
Failed to build writeordf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writeordf.f
/usr/local/bin/mpif77 -o writeordf writeordf.o ../util/mtestf.o
Makefile:123: recipe for target `writeordf' failed
make[2]: *** [writeordf] Error 1
Failed to build writeatallf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writeatallf.f
/usr/local/bin/mpif77 -o writeatallf writeatallf.o ../util/mtestf.o
Makefile:121: recipe for target `writeatallf' failed
make[2]: *** [writeatallf] Error 1
Failed to build writeatallbef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writeatallbef.f
/usr/local/bin/mpif77 -o writeatallbef writeatallbef.o ../util/mtestf.o \
Makefile:106: recipe for target `writeatallbef' failed
make[2]: *** [writeatallbef] Error 1
Failed to build writeallbef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writeallbef.f
/usr/local/bin/mpif77 -o writeallbef writeallbef.o ../util/mtestf.o
Makefile:95: recipe for target `writeallbef' failed
make[2]: *** [writeallbef] Error 1
Failed to build writeordbef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 writeordbef.f
/usr/local/bin/mpif77 -o writeordbef writeordbef.o ../util/mtestf.o
Makefile:111: recipe for target `writeordbef' failed
make[2]: *** [writeordbef] Error 1
Failed to build fileerrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 fileerrf.f
/usr/local/bin/mpif77 -o fileerrf fileerrf.o ../util/mtestf.o
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_abort.o):abort.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:119: recipe for target `fileerrf' failed
make[2]: *** [fileerrf] Error 1
Failed to build fileinfof; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 fileinfof.f
/usr/local/bin/mpif77 -o fileinfof fileinfof.o ../util/mtestf.o
Makefile:99: recipe for target `fileinfof' failed
make[2]: *** [fileinfof] Error 1
Failed to build shpositionf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 shpositionf.f
/usr/local/bin/mpif77 -o shpositionf shpositionf.o ../util/mtestf.o
Makefile:83: recipe for target `shpositionf' failed
make[2]: *** [shpositionf] Error 1
Failed to build atomicityf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 atomicityf.f
/usr/local/bin/mpif77 -o atomicityf atomicityf.o
Makefile:109: recipe for target `atomicityf' failed
make[2]: *** [atomicityf] Error 1
Failed to build miscfilef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 miscfilef.f
/usr/local/bin/mpif77 -o miscfilef miscfilef.o ../util/mtestf.o
Makefile:97: recipe for target `miscfilef' failed
make[2]: *** [miscfilef] Error 1
Failed to build setviewcurf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
F77 setviewcurf.f
/usr/local/bin/mpif77 -o setviewcurf setviewcurf.o ../util/mtestf.o
Makefile:113: recipe for target `setviewcurf' failed
make[2]: *** [setviewcurf] Error 1
Failed to build c2f2ciof; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/io'
CC c2f2cio.c
F77 c2f2ciof.f
/usr/local/bin/mpif77 -o c2f2ciof c2f2cio.o c2f2ciof.o ../util/mtestf.o \
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_group.o):comm_group.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:103: recipe for target `c2f2ciof' failed
make[2]: *** [c2f2ciof] Error 1
Looking in ./f77/rma/testlist
Failed to build winscale1f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 winscale1f.f
/usr/local/bin/mpif77 -o winscale1f winscale1f.o ../util/mtestf.o
Makefile:83: recipe for target `winscale1f' failed
make[2]: *** [winscale1f] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
Failed to build winfencef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 winfencef.f
/usr/local/bin/mpif77 -o winfencef winfencef.o ../util/mtestf.o
Makefile:99: recipe for target `winfencef' failed
make[2]: *** [winfencef] Error 1
Failed to build wingetf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 wingetf.f
/usr/local/bin/mpif77 -o wingetf wingetf.o ../util/mtestf.o
Makefile:81: recipe for target `wingetf' failed
make[2]: *** [wingetf] Error 1
Failed to build winscale2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 winscale2f.f
/usr/local/bin/mpif77 -o winscale2f winscale2f.o ../util/mtestf.o
Makefile:95: recipe for target `winscale2f' failed
make[2]: *** [winscale2f] Error 1
Failed to build winerrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 winerrf.f
/usr/local/bin/mpif77 -o winerrf winerrf.o ../util/mtestf.o
Makefile:87: recipe for target `winerrf' failed
make[2]: *** [winerrf] Error 1
Failed to build winnamef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 winnamef.f
/usr/local/bin/mpif77 -o winnamef winnamef.o ../util/mtestf.o
Makefile:105: recipe for target `winnamef' failed
make[2]: *** [winnamef] Error 1
Failed to build wingroupf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 wingroupf.f
/usr/local/bin/mpif77 -o wingroupf wingroupf.o ../util/mtestf.o
Makefile:97: recipe for target `wingroupf' failed
make[2]: *** [wingroupf] Error 1
Failed to build winaccf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 winaccf.f
