[mpich-discuss] mpi error
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Apr  9 14:38:58 CDT 2012
 Some suggestions,
# Since your OS is 64-bit, uninstall the 32-bit version of MPICH2 and install the 64-bit version
# Try running the sample program, cpi.exe, provided with MPICH2 and see if it works
# Run your server/client program and see if it works
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Sunday, April 8, 2012 7:37:34 AM
Subject: RE: [mpich-discuss] mpi error
I use mpich2-1.4.1p1-win-ia32, and i run the server program in command line the command is : mpiexec -np 1 server.exe
and the error now is :
Error while connecting to host, Aucune connexion n'a pu être Útablie car l'ordinateur cible l'a expressément refusée. (10061)
Connect on sock (host=MOUSSA-VAIO, port=8676) failed, exhaused all end points
Unable to connect to 'MOUSSA-VAIO:8676',
sock error: Error = -1
Thank you Jayesh
> Date: Tue, 3 Apr 2012 10:21:26 -0500
> From: jayesh at mcs.anl.gov
> To: mpich-discuss at mcs.anl.gov
> CC: b.moussa1989 at live.fr
> Subject: Re: [mpich-discuss] mpi error
> Hi,
> Which version of MPICH2 are you using? How are you running your client/server programs (Copy-paste the command and its output)?
> Regards,
> Jayesh
> From: "moussa boutouil" <b.moussa1989 at live.fr>
> To: "mpi" <mpich-discuss at mcs.anl.gov>
> Sent: Tuesday, April 3, 2012 9:36:59 AM
> Subject: [mpich-discuss] mpi error
> Hello,
> I have a client/server program, and I run it in the same machine (I have already installed MPICH2 on my machine which have OS Windows 7 64-bits).
> When I run the server program in commend line, this error appears:
> Fatal error in MPI_Open_port: Other MPI error, error stack:
> MPI_Open_port(124): MPI_Open_port(MPI_INFO_NULL, port=0x003CF6B4) failed
> MPID_Open_port(69): Function not implemented
> ****here we have the server code :
> #include "mpi.h"
> #include <cstdio>
> #include "string.h"
> #define MAX_DATA 100
> using namespace std;
> int main( int argc, char **argv )
> MPI_Comm server;
> double buf[MAX_DATA];
> char port_name[MPI_MAX_PORT_NAME];
> MPI_Init( &argc, &argv );
> strcpy(port_name, argv[1]); /* assume server's name is cmd-line arg */
> MPI_Comm_connect( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &server );
> bool done = false; int tag, n = 0;
> while (!done) {
> tag = 2;
> MPI_Send( buf, n++, MPI_DOUBLE, 0, tag, server );
> MPI_Send( buf, 0, MPI_DOUBLE, 0, 1, server );
> MPI_Comm_disconnect( &server );
> MPI_Finalize();
> return 0;
> ****here we have the client code :
> #include "mpi.h"
> #include <cstdio>
> #include "string.h"
> MPI_Comm client;
> MPI_Status status;
> char por t_name[MPI_MAX_PORT_NAME];
> int size, again;
> MPI_Comm_size(MPI_COMM_WORLD, &size);
> //if (size != 1) error(FATAL, "Server too big");
> MPI_Open_port(MPI_INFO_NULL, port_name);
> printf("server available at %s\n",port_name);
> while (1) {
> MPI_Comm_accept( port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD, &client );
> again = 1;
> while (again) {
> MPI_Recv( buf, MAX_DATA, MPI_DOUBLE, MPI_ANY_SOURCE, MPI_ANY_TAG, client, &status );
> switch (status.MPI_TAG) {
> case 0: MPI_Comm_free( &client );
> MPI_Close_port(port_name);
> MPI_Finalize();
> return 0;
> case 1: MPI_Comm_disconnect( &client );
> again = 0;
> break;
> case 2: /* do something */
> break;
> default:
> /* Unexpected message type */
> MPI_Abort( MPI_COMM_WORLD, 1 );
> if you have any solution, please help me.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
