[mpich-discuss] Using g95 to test mpich2-1.4/test file problems
謝奇哲
991546107 at stu.nkmu.edu.tw
Thu Aug 9 07:56:29 CDT 2012
Thank you, Anthony Chan.
I tried to install the latest version of mpich2-1.4.1p1.
But I still got error messages (detail saves in testing_1p1.txt).
Processing directory coll
Looking in ./coll/testlist
Unexpected output in allred3: Fatal error in MPI_Init_thread: Other MPI
error, error stack:
Unexpected output in allred3: MPIR_Init_thread(392).................:
Unexpected output in allred3: MPID_Init(139)........................:
channel initialization failed
Unexpected output in allred3: MPIDI_CH3_Init(38)....................:
Unexpected output in allred3: MPID_nem_init(196)....................:
Unexpected output in allred3: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in allred3: MPIU_SHMW_Seg_attach(925).............:
Unexpected output in allred3: MPIU_SHMW_Seg_create_attach_templ(637):
open failed - No such file or directory
Unexpected output in alltoallw1: [mpiexec at PC03] control_cb
(./pm/pmiserv/pmiserv_cb.c:215): assert (!closed) failed
HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback
returned error status
HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:181): error
waiting for event
Unexpected output in alltoallw1: [mpiexec at PC03] main
(./ui/mpich/mpiexec.c:405): process manager error waiting for completion
Program alltoallw1 exited without No Errors
Processing directory spawn
Looking in ./spawn/testlist
Unexpected output in spawnmult2: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in spawnmult2: [proxy:0:0 at PC03]
HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed)
failed
Unexpected output in spawnmult2: [proxy:0:0 at PC03] main
(./pm/pmiserv/pmip.c:226): demux engine error waiting for event
HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:70): one
of the processes terminated badly; aborting
HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23):
launcher returned error waiting for completion
HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:191): launcher
Unexpected output in spawnmult2: [mpiexec at PC03] main
Program spawnmult2 exited without No Errors
Unexpected output in taskmaster: [mpiexec at PC03] APPLICATION TIMED OUT
Unexpected output in taskmaster: [proxy:0:0 at PC03]
failed
Unexpected output in taskmaster: [proxy:0:0 at PC03] main
Unexpected output in taskmaster: [proxy:126:0 at PC03]
failed
Unexpected output in taskmaster: [proxy:126:0 at PC03] main
Unexpected output in taskmaster: [mpiexec at PC03] main
Program taskmaster exited without No Errors
Unexpected output in disconnect_reconnect: [mpiexec at PC03] APPLICATION
TIMED OUT
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03]
failed
Unexpected output in disconnect_reconnect: [proxy:0:0 at PC03] main
Unexpected output in disconnect_reconnect: [mpiexec at PC03] main
Program disconnect_reconnect exited without No Errors
Can anyone give me some advices to solve the problem?
Best regards,
Chi-Che Hsieh
2012/8/8 Anthony Chan <chan at mcs.anl.gov>
> Can you try the latest stable release, 1.4.1p1 ?
> > Hi,
> > I'm sorry if I'm asking too many times.
> > My case will need using mpi_init, so I install the MPICH2-1.4.
> > I'm using WindosXP, Cygwin, g95 and single-node systems.
> > And thank you, Jayesh Krishna. Answering my questions to let me know I
> > should
> > install latest Cygwin version.
> > So, I installed the latest Cygwin version on another computer.
> > And then the Cygwin Information was CYGWIN_NT-5.1 PC03
> > 1.7.16(0.262/5/3)
> > 2012-07-20 22:55 i686 Cygwin.
> > Now, I can use mpiexec running cpi. And I can use -n <number> equal or
> > greater than 4.
> > daizy at PC03 /cygdrive/c/cygwin/mpich2-1.4
> > $ mpiexec -n 4 ./examples/cpi
> > Process 0 of 4 is on PC03
> > pi is approximately 3.1415926544231239, Error is 0.0000000008333307
> > wall clock time = 0.000000
> > Process 1 of 4 is on PC03
> > Process 2 of 4 is on PC03
> > Process 3 of 4 is on PC03
> > $ mpiexec -n 5 ./examples/cpi
> > Process 0 of 5 is on PC03
> > pi is approximately 3.1415926544231230, Error is 0.0000000008333298
> > Process 1 of 5 is on PC03
> > Process 2 of 5 is on PC03
> > Process 3 of 5 is on PC03
> > Process 4 of 5 is on PC03
> > I would appreciate if someone can help me with the following problem:
> > When I use command make testing in mpich2-1.4/test file, I still got
> > error messages (detail saves in testing.txt).
> > Unexpected output in allred: Fatal error in MPI_Init_thread: Other MPI
> > error, error stack:
> > Unexpected output in allred: MPIR_Init_thread(388).................:
> > Unexpected output in allred: MPID_Init(139)........................:
> > Unexpected output in allred: MPIDI_CH3_Init(38)....................:
> > Unexpected output in allred: MPID_nem_init(196)....................:
> > Unexpected output in allred: MPIDI_CH3I_Seg_commit(366)............:
> > Unexpected output in allred: MPIU_SHMW_Hnd_deserialize(324)........:
> > Unexpected output in allred: MPIU_SHMW_Seg_open(863)...............:
> > Unexpected output in allred: MPIU_SHMW_Seg_create_attach_templ(637):
> > open
> > failed - Device or resource busy
> > Program allred exited without No Errors
> > Processing directory info
> > Looking in ./info/testlist
> > Processing directory init
> > Looking in ./init/testlist
> > Processing directory pt2pt
> > Looking in ./pt2pt/testlist
> > Unexpected output in sendflood: Fatal error in MPI_Init: Other MPI
> > error,
> > error stack:
> > open failed - Permission denied
> > Unexpected output in sendflood: [proxy:0:0 at PC03] HYDU_sock_read
> > (./utils/sock/sock.c:272): read error (Software caused connection
> > abort)
> > Unexpected output in sendflood: [proxy:0:0 at PC03] pmi_cb
> > (./pm/pmiserv/pmip_cb.c:228): unable to read PMI command
> > callback
> > Unexpected output in sendflood: [proxy:0:0 at PC03] main
> > Are these error messages related with single-node systems?
> > Can you give me some advices to solve the problem?
> > Best regards,
> > Chi-Che Hsieh
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120809/8f63849c/attachment.html>