/usr/local/bin/mpif77 -o winaccf winaccf.o ../util/mtestf.o
Makefile:101: recipe for target `winaccf' failed
make[2]: *** [winaccf] Error 1
Failed to build c2f2cwinf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
CC c2f2cwin.c
F77 c2f2cwinf.f
/usr/local/bin/mpif77 -o c2f2cwinf c2f2cwin.o c2f2cwinf.o ../util/mtestf.o \
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_win_get_group.o):win_get_group.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:92: recipe for target `c2f2cwinf' failed
make[2]: *** [c2f2cwinf] Error 1
Failed to build baseattrwinf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 baseattrwinf.f
/usr/local/bin/mpif77 -o baseattrwinf baseattrwinf.o ../util/mtestf.o \
Makefile:89: recipe for target `baseattrwinf' failed
make[2]: *** [baseattrwinf] Error 1
Failed to build winattrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 winattrf.f
/usr/local/bin/mpif77 -o winattrf winattrf.o ../util/mtestf.o
Makefile:85: recipe for target `winattrf' failed
make[2]: *** [winattrf] Error 1
Failed to build winattr2f; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/rma'
F77 winattr2f.f
/usr/local/bin/mpif77 -o winattr2f winattr2f.o ../util/mtestf.o
Makefile:103: recipe for target `winattr2f' failed
make[2]: *** [winattr2f] Error 1
Processing directory init
Looking in ./f77/init/testlist
Failed to build baseenvf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/init'
F77 baseenvf.f
/usr/local/bin/mpif77 -o baseenvf baseenvf.o ../util/mtestf.o
Makefile:78: recipe for target `baseenvf' failed
make[2]: *** [baseenvf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/init'
Looking in ./f77/comm/testlist
Failed to build commnamef; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/comm'
F77 commnamef.f
/usr/local/bin/mpif77 ../util/mtestf.o -o commnamef commnamef.o
Makefile:59: recipe for target `commnamef' failed
make[2]: *** [commnamef] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/comm'
Failed to build commerrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/comm'
F77 commerrf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o commerrf commerrf.o
Makefile:57: recipe for target `commerrf' failed
make[2]: *** [commerrf] Error 1
Processing directory ext
Looking in ./f77/ext/testlist
Failed to build c2f2cf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/ext'
CC c2f2c.c
F77 c2f2cf.f
/usr/local/bin/mpif77 -o c2f2cf c2f2c.o c2f2cf.o ../util/mtestf.o
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_rank.o):comm_rank.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:87: recipe for target `c2f2cf' failed
make[2]: *** [c2f2cf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/ext'
Failed to build ctypesinf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/ext'
F77 ctypesinf.f
CC ctypesfromc.c
/usr/local/bin/mpif77 -o ctypesinf ctypesinf.o ctypesfromc.o \
../util/mtestf.o
Makefile:80: recipe for target `ctypesinf' failed
make[2]: *** [ctypesinf] Error 1
Looking in ./f77/topo/testlist
Failed to build cartcrf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/topo'
F77 cartcrf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o cartcrf cartcrf.o
Makefile:59: recipe for target `cartcrf' failed
make[2]: *** [cartcrf] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/topo'
Failed to build dgraph_wgtf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/topo'
F77 dgraph_wgtf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o dgraph_wgtf dgraph_wgtf.o
Makefile:57: recipe for target `dgraph_wgtf' failed
make[2]: *** [dgraph_wgtf] Error 1
Failed to build dgraph_unwgtf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f77/topo'
F77 dgraph_unwgtf.f
/usr/local/bin/mpif77 ../util/mtestf.o -o dgraph_unwgtf dgraph_unwgtf.o
Makefile:61: recipe for target `dgraph_unwgtf' failed
make[2]: *** [dgraph_unwgtf] Error 1
Processing directory cxx
Looking in ./cxx/testlist
Processing directory attr
Looking in ./cxx/attr/testlist
Processing directory pt2pt
Looking in ./cxx/pt2pt/testlist
Looking in ./cxx/comm/testlist
Processing directory coll
Looking in ./cxx/coll/testlist
Unexpected output in arcomplex: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in arcomplex: MPIR_Init_thread(392).................:
Unexpected output in arcomplex: MPID_Init(139)........................: channel initialization failed
Unexpected output in arcomplex: MPIDI_CH3_Init(38)....................:
Unexpected output in arcomplex: MPID_nem_init(196)....................:
Unexpected output in arcomplex: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in arcomplex: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in arcomplex: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in arcomplex: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program arcomplex exited without No Errors
Unexpected output in uallreduce: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in uallreduce: MPIR_Init_thread(392).................:
