[mpich-discuss] MPICH2 Between Linux/Windows
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Apr 13 09:29:39 CDT 2012
 Did you try running your job with nemesis and the firewalls turned off?
Jayesh
----- Original Message -----
Sent: Thursday, April 12, 2012 4:21:55 AM
Subject: [mpich-discuss] MPICH2 Between Linux/Windows
I have make ture turn off firewalls on both the machines (Windows firewall & any firewalls on Linux) .
And then I try another build with :
./configure --with-pm=smpd --with-device=ch3:sock
then I run it ,the results follows, it can print the hostname,but the program dosen't end normally.
C:\mpi>mpiexec -n 2 -machinefile machinefile.txt -channel sock -path "c:\mpi;/home/administrator/mpich2-1.4.1p1/examples
" cpi
Process 0 of 2 is on yangsq
Process 1 of 2 is on yangsq-redhat32
thanks.
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