Unexpected output in uallreduce: MPID_Init(139)........................: channel initialization failed
Unexpected output in uallreduce: MPIDI_CH3_Init(38)....................:
Unexpected output in uallreduce: MPID_nem_init(196)....................:
Unexpected output in uallreduce: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in uallreduce: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in uallreduce: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in uallreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in uallreduce: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program uallreduce exited without No Errors
Unexpected output in uexscan: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in uexscan: MPIR_Init_thread(392).................:
Unexpected output in uexscan: MPID_Init(139)........................: channel initialization failed
Unexpected output in uexscan: MPIDI_CH3_Init(38)....................:
Unexpected output in uexscan: MPID_nem_init(196)....................:
Unexpected output in uexscan: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in uexscan: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in uexscan: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program uexscan exited without No Errors
Unexpected output in alltoallw2x: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in alltoallw2x: MPIR_Init_thread(392).................:
Unexpected output in alltoallw2x: MPID_Init(139)........................: channel initialization failed
Unexpected output in alltoallw2x: MPIDI_CH3_Init(38)....................:
Unexpected output in alltoallw2x: MPID_nem_init(196)....................:
Unexpected output in alltoallw2x: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Unexpected output in alltoallw2x: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in alltoallw2x: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in alltoallw2x: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program alltoallw2x exited without No Errors
Unexpected output in icallgatherx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icallgatherx: MPIR_Init_thread(392).................:
Unexpected output in icallgatherx: MPID_Init(139)........................: channel initialization failed
Unexpected output in icallgatherx: MPIDI_CH3_Init(38)....................:
Unexpected output in icallgatherx: MPID_nem_init(196)....................:
Unexpected output in icallgatherx: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in icallgatherx: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in icallgatherx: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in icallgatherx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icallgatherx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icallgatherx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icallgatherx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icallgatherx exited without No Errors
Unexpected output in icscattervx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in icscattervx: MPIR_Init_thread(392).................:
Unexpected output in icscattervx: MPID_Init(139)........................: channel initialization failed
Unexpected output in icscattervx: MPIDI_CH3_Init(38)....................:
Unexpected output in icscattervx: MPID_nem_init(196)....................:
Unexpected output in icscattervx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in icscattervx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in icscattervx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in icscattervx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Unexpected output in icscattervx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program icscattervx exited without No Errors
Looking in ./cxx/errhan/testlist
Looking in ./cxx/init/testlist
Processing directory info
Looking in ./cxx/info/testlist
Looking in ./cxx/datatype/testlist
Looking in ./cxx/io/testlist
Unexpected output in writenosx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in writenosx: MPIR_Init_thread(392).................:
Unexpected output in writenosx: MPID_Init(139)........................: channel initialization failed
Unexpected output in writenosx: MPIDI_CH3_Init(38)....................:
Unexpected output in writenosx: MPID_nem_init(196)....................:
Unexpected output in writenosx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in writenosx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in writenosx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program writenosx exited without No Errors
Unexpected output in writeallbenosx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in writeallbenosx: MPIR_Init_thread(392).................:
Unexpected output in writeallbenosx: MPID_Init(139)........................: channel initialization failed
Unexpected output in writeallbenosx: MPIDI_CH3_Init(38)....................:
Unexpected output in writeallbenosx: MPID_nem_init(196)....................:
Unexpected output in writeallbenosx: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in writeallbenosx: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in writeallbenosx: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in writeallbenosx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Program writeallbenosx exited without No Errors
Looking in ./cxx/spawn/testlist
Looking in ./cxx/rma/testlist
Unexpected output in getgroupx: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in getgroupx: MPIR_Init_thread(392).................:
Unexpected output in getgroupx: MPID_Init(139)........................: channel initialization failed
Unexpected output in getgroupx: MPIDI_CH3_Init(38)....................:
Unexpected output in getgroupx: MPID_nem_init(196)....................:
Unexpected output in getgroupx: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in getgroupx: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in getgroupx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in getgroupx: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Program getgroupx exited without No Errors
Processing directory f90
Looking in ./f90/testlist
Looking in ./f90/attr/testlist
Failed to build baseattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC baseattrf90.f90
(cd ../util && make mtestf90.o)
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/util'
FC mtestf90.f90
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/util'
/usr/local/bin/mpif90 ../util/mtestf90.o -o baseattrf90 baseattrf90.o
Makefile:82: recipe for target `baseattrf90' failed
make[2]: *** [baseattrf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
Failed to build baseattr2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC baseattr2f90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o baseattr2f90 baseattr2f90.o
Makefile:86: recipe for target `baseattr2f90' failed
make[2]: *** [baseattr2f90] Error 1
Failed to build commattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC commattrf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o commattrf90 commattrf90.o
Makefile:84: recipe for target `commattrf90' failed
make[2]: *** [commattrf90] Error 1
Failed to build commattr2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC commattr2f90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o commattr2f90 commattr2f90.o
Makefile:92: recipe for target `commattr2f90' failed
make[2]: *** [commattr2f90] Error 1
Failed to build commattr3f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC commattr3f90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o commattr3f90 commattr3f90.o
Makefile:80: recipe for target `commattr3f90' failed
make[2]: *** [commattr3f90] Error 1
Failed to build typeattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC typeattrf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o typeattrf90 typeattrf90.o
Makefile:88: recipe for target `typeattrf90' failed
make[2]: *** [typeattrf90] Error 1
Failed to build typeattr2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC typeattr2f90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o typeattr2f90 typeattr2f90.o
Makefile:96: recipe for target `typeattr2f90' failed
make[2]: *** [typeattr2f90] Error 1
Failed to build typeattr3f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC typeattr3f90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o typeattr3f90 typeattr3f90.o
Makefile:94: recipe for target `typeattr3f90' failed
make[2]: *** [typeattr3f90] Error 1
Failed to build fandcattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/attr'
FC fandcattrf90.f90
CC fandcattrc.c
/usr/local/bin/mpif90 ../util/mtestf90.o -o fandcattrf90 fandcattrf90.o fandcattrc.o
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0xf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0x2e): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0x64): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0x87): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0xaf): undefined reference to `__emutls_get_address'
/usr/local/lib/libpmpich.a(_comm_get_attr.o):comm_get_attr.c:(.text+0xd6): more undefined references to `__emutls_get_address' follow
Makefile:90: recipe for target `fandcattrf90' failed
make[2]: *** [fandcattrf90] Error 1
Looking in ./f90/coll/testlist
Failed to build uallreducef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/coll'
FC uallreducef90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o uallreducef90 uallreducef90.o
Makefile:70: recipe for target `uallreducef90' failed
make[2]: *** [uallreducef90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/coll'
Failed to build exscanf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/coll'
FC exscanf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o exscanf90 exscanf90.o
Makefile:66: recipe for target `exscanf90' failed
make[2]: *** [exscanf90] Error 1
Failed to build alltoallwf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/coll'
FC alltoallwf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o alltoallwf90 alltoallwf90.o
Makefile:64: recipe for target `alltoallwf90' failed
make[2]: *** [alltoallwf90] Error 1
Failed to build inplacef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/coll'
FC inplacef90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o inplacef90 inplacef90.o
Makefile:58: recipe for target `inplacef90' failed
make[2]: *** [inplacef90] Error 1
Failed to build reducelocalf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/coll'
FC reducelocalf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o reducelocalf90 reducelocalf90.o
Makefile:62: recipe for target `reducelocalf90' failed
make[2]: *** [reducelocalf90] Error 1
Processing directory comm
Looking in ./f90/comm/testlist
Failed to build commnamef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/comm'
FC commnamef90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o commnamef90 commnamef90.o
Makefile:59: recipe for target `commnamef90' failed
make[2]: *** [commnamef90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/comm'
Failed to build commerrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/comm'
FC commerrf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o commerrf90 commerrf90.o
Makefile:57: recipe for target `commerrf90' failed
make[2]: *** [commerrf90] Error 1
Looking in ./f90/ext/testlist
Failed to build c2f2cf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/ext'
FC c2f2cf90.f90
CC c2f902c.c
/usr/local/bin/mpif90 -o c2f2cf90 c2f2cf90.o c2f902c.o ../util/mtestf90.o \
Makefile:80: recipe for target `c2f2cf90' failed
make[2]: *** [c2f2cf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/ext'
Failed to build ctypesinf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/ext'
FC ctypesinf90.f90
cp ./../../f77/ext/ctypesfromc.c ctypesfromc.c
CC ctypesfromc.c
/usr/local/bin/mpif90 -o ctypesinf90 ctypesinf90.o ctypesfromc.o \
../util/mtestf90.o
Makefile:85: recipe for target `ctypesinf90' failed
make[2]: *** [ctypesinf90] Error 1
Looking in ./f90/info/testlist
Failed to build infotestf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/info'
FC infotestf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o infotestf90 infotestf90.o
Makefile:59: recipe for target `infotestf90' failed
make[2]: *** [infotestf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/info'
Failed to build infotest2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/info'
FC infotest2f90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o infotest2f90 infotest2f90.o
Makefile:57: recipe for target `infotest2f90' failed
make[2]: *** [infotest2f90] Error 1
Looking in ./f90/init/testlist
Failed to build baseenvf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/init'
FC baseenvf90.f90
/usr/local/bin/mpif90 -o baseenvf90 baseenvf90.o ../util/mtestf90.o
Makefile:78: recipe for target `baseenvf90' failed
make[2]: *** [baseenvf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/init'
Looking in ./f90/io/testlist
Failed to build fileerrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/io'
FC fileerrf90.f90
/usr/local/bin/mpif90 -o fileerrf90 fileerrf90.o ../util/mtestf90.o
Makefile:92: recipe for target `fileerrf90' failed
make[2]: *** [fileerrf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/io'
Failed to build fileinfof90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/io'
FC fileinfof90.f90
/usr/local/bin/mpif90 -o fileinfof90 fileinfof90.o ../util/mtestf90.o \
Makefile:97: recipe for target `fileinfof90' failed
make[2]: *** [fileinfof90] Error 1
Failed to build shpositionf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/io'
FC shpositionf90.f90
/usr/local/bin/mpif90 -o shpositionf90 shpositionf90.o ../util/mtestf90.o \
Makefile:85: recipe for target `shpositionf90' failed
make[2]: *** [shpositionf90] Error 1
Failed to build atomicityf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/io'
FC atomicityf90.f90
/usr/local/bin/mpif90 -o atomicityf90 atomicityf90.o
Makefile:90: recipe for target `atomicityf90' failed
make[2]: *** [atomicityf90] Error 1
Failed to build miscfilef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/io'
FC miscfilef90.f90
/usr/local/bin/mpif90 -o miscfilef90 miscfilef90.o ../util/mtestf90.o \
Makefile:100: recipe for target `miscfilef90' failed
make[2]: *** [miscfilef90] Error 1
Failed to build setviewcurf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/io'
FC setviewcurf90.f90
/usr/local/bin/mpif90 -o setviewcurf90 setviewcurf90.o ../util/mtestf90.o \
Makefile:82: recipe for target `setviewcurf90' failed
make[2]: *** [setviewcurf90] Error 1
Failed to build c2f2ciof90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/io'
FC c2f2ciof90.f90
CC c2f902cio.c
/usr/local/bin/mpif90 -o c2f2ciof90 c2f2ciof90.o c2f902cio.o \
../util/mtestf90.o
Makefile:94: recipe for target `c2f2ciof90' failed
make[2]: *** [c2f2ciof90] Error 1
Processing directory misc
Looking in ./f90/misc/testlist
Failed to build sizeof2; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/misc'
FC sizeof2.f90
/usr/local/bin/mpif90 -o sizeof2 sizeof2.o
Makefile:65: recipe for target `sizeof2' failed
make[2]: *** [sizeof2] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/misc'
Looking in ./f90/pt2pt/testlist
Failed to build statusesf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/pt2pt'
FC statusesf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o statusesf90 statusesf90.o
Makefile:60: recipe for target `statusesf90' failed
make[2]: *** [statusesf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/pt2pt'
Failed to build greqf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/pt2pt'
FC greqf90.f90
FC dummyf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o greqf90 greqf90.o dummyf90.o
Makefile:58: recipe for target `greqf90' failed
make[2]: *** [greqf90] Error 1
Processing directory datatype
Looking in ./f90/datatype/testlist
Failed to build typenamef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC typenamef90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o typenamef90 typenamef90.o
Makefile:66: recipe for target `typenamef90' failed
make[2]: *** [typenamef90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
Failed to build typesnamef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC typesnamef90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o typesnamef90 typesnamef90.o
Makefile:78: recipe for target `typesnamef90' failed
make[2]: *** [typesnamef90] Error 1
Failed to build typecntsf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC typecntsf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o typecntsf90 typecntsf90.o
Makefile:82: recipe for target `typecntsf90' failed
make[2]: *** [typecntsf90] Error 1
Failed to build typem2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC typem2f90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o typem2f90 typem2f90.o
Makefile:70: recipe for target `typem2f90' failed
make[2]: *** [typem2f90] Error 1
Failed to build typesubf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC typesubf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o typesubf90 typesubf90.o
Makefile:62: recipe for target `typesubf90' failed
make[2]: *** [typesubf90] Error 1
Failed to build packef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC packef90.f90
In file packef90.f90:156
1
In file packef90.f90:154
2
1
In file packef90.f90:152
2
In file packef90.f90:139
call mpi_pack_external( 'external32', inbuf2, insize2, &
1
In file packef90.f90:132
call mpi_pack_external( 'external32', cbuf, csize, &
2
1
In file packef90.f90:125
call mpi_pack_external( 'external32', rbuf, rsize, &
2
/usr/local/bin/mpif90 ../util/mtestf90.o -o packef90 packef90.o
Makefile:74: recipe for target `packef90' failed
make[2]: *** [packef90] Error 1
Failed to build gaddressf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC gaddressf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o gaddressf90 gaddressf90.o
Makefile:60: recipe for target `gaddressf90' failed
make[2]: *** [gaddressf90] Error 1
Failed to build allctypesf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC allctypesf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o allctypesf90 allctypesf90.o
Makefile:80: recipe for target `allctypesf90' failed
make[2]: *** [allctypesf90] Error 1
Failed to build structf; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC structf.f90
In file structf.f90:65
call mpi_get_address(x,disp(2),ierr)
1
In file structf.f90:61
call mpi_get_address(name,disp(1),ierr)
2
Warning (155): Inconsistent types (REAL(8)/CHARACTER(1)) in actual argument lists at (1) and (2)
In file structf.f90:87
& x,1,MPI_DOUBLE_PRECISION, comm,ierr)
1
In file structf.f90:85
& name,5,MPI_CHARACTER, comm,ierr)
2
/usr/local/bin/mpif90 ../util/mtestf90.o -o structf structf.o
Makefile:64: recipe for target `structf' failed
make[2]: *** [structf] Error 1
Failed to build indtype; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC indtype.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o indtype indtype.o
Makefile:76: recipe for target `indtype' failed
make[2]: *** [indtype] Error 1
Failed to build createf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC createf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o createf90 createf90.o
Makefile:68: recipe for target `createf90' failed
make[2]: *** [createf90] Error 1
Failed to build sizeof; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/datatype'
FC sizeof.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o sizeof sizeof.o
Makefile:72: recipe for target `sizeof' failed
make[2]: *** [sizeof] Error 1
Processing directory f90types
Looking in ./f90/f90types/testlist
Processing directory rma
Looking in ./f90/rma/testlist
Failed to build winscale1f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC winscale1f90.f90
/usr/local/bin/mpif90 -o winscale1f90 winscale1f90.o ../util/mtestf90.o \
Makefile:93: recipe for target `winscale1f90' failed
make[2]: *** [winscale1f90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
Failed to build winfencef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC winfencef90.f90
/usr/local/bin/mpif90 -o winfencef90 winfencef90.o ../util/mtestf90.o \
Makefile:101: recipe for target `winfencef90' failed
make[2]: *** [winfencef90] Error 1
Failed to build wingetf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC wingetf90.f90
/usr/local/bin/mpif90 -o wingetf90 wingetf90.o ../util/mtestf90.o
Makefile:83: recipe for target `wingetf90' failed
make[2]: *** [wingetf90] Error 1
Failed to build winscale2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC winscale2f90.f90
/usr/local/bin/mpif90 -o winscale2f90 winscale2f90.o ../util/mtestf90.o \
Makefile:109: recipe for target `winscale2f90' failed
make[2]: *** [winscale2f90] Error 1
Failed to build winerrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC winerrf90.f90
/usr/local/bin/mpif90 -o winerrf90 winerrf90.o ../util/mtestf90.o
Makefile:81: recipe for target `winerrf90' failed
make[2]: *** [winerrf90] Error 1
Failed to build winnamef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC winnamef90.f90
/usr/local/bin/mpif90 -o winnamef90 winnamef90.o ../util/mtestf90.o
Makefile:104: recipe for target `winnamef90' failed
make[2]: *** [winnamef90] Error 1
Failed to build wingroupf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC wingroupf90.f90
/usr/local/bin/mpif90 -o wingroupf90 wingroupf90.o ../util/mtestf90.o \
Makefile:96: recipe for target `wingroupf90' failed
make[2]: *** [wingroupf90] Error 1
Failed to build winaccf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC winaccf90.f90
/usr/local/bin/mpif90 -o winaccf90 winaccf90.o ../util/mtestf90.o
Makefile:85: recipe for target `winaccf90' failed
make[2]: *** [winaccf90] Error 1
Failed to build c2f2cwinf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC c2f2cwinf90.f90
CC c2f902cwin.c
/usr/local/bin/mpif90 -o c2f2cwinf90 c2f2cwinf90.o c2f902cwin.o \
../util/mtestf90.o
Makefile:106: recipe for target `c2f2cwinf90' failed
make[2]: *** [c2f2cwinf90] Error 1
Failed to build baseattrwinf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC baseattrwinf90.f90
/usr/local/bin/mpif90 -o baseattrwinf90 baseattrwinf90.o ../util/mtestf90.o \
Makefile:87: recipe for target `baseattrwinf90' failed
make[2]: *** [baseattrwinf90] Error 1
Failed to build winattrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC winattrf90.f90
/usr/local/bin/mpif90 -o winattrf90 winattrf90.o ../util/mtestf90.o
Makefile:99: recipe for target `winattrf90' failed
make[2]: *** [winattrf90] Error 1
Failed to build winattr2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/rma'
FC winattr2f90.f90
/usr/local/bin/mpif90 -o winattr2f90 winattr2f90.o ../util/mtestf90.o \
Makefile:90: recipe for target `winattr2f90' failed
make[2]: *** [winattr2f90] Error 1
Looking in ./f90/spawn/testlist
Failed to build namepubf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/spawn'
FC namepubf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o namepubf90 namepubf90.o
Makefile:60: recipe for target `namepubf90' failed
make[2]: *** [namepubf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/spawn'
Failed to build spawnf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/spawn'
FC spawnf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o spawnf90 spawnf90.o
Makefile:62: recipe for target `spawnf90' failed
make[2]: *** [spawnf90] Error 1
Failed to build spawnargvf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/spawn'
FC spawnargvf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o spawnargvf90 spawnargvf90.o \
Makefile:67: recipe for target `spawnargvf90' failed
make[2]: *** [spawnargvf90] Error 1
Failed to build connaccf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/spawn'
FC connaccf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o connaccf90 connaccf90.o
Makefile:58: recipe for target `connaccf90' failed
make[2]: *** [connaccf90] Error 1
Failed to build spawnmultf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/spawn'
FC spawnmultf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o spawnmultf90 spawnmultf90.o \
Makefile:64: recipe for target `spawnmultf90' failed
make[2]: *** [spawnmultf90] Error 1
Failed to build spawnmult2f90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/spawn'
FC spawnmult2f90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o spawnmult2f90 spawnmult2f90.o
Makefile:70: recipe for target `spawnmult2f90' failed
make[2]: *** [spawnmult2f90] Error 1
Processing directory timer
Looking in ./f90/timer/testlist
Failed to build wtimef90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/timer'
FC wtimef90.f90
/usr/local/bin/mpif90 -o wtimef90 wtimef90.o
Makefile:54: recipe for target `wtimef90' failed
make[2]: *** [wtimef90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/timer'
Looking in ./f90/topo/testlist
Failed to build cartcrf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/topo'
FC cartcrf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o cartcrf90 cartcrf90.o
Makefile:59: recipe for target `cartcrf90' failed
make[2]: *** [cartcrf90] Error 1
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/topo'
Failed to build dgraph_wgtf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/topo'
FC dgraph_wgtf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o dgraph_wgtf90 dgraph_wgtf90.o
Makefile:57: recipe for target `dgraph_wgtf90' failed
make[2]: *** [dgraph_wgtf90] Error 1
Failed to build dgraph_unwgtf90; make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/f90/topo'
FC dgraph_unwgtf90.f90
/usr/local/bin/mpif90 ../util/mtestf90.o -o dgraph_unwgtf90 dgraph_unwgtf90.o
Makefile:61: recipe for target `dgraph_unwgtf90' failed
make[2]: *** [dgraph_unwgtf90] Error 1
Processing directory errors
Looking in ./errors/testlist
Looking in ./errors/attr/testlist
Looking in ./errors/coll/testlist
Unexpected output in bcastlength: Found 2 errors
Unexpected output in bcastlength: Did not detect mismatched length (long) on process 3
Unexpected output in bcastlength: Did not detect mismatched length (short) on process 3
Program bcastlength exited without No Errors
Looking in ./errors/comm/testlist
Processing directory group
Looking in ./errors/group/testlist
Looking in ./errors/pt2pt/testlist
Looking in ./errors/topo/testlist
Looking in ./errors/rma/testlist
Looking in ./errors/spawn/testlist
Looking in ./errors/io/testlist
Looking in ./errors/f77/testlist
Looking in ./errors/cxx/testlist
Processing directory errhan
Looking in ./errors/cxx/errhan/testlist
Looking in ./errors/cxx/io/testlist
Looking in ./errors/f90/testlist
Processing directory threads
Looking in ./threads/testlist
Looking in ./threads/pt2pt/testlist
Unexpected output in multisend2: Fatal error in MPI_Init_thread: Other MPI error, error stack:
Unexpected output in multisend2: MPIR_Init_thread(392).................:
Unexpected output in multisend2: MPID_Init(139)........................: channel initialization failed
Unexpected output in multisend2: MPIDI_CH3_Init(38)....................:
Unexpected output in multisend2: MPID_nem_init(196)....................:
Unexpected output in multisend2: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in multisend2: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in multisend2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Permission denied
Unexpected output in multisend2: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in multisend2: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in multisend2: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in multisend2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - Device or resource busy
Unexpected output in multisend2: MPIU_SHMW_Seg_create_attach_templ(637): open failed - No such file or directory
Program multisend2 exited without No Errors
Unexpected output in multisend4: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in multisend4: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in multisend4: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in multisend4: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Program multisend4 exited without No Errors
Looking in ./threads/comm/testlist
Looking in ./threads/init/testlist
Looking in ./threads/spawn/testlist
Unexpected output in th_taskmaster: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in th_taskmaster: [proxy:0:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in th_taskmaster: [proxy:0:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in th_taskmaster: [proxy:0:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in th_taskmaster: [proxy:43:0 at PC03] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed
Unexpected output in th_taskmaster: [proxy:43:0 at PC03] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
Unexpected output in th_taskmaster: [proxy:43:0 at PC03] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
Unexpected output in th_taskmaster: [mpiexec at PC03] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one of the processes terminated badly; aborting
Unexpected output in th_taskmaster: [mpiexec at PC03] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
Unexpected output in th_taskmaster: [mpiexec at PC03] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher returned error waiting for completion
Unexpected output in th_taskmaster: [mpiexec at PC03] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Program th_taskmaster exited without No Errors
194 tests failed out of 628
Details in /cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi/summary.xml
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/mpi'
(XMLFILE=../mpi/summary.xml && XMLCONTINUE=YES && \
export XMLFILE && export XMLCONTINUE && \
cd commands && make testing)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/commands'
make[1]: Nothing to be done for `testing'.
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4.1p1/test/commands'
